Home > Off Topic > My RRC project
Page 11 of 53 <123 ... 101112 ... 515253>
VVS210
Door handles weren't Maestro - they were Marina/Allegro... at least they were on my J reg ex works 3 door 200Tdi.
Post #669796 8th Dec 2017 9:24pm
Procta
blackwolf wrote:
The Maestro van was used quite a lot, remember this was back in the era of British Leyland.
The original Disco used many BL parts, mostly from the Maestro van such as the rear lights and door handles. Apparently this was because there was so little money for development and tooling for the new vehicle that every penny mattered.
Yeah Rover had a habit of reusing old parts. The Rover metro used the maestro/montego fuse box and the hubs, Most of the rover metro ended up been used for the mgf.
I read that they used the floor pan of the freelander for a Rover 75 4x4 concept car years ago. Smile Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #669881 9th Dec 2017 5:07pm
grafty99
Both of my range rovers are full of montego switchgear Rolling with laughter 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #669943 9th Dec 2017 9:17pm
dorsetsmith
newer jag use ford chassis
Post #670025 10th Dec 2017 1:38pm
Procta
dorsetsmith, I think the jag uses or used the mondao floor pan. My pal said they used the ford locks too. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #670204 11th Dec 2017 12:37am
grafty99
The Jaguar x-type was basically a Mondeo. Running gear, engine and a lot of the electronics. The V6 Jag is basically a AWD ST220 Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #670354 11th Dec 2017 6:46pm
grafty99
Double post Embarassed 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #670567 12th Dec 2017 5:56pm
L110CDL
I bet you will be spending a lot of time in your workshop with all this Censored weather were having, happy dismantling Wink Clayton.
Keeper.
Post #670788 13th Dec 2017 8:38pm
grafty99
Looking under the shell, my previous assumptions were correct. The rear shell is pretty good and the front is poor. Thinking of welding the obvious bits and then getting the shell blasted. Any thoughts? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #670815 13th Dec 2017 9:52pm
grafty99
Oops, forgot to add under shots Thumbs Up
1990 Vogue SE
Post #670816 13th Dec 2017 9:54pm
mk1collector
I really want a lift at home Big Cry keep the pics coming please Thumbs Up Ray
My build thread
Post #670840 13th Dec 2017 11:21pm
Frivillesid
agreed with the previous poster, keep the pics coming. btw, my last range was looking quite the same but had health issues and been searching for meds reviews and so i had to sell it. unfortunately.
Post #670925 14th Dec 2017 5:30pm
grafty99
Made a little bit of progress today. Kept getting distracted Embarassed
Needs a really good clean up but a good base to start with.
I then split the engine and box so I can work on the engine easier. Could really do with an engine stand but haven't got the room to store one. Hence working on the crane (not ideal).
And finally stripped off the engine mounts and sump so they could have a spruce up Smile
RCP applied. Will get the top coat on tomorrow and then get the engine in hopefully Mr. Green 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #670935 14th Dec 2017 7:04pm
Romadog
Gearbox sump is another excuse for a bit of RCP relief
Did mine the other weekend along with kickdown cable replacement along with filter kit Thumbs Up
Post #670936 14th Dec 2017 7:25pm
grafty99
Yeah the gearbox is next on my list. Need to split it from the transfer box first and get it off the ground Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #670937 14th Dec 2017 7:27pm
