Home > Maintenance & Modifications > A day in the life of Miffy the 110...
Page 34 of 60 <123 ... 333435 ... 585960>
geobloke
24heuer wrote:
deja-vu?
https://www.defender2.net/forum/topic84752.html
all looks very familiar
Oh my yes those are very similar failures Rolling Eyes Shocked
Post #989461 19th Apr 2023 9:12am
geobloke
HardCharger wrote:
steveww wrote:
Salisbury axle on a Puma
Pardon my ignorance, but what are the pros and cons of this mod?
The salisbury is reputedly a "stronger" axle (based on the Dana 60 IIRC) than the P38. But it has its foibles in that they are more difficult to set up and they reduce clearance under the axle and tend to gouge trenches in the Earth Rolling Eyes
It could be since the Defender was in Canada that the Salisbury axle was what they had locally rather than going through the expense of ordering parts for the P38 from the UK. Possibly...
Post #989462 19th Apr 2023 9:16am
donmacn
Re: Front Differential Removal and Inspection
geobloke wrote:
And here is the damage to the planetary gears
I think you've done very well to catch this at this stage, though I understand that you've past reason to be vigilant. It looks to me with all those cracked planetary gears that things were about to get a lot worse and possibly quite quickly.
"Dèja vu"? - though I haven't written it up yet I've spent much of the last three months (having the luxury of a garage) refurbing my swivels/hubs/bearings/seals etc. Like you mine were only a kick in the pants off 250k miles. I just decided to change everything for 'peace of mind'. None of it is especially difficult to do incrementally, but it's all an involved process and I thought "do it once, do it properly". Though I do also get the point about not switching out serviceable parts willy-nilly. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #989463 19th Apr 2023 9:23am
excossack
Other than finding chunks in your oil, did you have any odd noises/rumbles etc?
Roughly how long do you think it took you remove diff/half shafts etc? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #989464 19th Apr 2023 9:38am
geobloke
All I am going to say on the subject of luck is thank goodness for magnetic drain plugs… Fit them people they are worth every Penny…. I have them on every drain plug.
Good effort doing your own swivels. They aren’t terribly hard but folks get frightened away by the setting of the preload with shims. The best advice I ever got was to wedge some soft soulder where the shims go and torque the bolts down. The thickness of the soulder is the thickness of the shims to start with. Works every time.
Completely agree about the peace of mind thing I have done it many times and it is the reason I am pulling the swivels off to replace the oil seal hiding behind it.
Looking forward to your write up Thumbs Up
Post #989561 19th Apr 2023 7:32pm
geobloke
Hi John. There might have been a little more transmission clunk, possibly… May have been a whine… nothing that I would have gone… A ha that there noise is indicative of the planetary gears eating themselves Laughing
If I was just pulling the diff then I would do as above and pop the whole brake and swivel assembly out by a couple of inches and extract the diff. That should take about two hours or so and minimal tools. As it was I decided to check on the CV and seals and so probably the best part of five or six hours taking my time.
Post #989562 19th Apr 2023 7:55pm
HardCharger
Oh, OK. Thank you for the information a bit wiser today Thumbs Up
Post #989584 20th Apr 2023 6:45am
donmacn
100% with you on the magnetic drain plugs - do them all is my approach.
Nice idea about the solder! I don’t find the swivels “difficult” as such, just a bit of a pain with the to-ing and fro-ing with shims. I last did this job something like 15-17 years ago. By the time I do it again I’d be in my 70s and I’m sure advanced senility will have set in. If I’m lucky I’ll remember that someone once gave me a handy tip…. but won’t be able to find it! Whistle Donald
in the past..
Post #989592 20th Apr 2023 7:32am
geobloke
And it is Island 4x4 for the win followed 48 hours later by YRM... Come on Ashcroft... It is not that I am impatient but I am burning non-rainy days and here in Wales they are hard to come by Rolling with laughter
This time around I am replacing all the bolts as when I did the swivels a few years back I didn't. Plus the swivel seal retaining rings are being replaced with YRM stainless thicker items are the las pair of OEM rings have all but turned to rust and are all bowed out between the bolts... Useless tin foil OEM components...
Post #989654 20th Apr 2023 1:12pm
geobloke
Well hopefully by then there will be a Defender2.net old codgers home we can all scuttle about in poking and prodding at what is left of our Land Rovers with what is left of our bodies and minds Rolling Eyes
Post #989655 20th Apr 2023 1:15pm
Book me a place!
Post #989656 20th Apr 2023 1:18pm
kenzle8a
I enjoy the optimism that we will have our bodies and minds after all those years of Land Rover based pain
Post #989706 20th Apr 2023 7:18pm
geobloke
I would counter that by saying it is due to our Land Rover based pain that we will keep our faculties...
You know the old axiom "use it or lose it" Thumbs Up
I was pondering on Lanoguard versus Waxoyl versus Dintrol last night before drifting off. I have used waxoyl on Miffy in the past and laterly Lanoguard just because I was curious. But I do very much like the black chassis look that Lanoguard does not allow.
So, do I wire brush, paint and Lanoguard or return back to a more traditional chassis black like Dintrol?!?
I have run out of Lanoguard so now is the time to swap if that is what I need to do. Rolling Eyes
Post #989773 21st Apr 2023 9:55am
geobloke
A day of taking apart, striping down, cleaning and painting today... Long day but a good day.
Todays job was to get the swivels off each side, clean and paint. I was nicely surprised that the 14mm 12pointed bolts came off as easily as they did and it was obvious that the nearside inner seal had been allowing swivel grease through to the axle. Wonder if this is because of excess play in the planetary gear on that side just pulling the seal out of round and allowing grease through... Possible...
Anyone replacing their swivels who might think fitting swivel gaiters is a good idea... DON'T.... Gutted to see the amount of crud and rust that has appeared under the gaiter fixing band. They will need to be treated and painted now.
So, out with the angle grinder wire brush and cordless drill wire brush. Don the bluetooth ear defenders and safety glasses and off we go. Anyone thinking that safety glasses are girly by the way should never ever use an angle grinder wire brush... Incredibly effective tool but bits fly everywhere including bits of the wire brush.
Does a great job though.
Clean off, etch primer and a good dose of Raptor 1k rattle can in black. Bloomin' marvellous outcome. So much so I did the steering arms, mud shields, QT diff guard and swivel retaining rings.
Next jobs are underneath to prepare for the new diff arriving at some point in the next month... Come on Ashcroft...
In fact if like the Raptor 1k multi-use paint so much I am tempted to do the jackal sills in it as well. They need doing desperately as do the Mammoth chequer plate at the rear that appears to have something against its black powder coating. Pretty much all fallen off...
Looking forward to tomorrow and fingers crossed the weather holds Very Happy
Post #989975 22nd Apr 2023 5:13pm
geobloke
Ok, folks looking for some advice on mechanics floor mats. I have been using a part roll of black 3mm chequer plate pattern mat for the last year or so and it has pretty much fallen to pieces from being rolled up and un-rolled.
So, looking for something else that is tough enough to be rolled out on to gravel or rough ground but be rolled up at the end of the day and noted. Padded would be lovely, but not essential.
I have seen a great selection of products in Australia, but not seen anything like them over here... Anyone else know of something similar?
Tough As ground mats Oz - https://tough-as.com.au
I do not want one of those folding foam pads, just too bulky for their useable lying area.
Any ideas?
Post #990138 24th Apr 2023 8:23am
