![]() | Home > Maintenance & Modifications > A day in the life of Miffy the 110... |
Hi Don. That is amazingly generous of you. Thank you. But... I am reluctant to fit a 2 pin diff back in to Miffy. I think the time has come for her to have a stronger upgraded diff. The irritating thing is that I know I have the abilities to build up the current diff with an ATB centre but without a workshop, vice, press etc it would be a challenging thing to do ![]() Such is life... ![]()
That is exactly as I understand it. The additional problems arise when engines are remapped and tweaked, such as a TD5. Such as Miffy. Mechanical dominoes... Add something to one end of the scale and something will happen at the other end. I think that I have heard that some of the the rear P38 axles of 110s and 130s from 2003 were fitted with the 2 pin variant of the P38 differential. Although I have no evidence of that at all. I think it is time to grab the endoscope and take a look as Miffy has a 2003 P38 rear axle. The Rover 2 pin diff can also fail when the planetary gears friction weld to the pin leading to either the pin shearing or the loss of gear teeth. Miffy's first 2 pin diff failed due to a sheared pin. I do not know why her second diff has chipped a tooth just yet. That will be something interesting to find out if it would only stop raining ![]() I do keep reverting to the thought of what is too much power or more to the point, what is enough power. The reason for thought is that my 1992 Tdi was modified and tweaked and just as rapid as Miffy but never ate a diff. She went everywhere and just kept off going day in day out off road or crunching motorway miles. I do wonder if half the problems vehicles have when off roading are down to too much power and the components of the vehicle working at the limits of their specs. In my mind more power is better but too much is not a good thing, so how much is enough???? Anyway... The time is getting close to when I am going to need to make a decision on this diff... Or do I get both front and rear diffs upgraded ![]() ![]() |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2785 ![]() ![]() |
Was the 4-gear Rover diff not already in existence? I thought it was used on V8 vehicles back as far back as the 80s, so it wasn’t brought about specifically to solve the 2-pin Tdci front diff issue but rather dusted off the shelf and stuck in instead. I would also agree that it’s the torque characteristics of the Tdci that causes the issue rather than outright power, they’re not particularly powerful engines after all compared to others. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18024 ![]() ![]() ![]() |
I didn't think it was, and I don't really see why the rear axle would have been altered to take the (weaker) P38 diff if the four-gear Rover diff was available, since it would fit straight in to an unmodified axle tube. Furthermore, why would the Salisbury diff have remained in use up to the TD5 era if there was a strong Rover diff available?
I don't know for sure when the four-gear Rover diff was introduced, but I am not personally aware of it being used anywhere prior to its appearance in the front of the Puma LWB vehicles. In many ways it did seem to take an extraordinarily long time for the four-gear Rover diff to be developed, with ENV and later Salisbury diffs providing the "strong" option in earlier years. The Stage One V8, which would be the vehicle in which you might expect a four-gear Rover diff to have first appeared, used a Salisbury rear and a Range-Rover (Rover-pattern 2 gear) front diff, with CV joints in the front axle, and a 3.54:1 axle ratio sa opposed to the then normal 4.7:1 as far as I know. |
My understanding is that it was fitted to the rear axles of V8 90s. The Salisbury diff is stronger than any Rover pattern one, so they would not have had any need to use it in the 110 or 130.
As for why they didn’t use it again when the Salisbury was discontinued I’ve no idea - presumably it was cheaper to adapt the P38 diffs to the Rover case. Some info here: https://www.megasquirt-v8.co.uk/diff_a_z.php Edit: just checked the parts catalogue and the 4-pinion diff is listed as an option for early vehicles - FTC785 |
Interesting. It makes sense to fit a long nose diff in a 90 since the fleet angle would be a problem with the P38's low pinion diff, however it makes no sense whatsoever to adapt the rear axle case of the 110 and 130 to take a P38 diff when there was a four-gear Rover diff already available which is stronger than the four-gear P38 and I bet costs no more to manufacture. It seems utterly bonkers to do that, and I wonder what on earth they were thinking.
I can only conclude that the few remaining engineers at Landrover at that time had already been completely subjugated by the fashionista halfwits and stylists who now run the show. The next question then is whether there is an existing rear axle case which takes a Rover diff and which will fit (without modification) a TD5 or Puma 110 or 130? I don't think there is, but someone may know otherwise. |
There is. A 90 or Disco 1 rear axle case will physically fit a 110 if you swap the spring seats over, and with a 4-pinion diff would give you a differential solution that’s stronger than the P38 solution but weaker than the Salisbury - ignoring differences in the strengths of the casings themselves.
A 90 and D1 as I recall both have significantly lower permitted rear axle loads than a 110, which might be a problem. It's an interesting avenue to explore though. Thanks.
Interesting discussion.
If I recall correctly there is about a 250-300kg difference in payload capacity between the Discovery 1 and Defender 110. Some of that will be spring capacity but some will be rear axle capacity. If you were to fit a HD braced Rover style rear axle it would probably bump the capacity up to comparable levels with the Salisbury and P38. Possibly... |
steveww Member Since: 05 Jan 2022 Location: Malton Posts: 611 ![]() ![]() ![]() |
Salisbury axle on a Puma
Last Saturday was the first dry day in weeks and the perfect opportunity to strip down Miffys front axle and remove the troubled differential.
The process is pretty straight forward, unbolt, take your time and don't lose any bits in the gravel/grass. I decided on dismantling the hubs, stub axle and calipers in order to remove the CV/half shafts because much of these parts are getting close to a quarter of a million miles old and I wanted to inspect them. It is a good time. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Everything came apart easily enough, it would be lovely wouldn't it to have a 2-post lift and not have to do this hunched over like Quasimodo ![]() The half shafts and CVs have almost no play between them, slightly more on the shorter drivers' side but not an alarming amount. The half shaft to differential splines are gorgeous... ![]() Click image to enlarge The CV to hub flange have seen better days, evidence of fretting and corrosion. But believe it or not much of that dates to before my ownership when the splines were un-lubricated. The actual spline wear is very minor for the amount of work they have done. ![]() Click image to enlarge The seal running surfaces look good too, there is one that will need a light clean as it has some sturdy gunk on it. Quite impressed with how good it all looks to be honest. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge The only thing that I am not so happy about are the heat colouring on the CV housing where the ball bearings run (4 photos up). It is probably 225k miles worth of colouring but it is still a ????????? Might have to replace the CVs. What do you think? As for the differential. It looks like this has nothing to do with the infamous 2-pin diff pin as that is free and apparently in good shape. There is however a lot of play in the planetary gears along the pin, more than I would expect and the reason why, I believe, they have worn so badly and begun to fall apart. https://youtu.be/oVu6b6obWHw You can see it here.... The crown wheel only has a few tiny bits of damage to it ![]() Click image to enlarge ![]() Click image to enlarge And here is the damage to the planetary gears ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 344 ![]() ![]() ![]() |
https://www.defender2.net/gallery/albums/u...G_2825.JPG
If you talking about the half moon heat marks, then my new cv joints were like this. I presume to do with the manufacture, or just a local heat treat process? |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 815 ![]() ![]() ![]() |
Pardon my ignorance, but what are the pros and cons of this mod? |
24heuer Member Since: 21 Jul 2015 Location: Edinburgh Posts: 182 ![]() ![]() ![]() |
deja-vu?
https://www.defender2.net/forum/topic84752.html all looks very familiar Cheers, Andy... Edinburgh, Scotland http://24heuer.com |
Yes I think you are right about it being caused during manufacturing as all of the CV images I looked at yesterday had the same heat marks, a hardening process perhaps. ![]() |
