Home > Maintenance & Modifications > A day in the life of Miffy the 110... |
Oh my yes those are very similar failures |
19th Apr 2023 9:12am |
The salisbury is reputedly a "stronger" axle (based on the Dana 60 IIRC) than the P38. But it has its foibles in that they are more difficult to set up and they reduce clearance under the axle and tend to gouge trenches in the Earth It could be since the Defender was in Canada that the Salisbury axle was what they had locally rather than going through the expense of ordering parts for the P38 from the UK. Possibly... |
19th Apr 2023 9:16am |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1850 |
I think you've done very well to catch this at this stage, though I understand that you've past reason to be vigilant. It looks to me with all those cracked planetary gears that things were about to get a lot worse and possibly quite quickly. "Dèja vu"? - though I haven't written it up yet I've spent much of the last three months (having the luxury of a garage) refurbing my swivels/hubs/bearings/seals etc. Like you mine were only a kick in the pants off 250k miles. I just decided to change everything for 'peace of mind'. None of it is especially difficult to do incrementally, but it's all an involved process and I thought "do it once, do it properly". Though I do also get the point about not switching out serviceable parts willy-nilly. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
19th Apr 2023 9:23am |
All I am going to say on the subject of luck is thank goodness for magnetic drain plugs… Fit them people they are worth every Penny…. I have them on every drain plug. Good effort doing your own swivels. They aren’t terribly hard but folks get frightened away by the setting of the preload with shims. The best advice I ever got was to wedge some soft soulder where the shims go and torque the bolts down. The thickness of the soulder is the thickness of the shims to start with. Works every time. Completely agree about the peace of mind thing I have done it many times and it is the reason I am pulling the swivels off to replace the oil seal hiding behind it. Looking forward to your write up |
19th Apr 2023 7:32pm |
Hi John. There might have been a little more transmission clunk, possibly… May have been a whine… nothing that I would have gone… A ha that there noise is indicative of the planetary gears eating themselves If I was just pulling the diff then I would do as above and pop the whole brake and swivel assembly out by a couple of inches and extract the diff. That should take about two hours or so and minimal tools. As it was I decided to check on the CV and seals and so probably the best part of five or six hours taking my time. |
19th Apr 2023 7:55pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 741 |
Oh, OK. Thank you for the information a bit wiser today |
20th Apr 2023 6:45am |
100% with you on the magnetic drain plugs - do them all is my approach. Nice idea about the solder! I don’t find the swivels “difficult” as such, just a bit of a pain with the to-ing and fro-ing with shims. I last did this job something like 15-17 years ago. By the time I do it again I’d be in my 70s and I’m sure advanced senility will have set in. If I’m lucky I’ll remember that someone once gave me a handy tip…. but won’t be able to find it! Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
20th Apr 2023 7:32am |
And it is Island 4x4 for the win followed 48 hours later by YRM... Come on Ashcroft... It is not that I am impatient but I am burning non-rainy days and here in Wales they are hard to come by
Click image to enlarge Click image to enlarge This time around I am replacing all the bolts as when I did the swivels a few years back I didn't. Plus the swivel seal retaining rings are being replaced with YRM stainless thicker items are the las pair of OEM rings have all but turned to rust and are all bowed out between the bolts... Useless tin foil OEM components... |
20th Apr 2023 1:12pm |
Well hopefully by then there will be a Defender2.net old codgers home we can all scuttle about in poking and prodding at what is left of our Land Rovers with what is left of our bodies and minds |
20th Apr 2023 1:15pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17516 |
Book me a place!
20th Apr 2023 1:18pm |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
I enjoy the optimism that we will have our bodies and minds after all those years of Land Rover based pain
20th Apr 2023 7:18pm |
I would counter that by saying it is due to our Land Rover based pain that we will keep our faculties...
You know the old axiom "use it or lose it" I was pondering on Lanoguard versus Waxoyl versus Dintrol last night before drifting off. I have used waxoyl on Miffy in the past and laterly Lanoguard just because I was curious. But I do very much like the black chassis look that Lanoguard does not allow. So, do I wire brush, paint and Lanoguard or return back to a more traditional chassis black like Dintrol?!? I have run out of Lanoguard so now is the time to swap if that is what I need to do. |
21st Apr 2023 9:55am |
A day of taking apart, striping down, cleaning and painting today... Long day but a good day.
Todays job was to get the swivels off each side, clean and paint. I was nicely surprised that the 14mm 12pointed bolts came off as easily as they did and it was obvious that the nearside inner seal had been allowing swivel grease through to the axle. Wonder if this is because of excess play in the planetary gear on that side just pulling the seal out of round and allowing grease through... Possible... Click image to enlarge Click image to enlarge Anyone replacing their swivels who might think fitting swivel gaiters is a good idea... DON'T.... Gutted to see the amount of crud and rust that has appeared under the gaiter fixing band. They will need to be treated and painted now. Click image to enlarge So, out with the angle grinder wire brush and cordless drill wire brush. Don the bluetooth ear defenders and safety glasses and off we go. Anyone thinking that safety glasses are girly by the way should never ever use an angle grinder wire brush... Incredibly effective tool but bits fly everywhere including bits of the wire brush. Click image to enlarge Does a great job though. Clean off, etch primer and a good dose of Raptor 1k rattle can in black. Bloomin' marvellous outcome. So much so I did the steering arms, mud shields, QT diff guard and swivel retaining rings. Click image to enlarge Click image to enlarge Click image to enlarge Next jobs are underneath to prepare for the new diff arriving at some point in the next month... Come on Ashcroft... In fact if like the Raptor 1k multi-use paint so much I am tempted to do the jackal sills in it as well. They need doing desperately as do the Mammoth chequer plate at the rear that appears to have something against its black powder coating. Pretty much all fallen off... Looking forward to tomorrow and fingers crossed the weather holds |
22nd Apr 2023 5:13pm |
Ok, folks looking for some advice on mechanics floor mats. I have been using a part roll of black 3mm chequer plate pattern mat for the last year or so and it has pretty much fallen to pieces from being rolled up and un-rolled.
So, looking for something else that is tough enough to be rolled out on to gravel or rough ground but be rolled up at the end of the day and noted. Padded would be lovely, but not essential. I have seen a great selection of products in Australia, but not seen anything like them over here... Anyone else know of something similar? Tough As ground mats Oz - https://tough-as.com.au I do not want one of those folding foam pads, just too bulky for their useable lying area. Any ideas? |
24th Apr 2023 8:23am |
