Home > Puma (Tdci) > Total loss of drive.....ah well
Page 1 of 5 12345>
ozy013
Australia 2010 Defender 110 Puma 2.4 SW Rimini Red
Well it happened at 5am this morning, on the way to work. Cruising along in 6th at 100kph on the Western Hwy near Melbourne
No warning, just a slight crunch then whirring noise. Came to a stop in the hard shoulder. Could select gears, but every time I let out the clutch no drive.
It's now been towed to Melbourne City Land Rover, who will probably get to look at it by Friday.
Initial thoughts were the output shaft, but last August I had Les Richmond, an indie, put the Ashcrofts kit in. The old shaft was pretty flogged and bone dry. Just called Les Richmond, but they're still on Holidays till the 16th Jan.
It'll be interesting to see what caused the total loss of drive, hopefully I'll know by end of business this week. The cars my daily drive, so the sooner the better. Could be many things I suppose, I was just lucky that it didn't happen whilst I was away camping in the Victorian High Country with the kids over the Christmas break.
I do all the servicing and general repairs myself, but when it involves dropping either the gearbox or TC, I just don't have the room or time do it on my own. Especially now we have friends over for a month or so, and the driveway is chockers.
This is actually the first time any of my Landy's have let me down, in 30 odd years of ownership, so not too bad going then. Hopefully I'll have more of an update by the end of the week.
When I dropped off the Defender, the service manager said over the past week they've had a least 4 tow ins a day, I guess it's that time of year. Short staffed, and a little snowed under, ah well fingers crossed.
__________________
Post #589947 3rd Jan 2017 11:56pm
ozy013
Quick update, just had call from MCLR, they've already put it on the hoist, just in the off chance that it would be "a quick fix to get me back on the road". Not bad when they said they couldn't get to it till Friday.
Unfortunately the transfer case has to come off, head technician says that it's highly likely from the noises made and past experience, that the output shaft has failed.
Post #589956 4th Jan 2017 12:08am
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
How long would the Ashcroft one take to get to you
Post #589957 4th Jan 2017 12:11am
ozy013
Not sure, especially this time of year. I purchased my kit through Les Richmond, they fit a lot of Ashcroft gear here in Melbourne.
Most parts I order from the UK take 1-2 weeks, sometimes quicker than local post.
But i do hear from others who have purchased Ashcroft's products, that they're postage is pretty swift
Post #589959 4th Jan 2017 12:18am
mk1collector
Drive flanges? Ray
My build thread
Post #589960 4th Jan 2017 12:20am
ozy013
I gave the vehicle a good going over before our trip, rears have HD Hi Tuff Engineering axles and flanges, used to be Maxi Drive. Fronts are standard. There was no play in either when I removed the caps to grease.
Post #589963 4th Jan 2017 12:26am
Avion8
Australia 2015 Defender 90 Puma 2.2 Heritage Edition SW Grasmere Green
Sorry to hear about your woes, but out of interest how many kms since your Ashcroft kit was installed. Thinking of having the Ashcroft kit installed in mine once out of warranty. 1955 Series 1 107" Pick up.
1977 RRC Suffix 'D'.
2000 Defender 110 TD5 Xtreme.
2015 Defender Heritage 90.
Post #589981 4th Jan 2017 8:07am
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
Be interesting to see if it is the Ashcroft kit that has failed, have not heard of one failing yet.
Post #589985 4th Jan 2017 8:42am
ozy013
The kit was installed August 2016, and I've done just over 7000Km's since. I also have not heard of it failing, it would be unusual for it to totally let go after such a short period of time. Especially after seeing the old shaft that came out of the vehicle, it was bone dry and worn but still usable......just, after 80,000km's of use and no lube from factory.
Still counting my lucky stars that it didn't happen whilst in the Avon Wilderness, with the kids. We didn't see another 4wd in 6-7 days.
I have sent Ashcrofts a quick email, and Dave said to keep him updated. If I had a choice it would go back to the original installer, but they don't open till the 16th. So dealer prices it is then.... Shocked Shocked
Post #589997 4th Jan 2017 9:45am
pjb
Cannot believe an Ashcroft shaft would fail in such a short time & mileage Sad
I wonder if the LR garage are going for obvious normal fail point rather than looking at it properly Question
Only time will tell & hope its fixed quickly for you 2020 P300 HSE
Post #590039 4th Jan 2017 12:35pm
Mo Murphy
Did you try driving it on diff lock at all, that would have helped diagnose whether it was axle/diff related or transfer box.
50 Shades of Pennine Grey
Post #590078 4th Jan 2017 3:13pm
I assume from the comments above that it has been established (by locking the centre diff) that it is not an axle fault.
It seems exceptionally unlikely that the Ashcroft parts could fail through fretting and wear in the mileage you have done (I suppose if there was no oil in the main gearbox the shaft wouldn't get lubricated, but I suspect that the gearbox would fail before the shaft).
It is I suppose possible that the Aschroft shaft had an internal metallurgical defect since manufacture and has failed. It will be apparent as soon as the transfer box is off, though. Mainshaft failure in the main gearbox would seem to be another possibility.
Please let us know what you find.
Post #590095 4th Jan 2017 4:32pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Sorry to hear of your plight.
I also had the original shaft swapped out at 80000 kms and replaced it with the Ashcroft one only a month ago. The original shaft was dry, worn and rusty but still functioning. Waiting to see what the diagnosis is. Could also be a halfshaft, flange, an installation fault on the Ashcroft, or a material fault on the original piece supplied to them.
Fingers crossed..... 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #590123 4th Jan 2017 5:49pm
ozy013
As blackwolf said, the first thing I tried when pulled over in the hard shoulder was locking the centre diff.
As soon as I know more, I will post, I was also thinking of mainshaft failure, but i guess its all speculation at the moment.
Post #590146 4th Jan 2017 7:00pm
Pickles
G'day Ozy,..again,....from sunny downtown Aspendale.
Great forum this, isn't it?.....There'll be plenty of guys on here, who'll be interested to see what's happened.
Regards, Pickles.
Post #590272 4th Jan 2017 11:33pm
Page 1 of 5 12345>
