Home > Td5 > new fuel pump,cleand out harness now running s**t...help |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
Try unplugging the maf sensor see if it makes any difference probably need replacing but only with genuine/vdo I assume you have replaced injector harness already? If not that would be first port of call easy to do about 30 mins job again use genuine loom only 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
15th Dec 2016 8:27pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
You have to replace the injector loom. That's where the oil is coming from. You will still have plenty of oil in the main loom that will come out giving time. So you will need to clean you red plug regulary till you see less and less oil coming out.
Take the ECU out and place it with the plugs down, I hope you didn't get much oil in the ECU. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
16th Dec 2016 10:02am |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 636 |
The oil is not the real problem, real problem of the loom are tiny connectors on the injectors side of the loom. It loosens contact.
But with replacing the fuel pump you need to purge the fuel system. And it can take quite a bit of time. The procedure was already described somewhere here. And also the new pump can be faulty. If you unplug a pipe from fuel pressure regulator, and switch on the ignition, fuel must squirt out, not just slowly flowing. Put the pipe into a suitable container to catch the fuel. It should be approx. 3 l/ hour of fuel. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo |
16th Dec 2016 12:10pm |
lozza Member Since: 13 Oct 2016 Location: oxfordshire Posts: 190 |
thanks for the reply's,pump is working gonna change the loom,forgot all about the loom issue to be honest only had it once in 16 yrs
loz |
17th Dec 2016 8:20am |
update.....replaced loom,cleaned out any oil in red connector still not running
any other ideas lads loz |
21st Dec 2016 4:58pm |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772 |
Disconnect the maf and drive it about for a week Ray
21st Dec 2016 5:23pm |
its just not starting now,cycled the pump done the 5 throttle press cycle just loads of white smoke
21st Dec 2016 5:40pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Injector seals gone or fuel pressure regulator leaking ???
Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
21st Dec 2016 6:42pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4793 |
+1 for injector seals, gets progressively worse till it won't run.... 2002 90 Td5 Station Wagon
21st Dec 2016 7:30pm |
Once after replacing fuel cooler, I was not able to purge the fuel system. After 1 hour playing I have just pressed the gas pedal for full throttle and let the starter run for long time (30 seconds). And it finally started, with big cloud of smoke. After that it runs perfectly. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
21st Dec 2016 9:18pm |
hi,no leaks anywhere was performing perfectly for 15 yrs before fuel pump went quite suddenly on a 10 mile drive,it will start with jumpleads and 15 mins of trying,had ecu off over night no oil came out,i was gutted when it did not start with the new loom,going to get a new regulator and air mass thingy but still very open to any advice
if you let your fuel pump start cycle compleat then press the throttle 5 times it will constantly cycle and the engine light will flash purging the system loz |
22nd Dec 2016 7:25am |
Have you replaced the fuel filter? And also is the replacement pump a genuine one? I have heard stories of brand new aftermarket ones failing literally immediately, as in they don't work our of the box.... 2002 90 Td5 Station Wagon
22nd Dec 2016 9:45am |
Also if you do replace the filter make sure it is filled with fresh diesel not the stuff out of the old filter 2002 90 Td5 Station Wagon
22nd Dec 2016 9:47am |
new filter,pump is a good one 220 quid i have had it running but needed jump leads to start it,spoke to a indi dealer today he seems to think its injector seals but there is no leaks anywhere and it was running perfect before the pump gave up
22nd Dec 2016 5:26pm |
