Home > Technical > How-To: Side locker Nakatanenga
Page 2 of 3 <123>
nakatanenga
Germany
The doors are exactly the same, just the position of hinge and lock is turned by 90°
EUR 375.- is 4.5h labour inc VAT. A simple but time consuming job, true. WANTED:
SII or SIII in max 1.5k
Post #521505 6th Apr 2016 1:09pm
ARC99
nakatanenga wrote:
What do you mean with: long small, thin bar with ovals in
looking at the photo I believe the reference is to the chain. Don't make old people mad.
Richard
Post #521514 6th Apr 2016 1:33pm
Penguin
Belgium 2015 Defender 110 Puma 2.2 HT Chawton White
nakatanenga wrote:
The perforated plates can be used as additional support (over 10kg load)
This one:
 28/02 - Loss of a good friend...
In a time of chimpanzees, I was a penguin.
Post #521515 6th Apr 2016 1:35pm
nakatanenga
Germany
Sorry, that's a hanger from the powdercoater. WANTED:
Post #521518 6th Apr 2016 1:48pm
Penguin
Laughing ok 28/02 - Loss of a good friend...
Post #521523 6th Apr 2016 1:52pm
nakatanenga wrote:
The instructions are as following:
measure the hole
cut the hole
rivet the thingy in
job done
4.5 hours - are you cutting the hole with a rusty bread knife?
Post #521644 6th Apr 2016 7:14pm
L110CDL
Hi i have not got the side locker that you have got, but when i fitted my 2 lockers (one each side) i made a bracket up to bolt on the back of the box to the landy chassis and put some Stixall (same as Tiger Seal but cheaper) around the bolt heads in the box to keep the water out, which has worked 100%, hope this helps you Thumbs Up Clayton.
Keeper.
Post #521746 6th Apr 2016 9:40pm
Penguin
Thx for the tip. 28/02 - Loss of a good friend...
Post #521775 7th Apr 2016 5:10am
Penguin
The drilling is done.
To fit it in the right side of a 2015 puma, you have about 15mm margin to place the box.
If you go higher, you have to go more to the back, and then the fuel filter gets in the way.
Tomorrow I'll make the support so the box can rest on the chassis and be fixed to the support.
The fuel filter protector also needs a cut or the locker will not fit.
If you have rock-sliders you can't place the locker lower than 30mm from the bottom of the side panel, or you won't be able to open the door wide enough.
I also have the impression that the door is quite far from the side panel. Seems like the locker should not be pushed in the whole but place via the bottem and then push it outwards, but there is not enough space to make that possible.
Once done, more photo's will follow.
Post #521927 7th Apr 2016 4:26pm
L110CDL
Your making good progress there, you get very nervous when you are cutting the hole out, even when you have measured ten times Thumbs Up Clayton.
Keeper.
Post #522044 7th Apr 2016 9:35pm
Penguin
oooh yes.. It took me a while before I made the first cut on the final measurement Smile
Today I'll try to get the box installed from below and push it outwards, so the door is closer to the body. Kept me awake for some hours Rolling Eyes 28/02 - Loss of a good friend...
Post #522086 8th Apr 2016 6:04am
Penguin
Job done, but not straight forward. The locks were to high in the door. Shortening the lips heated them up, so the welding got loose.
So, that's how you get 4,5 hrs Smile 28/02 - Loss of a good friend...
Post #522205 8th Apr 2016 11:43am
Penguin
http://www.defender2.net/forum/post522737.html#522737
Full report can be read on the website. 28/02 - Loss of a good friend...
Post #522738 10th Apr 2016 12:04pm
Mo Murphy
Good work penguin, sometimes you have to be brave 😊
Nice to see you fitting stuff yourself, too many people miss out on the 'fun' of installation by paying someone else to do it.
Well done Thumbs Up
50 Shades of Pennine Grey
Post #522741 10th Apr 2016 12:33pm
Penguin
thank you Smile 28/02 - Loss of a good friend...
Post #522744 10th Apr 2016 12:37pm
Page 2 of 3 <123>
