Home > Technical > How-To: Side locker Nakatanenga |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8581 |
I have not fitted a side locker so can not give direct advice.
Please drop an email to info@nakatanenga.de I am sure someone there can help out. Brendan |
6th Apr 2016 7:19am |
Penguin Member Since: 08 Dec 2014 Location: Tienen Posts: 247 |
6th Apr 2016 8:24am |
Paul55 Member Since: 03 Feb 2009 Location: Somewhere in my head! Posts: 511 |
I'm sure I've seen a vid on YouTube try there, good luck Cogito ergo sum
6th Apr 2016 8:37am |
simon67 Member Since: 18 Jun 2015 Location: west sussex Posts: 569 |
Look for a professional on here, good luck with that one
Have a large group of happy amateurs who each have an opinion on everything I would ask the indies round you for a quote, at least you are covered if they it up |
6th Apr 2016 8:39am |
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 627 |
This seems a pretty poor reply for a company selling to the public. How does the professional know to install their equipment safely without product information or instructions? 1995 Defender 110 CSW
1971 SIIA Lightweight |
6th Apr 2016 8:50am |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 |
To be honest: The job is pretty easy, but requires some skilful measurements. Depending on the MY and the built quality the measures are a bit different. So there is NO CHANCE for a template.
The instructions are as following: measure the hole cut the hole rivet the thingy in job done WANTED: SII or SIII in max 1.5k |
6th Apr 2016 9:39am |
6th Apr 2016 9:48am |
How much did you pay for the kit?
6th Apr 2016 10:58am |
289,00 €
https://www.nakatanenga.de/zubehoer/ordnun...eschichtet Cost to be installed by them € 375.00 (for an easy job, not bad....) https://www.nakatanenga.de/zubehoer/ordnun...fender-110 28/02 - Loss of a good friend... In a time of chimpanzees, I was a penguin. |
6th Apr 2016 11:09am |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10382 |
Measure 8 times, cut once.
6th Apr 2016 11:16am |
Peter Td4 Member Since: 23 Oct 2010 Location: Antwerp, Belgium Posts: 228 |
Hi Penguin,
From the picture on their website : I would say that the lines of spot welds is your best reference. But some pictures showing the underside / rearside after mounting would indeed be helpful. Good luck on the install Peter, Defender 110 StaWa - Td5 Defender 110 HCPU - Puma Defender 90 Soft Top - Td5 |
6th Apr 2016 11:47am |
hard to tell Peter.
As you maybe saw, the door I have is different from the models posted on their site. And the door drops open now. So if the size is different... I'm .... It'll be indeed measure x8, measure again, cut and, as usual followed, by a lot of swearing in different languages 28/02 - Loss of a good friend... In a time of chimpanzees, I was a penguin. |
6th Apr 2016 11:51am |
Windowlicker Member Since: 24 Aug 2014 Location: East yorks Posts: 290 |
Are the perforated plates spreader plates for the rivet to pass through behind the panel maybe ?? "Procrastination is the thief of time"
6th Apr 2016 12:41pm |
It will hold load up to 10kg, even under the harshest offroad conditions. Proofed.
The perforated plates can be used as additional support (over 10kg load) What do you mean with: long small, thin bar with ovals in WANTED: SII or SIII in max 1.5k |
6th Apr 2016 1:06pm |
