![]() | Home > General & Technical (L663) > NEXT LAND ROVER DEFENDER |
Michaels Defender Member Since: 16 Aug 2007 Location: North Yorkshire Posts: 278 ![]() ![]() ![]() |
I quite like this idea for the new Defender
![]() ![]() Click image to enlarge |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6324 ![]() ![]() ![]() |
I like the last paragraph in the article
"Defenders are sprayed with 343 high-pressure water jets for 14 minutes to check for leaks in the Monsoon Chamber" ![]() ![]() ![]() Am I missing the point? mine was clearly checked to make sure it had leaks - there were several. |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3790 ![]() ![]() ![]() |
I tell you what, that's not bad, in fact, I reckon it's the best I've seen to date. Pickles. |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2774 ![]() ![]() |
Square it off a little and I don't actually mind the DC100 as much anymore. Just needs proper wheels& tyres and a long wheelbase:
![]() And I quite like this ![]() Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
I always did like the dc100
![]() My build thread http://www.defender2.net/forum/topic17615.html |
That would be 4 yes 4 alpine Windows to leak, could the new one really leak more than the old? With that set up yes it could ![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 ![]() ![]() |
If they built something like that yellow 110, Then in these days of health and safety nanny state engineering I'd be happy enough.. Yes it's not really a Defender as we know it... But it never can be can it...
Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17686 ![]() ![]() ![]() |
The similarity to the Skoda Yeti is very apparent! |
The defender as we know it is dead.
Land Rover's main goal now should be to build the best4x4xfar again. Something to beat toyota/jeep and cement land rover's off road status again. If it can be utilitarian and have some design cues from the current (old ![]() Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
The farm I work on has had a Land Rover since 1948. We've had Series 1, 2, 2A, 1ton, 3, 110 and Defender; and multiple varieties of each. Each bought because it was the best vehicle for the job at the time.
We currently have a 2005 110. I would be disappointed if there wasn't a Land Rover product for us when it comes up for replacement in 5-10 years time. |
Even if the defender station wagons move upmarket a bit, I hope Land Rover make a fantastic pickup version. Something to rival the Amarok and hilux at the higher end of the market... Cheers, David
Perhaps it needs to be a bit wider to give us more elbow room
Edzi Member Since: 20 Sep 2015 Location: London Posts: 279 ![]() ![]() ![]() |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3150 ![]() ![]() ![]() |
You had a 1-Ton? Do you mean a 101 or an actual 1-ton? Sorry to go OT, just curious. 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
