Home > General & Technical (L663) > NEXT LAND ROVER DEFENDER
Page 3 of 35 <123 4 ... 333435>
Cheshire110
Agreed. I can't see it starting at over Ł31/32k but extras might push it up.
I reckon a jump of around ~5k for similar spec to current would be reasonable. Cheers, David
Post #367993 29th Oct 2014 12:59pm
SS90
Re: A bit more info...
davidwhittaker wrote:
"JLR is determined that the new Defender will be able to thrive in the world’s harshest conditions, to the extent that it will be able to ‘plug into’ existing component networks by using the same wheel and tyres sizes as Toyota’s Land Cruiser and Hilux.
Autocar has been unable to substantiate rumours that the new Defender also uses the same bolt circle diameter to make wheel replacement easier in places such as central Africa."
Isn't that what the Defenders done, thrived in the harshest conditions? It's done that because of their practical simplistic nature. I'd bet my bottom dollar that this will have more electronics than ever before, more to go wrong when you're out in the desert. To my mind they've gone too far with what they have now. I imagine the majority of Defender lovers will keep hold with what they have and this will appeal to a different market entirely.
Before too long you won't be able to tell the difference between a replacement Defender, a FreeLander, Evoque, Discovery and Range Rover, they all look the same.
Think I'm correct in saying that many Manufacturers have tried to produce a vehicle to rival the Defender and have failed so what makes Land Rover think they can produce something better?
Post #368001 29th Oct 2014 1:14pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Defender-Stu wrote:
I have found out last night from one of the design team at JLR that the Chassis for the new defender will be one that is used for the current models like the Evoque/Discovery and they currently working on the suspension options.
If i can get more info out of him i will try but its all hush hush
He won't tell you anything more of he reads this thread!
Post #368006 29th Oct 2014 1:43pm
Marky Boy
Whilst i can understand the simple is best argument, I would have thought that modern vehicles will all have some form of electronic engine management systems to comply with ever increasing emission requirements - as such your stuck with them.
Done correctly, electronics devices are perfectly capable of surviving in harsh conditions for many years and as such should not be dismissed as unreliable. I suppose the key words are "done correctly".
Aren't Merc G Wagons full of electrickery (stand to be corrected on this !) and they seem to have a reputation as a reliable world eating bit of kit ?
The Defender will have electronics in the same way a Ford Fiesta does, OK the Fiesta isnt expected to drive through swamps and over frozen Tundra, but engineered correctly I dont see it as a problem.
Just my thoughts as a TD5 owner who has never had a 200TDi or earlier.....
Post #368011 29th Oct 2014 2:05pm
Cheshire110
I agree. The days of ECU-less cars are over. They can't really be sold anywhere.
Land cruisers, Nissan patrols, hiluxes, g wagens etc all are very electrical.
The hilux that TG took to the North Pole would have been a common rail diesel etc Cheers, David
Post #368012 29th Oct 2014 2:09pm
Happyoldgit
http://www.defender2.net/forum/topic32352.html Steve.
http://forums.lr4x4.com
Post #368020 29th Oct 2014 2:39pm
Cheshire110
^ that's why I called this thread 'a bit more info' Whistle Cheers, David
Post #368023 29th Oct 2014 2:44pm
x-isle
Calm down, it's just Autocar doing their usual dreaming and mock ups in Photoshop.
To be honest, they've not really pushed the boat out imagining this one.
They've just taken the old shape and put an Evoque front on it.
Chances are, the front will have the new LR branding style, but don't get hung up on Autocar's paint by numbers, this isn't LR's design Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #368024 29th Oct 2014 2:47pm
Merc G wagen... 'nuff said Whistle
Post #368027 29th Oct 2014 3:21pm
Happyoldgit
'Bit' being the operative word Twisted Evil Steve.
Post #368039 29th Oct 2014 4:39pm
AndrewS
Not new news the T5 platform was called T5 as they intended to make 5 models on the production line.
Clearly the Evoque is monocoque and does not have a chassis so not sure why your man stated these facts Thumbs Up
Post #368058 29th Oct 2014 6:34pm
AndrewS
Ah the old more to go wrong argument Rolling Eyes , have you proof that electronics go wrong more in the desert than they do elsewhere?
Post #368059 29th Oct 2014 6:41pm
Cheshire110
When I was in Botswana/Zambia, the savannah and roads alike were dominated by 76,78, 80 and 100 series cruisers. All of which have common rain diesels, ECUs, TC, ABS etc Cheers, David
Post #368064 29th Oct 2014 7:08pm
SS90
What proof do you need, when electronics go wrong they are generally more of a problem to fix I wouldn't want to be out in a desert if they were to go wrong would you? Why do you think the army liked the 300tdi unit?
I appreciate regulations get in the way etc. However these days everything is made to be complicated suppose they have to reason to inflate prices. Everything is designed to have a short life, everything is thrown away when finished with. Just ashame that's all.
I've got a 200tdi and it's brilliant, bullet proof what I call a proper engine. I'd have a brand new one like a shot if I could, it's taken me a lot to put an order in for a 2.2 still not sure if it's the correct decision but we'll see.
Classic example is there is no such thing called a bumper on a car now is there? It's all an integral part of the bodywork, cars are now fashion accessory items, practicalities go out of the window. I guess they call that progress Laughing
Post #368068 29th Oct 2014 7:15pm
DSC-off
Hi all,
My first post on the forum, but it's been keeping me amused and informed for year or so.
I ve got a 110 on order for 2015, figuring it'll be my last chance to buy what I want.
Anyway, as this thread and the other say, the new defender will be based on a current platform. Certainly not Freelander/Evoque, so that leaves the aluminium monocoque FFRR/RRS platform that the next full size Disco will also be on.
It's also bound to come with the same service and repair bills as those models.
I loved the photoshopped white wheels and bfg's! Still not sure about the rest of it though.
J.
Post #368069 29th Oct 2014 7:15pm
