Home > Puma (Tdci) > Narrowing down the problem-Overheating
Page 5 of 6 <123456>
Cheshire110
WelshGas wrote:
Had something similar on my 2010my 90. Scanguage started showing variable temperature readings over 72 hrs, going upto 98c but instrument pod temperature didn't move. Then on a longer journey climbing out from Symonds Yat up a longish steep hill temp went upto 105 then down to 98 . Heater on at the time and working. Then joined A road, temp climbed to 108 on Scanguage, instrument temp shot up, limp mode and pulled into layby. AA called, no coolant loss, fan seemed to be working ok, but found radiator was stone cold, although pipes were warm. Recovered home. Local Indy, that knows car, diagnosed thermostat failed closed. Replaced and all is well. Apparently not an easy job to do.
Have a new thermostat on order too, along with viscous fan and electric fan too. Sounds like my symptoms yeah, will replace one by one and see how it goes! Thanks for the tip Cheers, David
Post #331065 14th May 2014 7:52pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
When you have the vehicle upto temp, switch off and lying under front feel the radiator . Warm or cold. If cold then thermostat. If warm then probably fan. LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #331273 15th May 2014 7:00pm
Eduardo
Hi guys!
Tomorrow the viscous fan and the thermostat will be changed.
We will see what happens.
I hope that will solve my problem, if not I will be very upset with this failure Neutral
Cheers! Eduardo
Post #331494 17th May 2014 1:56am
Cheshire110
I'll be doing the same when I get back from Spain, hopefully will fix it! Cheers, David
Post #331515 17th May 2014 8:10am
Eduardo
Both pieces already changed,
According to the Indy, the viscous appear to be the problem.
The new one looks like to blow more than the old one.
We will see... Eduardo
Post #332104 19th May 2014 6:35pm
Cheshire110
Just started the thermostat before, only to be halted by thunder & torrential rain...
Fingers crossed! If not it'll be Onto the viscous tomorrow...
Any tips on how to remove the viscous fan? Cheers, David
Post #332125 19th May 2014 8:07pm
munch90
with a viscous spanner , yes there are special scanners for them , trouble is I can't remember what size it is , there are only two sizes
think 32 or 36 mm some scanners have both sizes on one spanner , halfords should do one and there not expensive
12.99 at halfords just looked and it's the double ended one so got both sizes
give spanner a sharp tap on other end with small hammer to undo , if you try doing it by hand the pulley normally just turns slipping on the belt
Post #332130 19th May 2014 8:18pm
martinfiattech
yea flipping things got a 32 and 36 sykes pickavant they always open up after a few goes, have more luck with a big chisel and hammer. Very Happy
might be a trade thing !! Excuse the spelling I`am better with spanners and wires.
Post #332132 19th May 2014 8:25pm
munch90
yes that's the trade way , I've never had much luck with the spanners yes they open up after a few , but don't like telling someone to hit there car with a hammer and chesil !
if someone slips and drops the chisel and digs a hole in there rad I don't want them saying " you tw@t you told me to do it that way !"
prefer to explain safe proper way first Laughing
got one long long chesil and that's all it's used for !
so please do it the safe proper way , don't listen to us garage cowboys Rolling with laughter Rolling with laughter Rolling with laughter
Post #332134 19th May 2014 8:31pm
Eduardo
As we said here.
When the rigth tool is not available the hammer is your best friend.
Cheers and good luck with the change DW! Eduardo
Post #332142 19th May 2014 9:06pm
Cheshire110
Perfect, thanks for all the advice as always folks! Will feedback tomorrow.. Cheers, David
Post #332145 19th May 2014 9:08pm
Cheshire110
Eduardo wrote:
As we said here.
Has yours been fixed? Cheers, David
Post #332146 19th May 2014 9:10pm
Cheshire110
Got the old thermostat off but not fitted the new one yet...
Tested the old one with hot water though, and it WASNT working... Hopefully that was it!
Will report back again tonorrow Cheers, David
Post #332177 19th May 2014 10:32pm
Whitewaitress
I've a suspicion with my thermostat - not sure it's doing it's job as it should at the moment. Are the coolant pipes rock hard all the time prior to changing and have they reduced in pressure afterwards? Possibly a bit too soon to ask you if you've not had chance for a road test.. Mine gets up to running temp (usually about 1/4 up the gauge) and when I check lately the pipes are pretty hard.
Post #332199 20th May 2014 7:23am
landy andy
1/4 up gauge!! That's low, running temp is 1/2 way.
Andy
Post #332200 20th May 2014 7:25am
