![]() | Home > Puma (Tdci) > Narrowing down the problem-Overheating |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2769 ![]() ![]() |
Have a new thermostat on order too, along with viscous fan and electric fan too. Sounds like my symptoms yeah, will replace one by one and see how it goes! Thanks for the tip Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
When you have the vehicle upto temp, switch off and lying under front feel the radiator . Warm or cold. If cold then thermostat. If warm then probably fan. LANDYWATCH
![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Hi guys!
Tomorrow the viscous fan and the thermostat will be changed. We will see what happens. I hope that will solve my problem, if not I will be very upset with this failure ![]() Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge Last edited by Eduardo on 17th May 2014 3:13pm. Edited 1 time in total |
I'll be doing the same when I get back from Spain, hopefully will fix it! Cheers, David
Both pieces already changed,
According to the Indy, the viscous appear to be the problem. The new one looks like to blow more than the old one. We will see... Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Just started the thermostat before, only to be halted by thunder & torrential rain...
Fingers crossed! If not it'll be Onto the viscous tomorrow... Any tips on how to remove the viscous fan? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 ![]() ![]() |
yea flipping things got a 32 and 36 sykes pickavant they always open up after a few goes, have more luck with a big chisel and hammer.
![]() might be a trade thing !! Excuse the spelling I`am better with spanners and wires. |
yes that's the trade way , I've never had much luck with the spanners yes they open up after a few , but don't like telling someone to hit there car with a hammer and chesil !
if someone slips and drops the chisel and digs a hole in there rad I don't want them saying " you tw@t you told me to do it that way !" prefer to explain safe proper way first ![]() got one long long chesil and that's all it's used for ! so please do it the safe proper way , don't listen to us garage cowboys ![]() ![]() ![]() |
As we said here.
When the rigth tool is not available the hammer is your best friend. Cheers and good luck with the change DW! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Perfect, thanks for all the advice as always folks! Will feedback tomorrow.. Cheers, David
Has yours been fixed? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Got the old thermostat off but not fitted the new one yet...
Tested the old one with hot water though, and it WASNT working... Hopefully that was it! Will report back again tonorrow Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Whitewaitress Member Since: 26 Nov 2013 Location: Liverpool Posts: 47 ![]() |
I've a suspicion with my thermostat - not sure it's doing it's job as it should at the moment. Are the coolant pipes rock hard all the time prior to changing and have they reduced in pressure afterwards? Possibly a bit too soon to ask you if you've not had chance for a road test.. Mine gets up to running temp (usually about 1/4 up the gauge) and when I check lately the pipes are pretty hard.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
1/4 up gauge!! That's low, running temp is 1/2 way.
Andy |
