Home > Puma (Tdci) > Narrowing down the problem-Overheating
Page 4 of 6 <123456>
landy andy
"but i wouldn't change anything."
Apart from the viscous fan, the................
Andy
Post #327107 29th Apr 2014 9:46pm
Whitewaitress
Sorry if I've missed an earlier post, but have you flushed the entire cooling system - from the expansion tank right down to the fuel cooler? And then re-filled the system as per the Ford workshop manual - topping up, running at 3000rpm for a numer of minutes, topping up above the level & so on?
Unless the coolant is filled as per the manual, and at the correct ratio my experience has proven that problems will follow. Too much water in the mixture will corrode your rad / other internals, potentially causing a blockage / too much coolant will rot the system.
Not telling you how to suck eggs here mate, just thought it was worth a mention. I flushed mine 6 times a few weeks ago - lots of crap came out until it ran completely clear, followed the workshop manual & touch wood no issues since.
Are your coolant pipes under a lot of pressure or can you squeeze them easily?
Post #327612 1st May 2014 7:16pm
Cheshire110
hi there, a point i'd not thought of...
can you point me in the direction of some instructions on how to flush the system? Does it involve draining all the coolant & replacing with new i guess? Im sure theres a sticker in the engine bay which says " Do not drain coolant! " haha... Cheers, David
Post #327644 1st May 2014 9:00pm
munch90
the manual says to vacuum fill ,
if your going to flush system ,when you refill pour coolant in slowly it helps reduce air locks
Post #327661 1st May 2014 9:19pm
landy andy
Been keeping any eye on mine since this post, and the temp never goes above 84-85c. So yours does apear permenantly hot
Andy
Post #327672 1st May 2014 9:41pm
Whitewaitress
http://www.defender2.net/forum/post324325.html
2nd post in the above link kindly supplied by dgardel - the relevant file is in the link but for the 2.2 tdci. Mine is the 2.4 but so far the jobs I've done have been broken down step by step and have been illustrated perfectly from the 2.2 manual dgardel has provided.
There's a little yellow sticker half hanging on mine which says use genuine LR coolant, probably a safe bet Laughing !!
As munch90 rightly pointed out, it does say to vacuum fill but I didn't have the tools for this & gave it a go anyway. Releasing the breather screw does help with air locks, good point on pouring slowly too - made the mistake of pouring too quick in the past Embarassed
If you are going to change, try a good coolant flush product to lift & remove any solids flowing around the system. I found the small hose from the bottom of the radiator to the fuel cooler was preventing fluid to flow when I flushed mine.
Keep us posted on your findings,
Post #327677 1st May 2014 9:46pm
Cheshire110
Ok thanks all...
First job will be fitting the replacement viscous coupling & fan I've got.. Hopefully that's it,
After that the troubleshooting gets more and more vague... Hmmm Cheers, David
Post #327679 1st May 2014 9:49pm
munch90
It definitely is getting hot, can hear the coolant boiling...[/quote]
can you hear water boiling or air bubbling up the hoses
Post #327683 1st May 2014 10:00pm
Cheshire110
99% sure boiling, readout on OBD gauge, hot smell and limp mode all agree too.. Cheers, David
Post #327685 1st May 2014 10:06pm
landy andy
Slightly off topic, but is it the same spanners to remove a Tdci fan as a Td5?
Andy
Post #327734 2nd May 2014 7:08am
Lou Sparts
Landy andy do you mean viscous fan ? If so the answer is no the Tdi is 32mm and a left hand thread and the Td5 is 36mm and right hand thread.
Hope this helps. 2005 Td5 90 XS
Steve
Post #327901 2nd May 2014 6:32pm
landy andy
Yes that is what I ment. So Big Cry Big Cry something else to get rid off as no good for me.
Andy
Post #328698 6th May 2014 12:06pm
I don't know what the answer is, but it's worth noting that whilst you asked about the Tdci, Lou's reply was about the Tdi. It could just be a typo but could also be a completely different engine. Darren
Post #328701 6th May 2014 12:34pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Had something similar on my 2010my 90. Scanguage started showing variable temperature readings over 72 hrs, going upto 98c but instrument pod temperature didn't move. Then on a longer journey climbing out from Symonds Yat up a longish steep hill temp went upto 105 then down to 98 . Heater on at the time and working. Then joined A road, temp climbed to 108 on Scanguage, instrument temp shot up, limp mode and pulled into layby. AA called, no coolant loss, fan seemed to be working ok, but found radiator was stone cold, although pipes were warm. Recovered home. Local Indy, that knows car, diagnosed thermostat failed closed. Replaced and all is well. Apparently not an easy job to do. LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #331060 14th May 2014 7:40pm
Lou Sparts
Just re read this and it was my error I read Tdci as Tdi Embarassed I have no idea about viscous fan on a Tdci. 2005 Td5 90 XS
Steve
Post #331062 14th May 2014 7:46pm
