![]() | Home > Puma (Tdci) > Puma Engine Mileage |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 390 ![]() ![]() ![]() |
23000 miles. March 2015 90xs. Every day drive and no issues at all apart from a leak from under the rear tub just behind front seats..... but sorted it myself when new
Jim_Bean Member Since: 10 May 2011 Location: Staffordshire / Shropshire border Posts: 613 ![]() ![]() ![]() |
2013 110 XS
43,000 miles Turbo hoses spilt at 800 miles and at 2400 miles. BAS silicone hoses fitted at 5000 miles. BAS map at 17000 miles - no engine issue issues. Clutch at 21,000 tho |
RlpV8 Member Since: 31 May 2014 Location: Northampton Posts: 25 ![]() ![]() ![]() |
December 2012 90 XS
33,000 miles Daily driver to work 20 miles Annual tours of Ireland once Scotland twice and most of the time a couple of hundred miles at the weekend. Only engine problem was a sensor worked it's way out of the catalytic converter. The morons at the dealer had two goes at securing it and in the process knackered the thread. Then I fixed it myself. Has a few issues that I live with but wouldn't change it for the world!! |
GAZ59 Member Since: 10 Feb 2015 Location: DARWIN Posts: 3 ![]() ![]() ![]() |
2008 110
125000 kms Northern Territory based annual trips including The Kimberley, Canning Stock Route and other trips through the centre , east and west coasts 60% sealed roads 40% dirt roads and tracks Towing an Conqueror 490 camper just had new clutch ![]() |
Rugerrog Member Since: 16 Jan 2015 Location: Derbyshire Posts: 12 ![]() ![]() ![]() |
32,000 miles
110 xs 2014 used every day commuting or logging !! oil pump recall and a (paint issue sorted) apart from that no problems , that will put the kiss of death on it ![]() with a straight 6 petrol engine ![]() |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4800 ![]() ![]() ![]() |
100000 miles
2008 SVX Roof April 1st and back on 1st of November ![]() 100% of miles done on Tarmac and loved driving everyone of them ![]() |
Bigboab123 Member Since: 03 Nov 2016 Location: Glasgow Posts: 3 ![]() ![]() ![]() |
- Mileage - 58000km
- Year make - 2012 - Body type - 110 Station Wagon -The main use of the vehicle - 100% road (so far) - No engine problems (again - so far) Life is a tangled up necklace of pearls.... |
Biancone110, a member of the italian forum africaland.it, has 320.000km 2008 2.4 Puma, completely original, including clutch.....
dgardel a very great member of africaland.it and defender2.net, a really expert (a guru), a strong man ![]() ![]() ![]() ![]() IID Pro MV License |
LRnovice Member Since: 08 May 2008 Location: Cardiff Posts: 61 ![]() ![]() |
2008 Defender SWB (or is it still called 90)
91,000miles 95% on road 5% farm tracks, crossing stubble fields etc No engine problems although heavy oil use - approx 1litre 1000 miles - reason unknown as yet. |
Landie Member Since: 21 Jun 2015 Location: WA Posts: 22 ![]() ![]() ![]() |
96000 Kms
2008 110 50% beach/off road 50% Road No issues |
John110 Member Since: 20 Nov 2011 Location: Co. Meath Posts: 106 ![]() ![]() ![]() |
189000 Kim's
2008 110 H/T Commute to work, collect parts too. Just a set of glow plugs. For those who understand, no explanation is needed... For those who do not understand, no explanation is possible |
cannondale Member Since: 26 Dec 2014 Location: carton Posts: 11 ![]() ![]() |
usually this problem,my defender just fixed it |
Check the injectors seals
http://www.defender2.net/forum/topic47727.html (as Cannondale wrote) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
