Home > Puma (Tdci) > Puma Engine Mileage |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 377 |
23000 miles. March 2015 90xs. Every day drive and no issues at all apart from a leak from under the rear tub just behind front seats..... but sorted it myself when new 2015 90 XS Santorini Black
21st Oct 2016 1:18pm |
Jim_Bean Member Since: 10 May 2011 Location: Staffordshire / Shropshire border Posts: 613 |
2013 110 XS
43,000 miles Turbo hoses spilt at 800 miles and at 2400 miles. BAS silicone hoses fitted at 5000 miles. BAS map at 17000 miles - no engine issue issues. Clutch at 21,000 tho |
21st Oct 2016 3:22pm |
RlpV8 Member Since: 31 May 2014 Location: Northampton Posts: 25 |
December 2012 90 XS
33,000 miles Daily driver to work 20 miles Annual tours of Ireland once Scotland twice and most of the time a couple of hundred miles at the weekend. Only engine problem was a sensor worked it's way out of the catalytic converter. The morons at the dealer had two goes at securing it and in the process knackered the thread. Then I fixed it myself. Has a few issues that I live with but wouldn't change it for the world!! |
30th Oct 2016 12:48pm |
GAZ59 Member Since: 10 Feb 2015 Location: DARWIN Posts: 3 |
2008 110
125000 kms Northern Territory based annual trips including The Kimberley, Canning Stock Route and other trips through the centre , east and west coasts 60% sealed roads 40% dirt roads and tracks Towing an Conqueror 490 camper just had new clutch |
30th Oct 2016 3:22pm |
Rugerrog Member Since: 16 Jan 2015 Location: Derbyshire Posts: 12 |
32,000 miles
110 xs 2014 used every day commuting or logging !! oil pump recall and a (paint issue sorted) apart from that no problems , that will put the kiss of death on it Current Landy is a 110 2.2 Puma bit different from my first one a Series 1 with a straight 6 petrol engine last one was a 2.2 puma 90 but the M4 crash barrier took care of that !!!! |
31st Oct 2016 10:28pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4792 |
100000 miles
2008 SVX Roof April 1st and back on 1st of November 100% of miles done on Tarmac and loved driving everyone of them |
7th Nov 2016 6:32pm |
Bigboab123 Member Since: 03 Nov 2016 Location: Glasgow Posts: 3 |
- Mileage - 58000km
- Year make - 2012 - Body type - 110 Station Wagon -The main use of the vehicle - 100% road (so far) - No engine problems (again - so far) Life is a tangled up necklace of pearls.... |
13th Nov 2016 10:53am |
Biancone110, a member of the italian forum africaland.it, has 320.000km 2008 2.4 Puma, completely original, including clutch.....
dgardel a very great member of africaland.it and defender2.net, a really expert (a guru), a strong man has 120.000km (180CV and 550Nm) with "only" 3 clutches (the last one is the sachs and seem fine after 60.000km) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
14th Nov 2016 8:48am |
LRnovice Member Since: 08 May 2008 Location: Cardiff Posts: 59 |
2008 Defender SWB (or is it still called 90)
91,000miles 95% on road 5% farm tracks, crossing stubble fields etc No engine problems although heavy oil use - approx 1litre 1000 miles - reason unknown as yet. |
14th Nov 2016 10:32pm |
Landie Member Since: 21 Jun 2015 Location: WA Posts: 22 |
96000 Kms
2008 110 50% beach/off road 50% Road No issues |
20th Nov 2016 12:37am |
John110 Member Since: 20 Nov 2011 Location: Co. Meath Posts: 106 |
189000 Kim's
2008 110 H/T Commute to work, collect parts too. Just a set of glow plugs. For those who understand, no explanation is needed... For those who do not understand, no explanation is possible |
20th Nov 2016 12:41am |
cannondale Member Since: 26 Dec 2014 Location: carton Posts: 11 |
usually this problem,my defender just fixed it |
25th Nov 2016 8:04am |
Check the injectors seals
http://www.defender2.net/forum/topic47727.html (as Cannondale wrote) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
25th Nov 2016 8:30am |
25th Nov 2016 8:47am |
