Home > Maintenance & Modifications > Replacement headlight harness - Highly recommended
Page 5 of 11 <123 456 ... 91011>
munch90
when I read about this on the forum I thought I would check mine out , I removed headlight left it hanging on the wires, switched them on and used a power probe to give extra power to the headlight on the connector on the back with power taken from the battery that way I could see the different amount of light ouput and giving it the extra power by switching power probe on and off giving it the extra voltage without voltage drop of defender wiring,,
really does make a big difference relaying the feeds to headlights
Post #307820 13th Feb 2014 6:21pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
So an envelope arrived from China today with my £7 eBay harnesses, great just in time for the weekend. I had ordered four sets, using separate ones each side for me and StephenO. Very Happy Very Happy
My excitement was short lived though........ This was what turned up
Awaiting a response now, will see what happens. Sad Sad 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #309968 20th Feb 2014 4:04pm
Tiger
Mine turned up this week also.
Here's a photo help you compare Whistle
They look well made and although I ordered 2 I think I'll only use one. I'll swap the relays though.
Thumbs Up
Post #309969 20th Feb 2014 4:10pm
Dave T
You can really go off people............ Very Happy 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #309971 20th Feb 2014 4:12pm
Dave T
Had a good sounding response from the seller, hopefully be sorted out, just another few weeks no doubt. 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #310134 21st Feb 2014 6:56am
ericvv
Is everybody who recently have installed this upgraded loom from Landreiziger, Holland happy with the end result?
I also bought this loom, and the truck goes later this week to the dealer for some maintenance and other warranty work, and they also intend to install this loom then. I showed the Landreiziger loom to them earlier today, and they say that the only thing that needs to be done is to extend the permanent live cable, so that power can be taken directly from the battery.
Tks, Eric You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #316613 17th Mar 2014 1:37pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
Why do you want to extend to the battery if you have already a permanent live on the starter motor and altenator? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #316652 17th Mar 2014 5:37pm
mk1collector
Mine went straight to the alternator
Post #316670 17th Mar 2014 6:19pm
ericvv
Hi Roel, mk1,
It was a bit of a rush rush discussion abt this loom at the dealer today amidst of talking about a bunch of other jobs they will have to do this wed-fri.... May well be that the battery connection was even brought up by myself, so wednesday I will mention the alternator and starter motor connections you mention here.
Just one thing, I want to be able to turn at least the sidelights on without having the key in the contact, so hope that the live to the alternator indeed is a permanent live. I guess the starter motor live is not really permanent, only comes on with the key in/contact on, no?
Post #316673 17th Mar 2014 6:29pm
mk1collector
My sidelights can stay on without the key in the ignition
Post #316674 17th Mar 2014 6:37pm
Dave T
Still waiting on my harnesses, they were supposed to have been resent Sad Sad 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #316681 17th Mar 2014 7:09pm
ericvv
So truck came back from the dealer friday with the "Landreiziger" headlights loom installed. They made one change, in order to be sure to have a good earth, they cut and extended the black earth wire, and connected it as in below picture, believe that is on top of the airco compressor.
Dealer mechanics commented that this loom indeed is a good solid piece of kit, and when I mentioned the price to them they were very surprised. (certainly as they are used to Swiss prices Laughing)
So I guess I will never have the use the spare light switch which I bought together with the loom from Landreiziger as a package deal. Goes in the spare parts storage. Thumbs Up
Eric
Post #318261 23rd Mar 2014 6:21am
Merlin
Not only you DaveT who didn't get their harness. I ordered mine in January (and paid) and then when I complained in March the vendor said he would send a "replacement" harness. This arrived in a week. I had to wait as fleebay said the order was still within timescale as the vendor kept moving the delivery date.
Oddly the wiring only allows either the dip or full beam on at once. Whereas the standard set-up is that you can 'flash' while on dip and have all 210 watts showing. This is different but is it a bad thing?
Merlin
Post #320296 30th Mar 2014 5:49pm
Dave T
I am still waiting Crying or Very sad Crying or Very sad 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #320309 30th Mar 2014 6:23pm
munch90
Merlin
should all work the same if triggers are taken from original wiring
Post #320320 30th Mar 2014 6:57pm
