Page 553 of 1383 <123 ... 552553554 ... 138113821383>
Don't worry he's got a Waxoyled Indiana Jones hat for that. Whistle
Rolling with laughter Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #261043 24th Aug 2013 7:44pm
GUM97
If I'd had that on Steve I'd have been saved from Waxy hair! Rolling with laughter An engine to TDi for!
Post #261048 24th Aug 2013 7:56pm
excossack
Finally finished off replacing all brake pipes with new copper ones and replaced the flexi pipes with new braided steel ones.
A few minor tweaks to the front flexi pipes as I wend for +2" inch extra for when I replace the springs with HD ones. So I used the plastic spring thing from the old flexi pipes and put it on the new ones. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #261117 25th Aug 2013 8:40am
TheWarden
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Fitted Rammount Cupholders. I mounted the bases on the side of the cubby box with long extension arms. That should stop the kids whining about not having anywheree to put their Starbucks....
 2013 Aintree Green 110 Station Wagon SX
Post #261125 25th Aug 2013 9:03am
excossack
Hope there is a drip tray being right above an amp ? 1999 Defender TD5 110
Regards
John M0VAZ
Post #261131 25th Aug 2013 9:20am
excossack
After finding the original OEM connectors for the radio, I got them plugged into the radio and and also re-wired the speakers into the original LR loom 1999 Defender TD5 110
Regards
John M0VAZ
Post #261158 25th Aug 2013 12:29pm
TheWarden
Fear not - they are easy to relocate when in use. This is their not in use storage position. I also have window mounts that they can be relocated to..... 2013 Aintree Green 110 Station Wagon SX
Post #261162 25th Aug 2013 12:43pm
diesel_jim wrote:
Rebuilt the front calipers for the 110. l shiney new pistons, freshly shotblasted and painted caliper pieces, nice new seals with red grease.
look too good to use now! Cool Cool
Some pics of the brakes:
Freshly painted
Old ones coming off (ex salisbury front axle, extra HD brakes. apparently designed for slowing 7 tonnes of 110 desert patrol vehicle!)
Can you tell which side i've done yet?
Might have time to get out this afternoon and finish the N/S. needs new bearings on that one as well. Got them all ready to go in.
Post #261182 25th Aug 2013 3:39pm
Nice job Jamie ( as usual It's what's under the skin that counts ) Thumbs Up
Although in the spirit of defender2 you should have sprayed them yellow or red Thumbs Up
Post #261194 25th Aug 2013 4:37pm
dgardel
Italy
Goog job, but..................
the salisbury brake should be better than standard.....
or not? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #261212 25th Aug 2013 5:26pm
Yes, in theory, but my 110 doesn't weigh anywhere near like what these brakes are designed for, and there's a couple of sticking pistons in them, so I thought i'd just rebuild some standard calipers (and I had a brand new set of vented discs) and swap the over.
I have some new seals, so I'll rebuild these salisbury brakes with them. Will probably sell them on; I have a second set of discs as well, so they'll be ideal for someone with a higher performance 90/110. I had these on my old 90 and they were awesome! especially with 35" tyres, no brake fade at all.
Post #261214 25th Aug 2013 5:47pm
Offroad-Tec
Germany
Hi Lift bracket for HD bonnet hings
Hello,
mounted the new Hi Lift brackets for the HD bonnet hinges.
Markus
Post #261215 25th Aug 2013 5:51pm
ericvv
Re: Hi Lift bracket for HD bonnet hings
Offroad-Tec wrote:
Hello,
Markus
Markus, is putting your high lift in that position legal in Germany?
Best, Eric You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #261222 25th Aug 2013 6:02pm
Seems a very impractical position - not the easiest position to lift a jack on and off and can only end in tears when not if the bonnet and/or wing get gouged...
Post #261227 25th Aug 2013 6:35pm
Offroad-Tec
Germany
HiLift bracket
@eric
Hello,
I carry the hi lift in a neoprene bag, the base plate and the top clamp aren't mounted. On the photo you can see the "big" hi lift. I only carry the hi lift for offroad-use and for advertising, not for the ice cream shop. There are other possibilities to carry a hi lift, in the car with universal-brackets, on our roof racks with especially brackets, .....
In Germany you can carry the hi lift on such a bracket, because it's freight. In the neoprene-cover it is protected.
Greetings -Markus
Post #261231 25th Aug 2013 6:46pm
