If I'd had that on Steve I'd have been saved from Waxy hair!
![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5940 ![]() ![]() ![]() |
Finally finished off replacing all brake pipes with new copper ones and replaced the flexi pipes with new braided steel ones.
A few minor tweaks to the front flexi pipes as I wend for +2" inch extra for when I replace the springs with HD ones. So I used the plastic spring thing from the old flexi pipes and put it on the new ones. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
TheWarden Member Since: 25 Feb 2013 Location: Southampton Posts: 179 ![]() ![]() ![]() |
Fitted Rammount Cupholders. I mounted the bases on the side of the cubby box with long extension arms. That should stop the kids whining about not having anywheree to put their Starbucks....
![]() Click image to enlarge 2013 Aintree Green 110 Station Wagon SX |
Hope there is a drip tray being right above an amp ? 1999 Defender TD5 110
After finding the original OEM connectors for the radio, I got them plugged into the radio and and also re-wired the speakers into the original LR loom 1999 Defender TD5 110
Fear not - they are easy to relocate when in use. This is their not in use storage position. I also have window mounts that they can be relocated to..... 2013 Aintree Green 110 Station Wagon SX |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6170 ![]() ![]() ![]() |
Some pics of the brakes: Freshly painted ![]() Click image to enlarge ![]() Click image to enlarge Old ones coming off (ex salisbury front axle, extra HD brakes. apparently designed for slowing 7 tonnes of 110 desert patrol vehicle!) ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Can you tell which side i've done yet? ![]() Click image to enlarge ![]() Click image to enlarge Might have time to get out this afternoon and finish the N/S. needs new bearings on that one as well. Got them all ready to go in. |
Nice job Jamie ( as usual It's what's under the skin that counts )
![]() Although in the spirit of defender2 you should have sprayed them yellow or red ![]() |
Goog job, but..................
the salisbury brake should be better than standard..... or not? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Yes, in theory, but my 110 doesn't weigh anywhere near like what these brakes are designed for, and there's a couple of sticking pistons in them, so I thought i'd just rebuild some standard calipers (and I had a brand new set of vented discs) and swap the over.
I have some new seals, so I'll rebuild these salisbury brakes with them. Will probably sell them on; I have a second set of discs as well, so they'll be ideal for someone with a higher performance 90/110. I had these on my old 90 and they were awesome! especially with 35" tyres, no brake fade at all. |
Offroad-Tec Member Since: 28 Jul 2012 Location: Damshagen/ Baltic Sea Posts: 58 ![]() ![]() |
Hello,
mounted the new Hi Lift brackets for the HD bonnet hinges. Markus ![]() Click image to enlarge |
Markus, is putting your high lift in that position legal in Germany? Best, Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Seems a very impractical position - not the easiest position to lift a jack on and off and can only end in tears when not if the bonnet and/or wing get gouged...
@eric
Hello, I carry the hi lift in a neoprene bag, the base plate and the top clamp aren't mounted. On the photo you can see the "big" hi lift. I only carry the hi lift for offroad-use and for advertising, not for the ice cream shop. There are other possibilities to carry a hi lift, in the car with universal-brackets, on our roof racks with especially brackets, ..... In Germany you can carry the hi lift on such a bracket, because it's freight. In the neoprene-cover it is protected. Greetings -Markus |
