Home > My Defender > What Did You Do In Your Defender Today |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1747 |
Removed rear prop and pumped grease into UJs. On end ok the other has full movement, but grease not getting to the furthest bearings from grease nipple. So got hold of some GKN UJs ready when theystart to cause issues.
Found a small weep from rear output seal on T/fer box so purchased a new one and replaced. Click image to enlarge Then replaced the output seal on rear salisbury axle which has been leaking for some time. Again with Genuine seal. Click image to enlarge Click image to enlarge Then refitted prop with new bolts and nuts and took for a test drive. Thankfully job well done as no leaks after a good run Last edited by Romadog on 25th Jan 2016 8:05pm. Edited 1 time in total |
24th Jan 2016 7:26pm |
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 613 |
Drove 350 miles to see some flat coated retriever puppies in Ipswich.
Defender was brilliant and apart some rough patches on the A12, ride was smooth and comfortable. |
24th Jan 2016 7:40pm |
PCA42 Member Since: 15 Jun 2014 Location: Church Stretton Posts: 468 |
I have been getting a load of jobs done to my 110 that I've been wanting to do for a while...
First of all I've installed my front and rear Anderson connector harness (from Goodwinch) to allow the use of my detachable winch set up at either end of the vehicle (or jump leads etc): Click image to enlarge Click image to enlarge I also changed the wheels from the original Boosts to black 'Wolf' wheels (detailed more in the Wolf wheel thread about the balancing issues! ). Click image to enlarge I also removed the Tomb Raider side steps in preparation for my rock siders arriving next week... The steps will be for sale in the For Sale section soon if anyone is interested. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Pete 2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
24th Jan 2016 9:07pm |
John110 Member Since: 20 Nov 2011 Location: Co. Meath Posts: 106 |
Looks great david For those who understand, no explanation is needed... For those who do not understand, no explanation is possible |
24th Jan 2016 9:13pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17206 |
Winched a very stuck Toyota Hilux out of a field full of wallabies.
Always nice when you have to help the Japanese. |
24th Jan 2016 10:57pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5815 |
Got the rear chassis primed and painted after having the x-member replaced. Looks better with a coat of black paint than bare metal.
MOT time tomorrow 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
25th Jan 2016 6:47pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1762 |
Pulled the engine out over the weekend, then degreased the engine bay and dinitrolled all the bits of chassis I could get to easily!
New engine going in next weekend! |
25th Jan 2016 7:30pm |
Rock sliders on
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Pete 2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
25th Jan 2016 7:46pm |
Picked up the 110 from MOT - passed. One advisory - Oil leak (suspect this to be the half moon at the rear of the rocker cover) 1999 Defender TD5 110
26th Jan 2016 4:51pm |
Fitted new Wipac Crystal head lights. They do look nice
Now I need some darkness to test them 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
27th Jan 2016 4:37pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20114 |
You will like them, did you fit upgraded bulbs too?
27th Jan 2016 8:36pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10676 |
Hi excossack, have you got some before/after pic's if possible, im still not sure which way to go for upgrading my headlights and your thoughts on your test night drive, many thanks
Clayton. |
27th Jan 2016 9:40pm |
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 559 |
I'm very happy with the performance of the Wipac Crystals, I've got Osram Night Breaker bulbs in as well to get the most out of them I'm sure you'll be happy with them.
27th Jan 2016 10:02pm |
I've got Crystals but Philips Extreme, what ever brand you go for it'll be better.
27th Jan 2016 11:01pm |
