Home > Maintenance & Modifications > Soundproofing a Defender
Page 7 of 9 <123456789>
Appleby
United Kingdom 2002 Defender 90 Td5 CSW Epsom Green
Just thought I'd stick up my progress with this too. I'm doing my Td5 90 with Dynamat Extreme and Dynaliner. I had to take out the headlining recently so I thought I would start with the roof.
Roof cleaned ready for dynamat
Dynamat
Dynaliner
I used the rest of the bulk pack to do the floor of the tub and the rear door which now shuts with a real thud rather than a clang!
I'm hoping that as well as reducing noise, it will also add some insulation as my landy gets very hot in summer and very cold in winter. Looks like I'm going to need at least another bulk pack as I intend to do the rest of the roof/tub/seat boxes etc.
Post #257086 7th Aug 2013 8:00pm
Killer90
Site Sponsor
That looks a very neat job , Thumbs Up well done
This was this weeks job at the CSK workshop 13 plate 110 xs in for the full works
 CSK Automotive
www.cskautomotive.co.uk
Post #257108 7th Aug 2013 9:25pm
Appleby
Cheers , how much Dynamat does it take to do an entire 110 then?
One more question, when you do the roof/doors do you remove the original land rover sound deadening or just go over it?
Post #257111 7th Aug 2013 9:29pm
Killer90
Site Sponsor
Usually get through 3-4 boxes for a complete job like this, it had dynaliner to footwells and gearbox aswell. When i soundproof the doors i cut a square sheet and tuck it in and go over the lr orignal "thing" Laughing they put on. Then heat the dynamat up with a heat gun and work the edges into the orignal lr stuff so theres no gaps Thumbs Up Thumbs Up CSK Automotive
Post #257113 7th Aug 2013 9:32pm
Very naughty! Where are those gloves! You'll end up in A&E with severe cuts like that. Never forget protection! Whistle
Rolling with laughter Rolling with laughter No Guts, No Glory.
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #257114 7th Aug 2013 9:35pm
Killer90
Site Sponsor
I just brought a set of Mechanix gloves, that dynamat is lethal and i never learn Rolling with laughter
p.s this is not sarcasm im telling the truth Laughing CSK Automotive
Post #257115 7th Aug 2013 9:40pm
Well just be careful the H&S experts will give you a detailed explanations of the severe implications of your actions.... Laughing
Still they will tell you next every time you go out for a drive you may not come back again. Shocked No Guts, No Glory.
Post #257119 7th Aug 2013 9:45pm
Pickles
CSK..Top job.
Carpet as well.....Who supplied the carpet?....I'd like to see an image of the finished item..cabin, seat boxes, & rear, if possible.
Cheers, Pickles.
Post #257125 7th Aug 2013 9:59pm
smb
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Hi Appleby,
My 110 took 3 Dynamat Extreme Bulk packs with very little wastage and have gone through three rolls of Dynaliner, but will need another two at least with zero wastage. The problem with it is that after you've done the floors, doors, ceiling etc you start trying to find other places to put it Whistle
If I got another bulk pack I'd find somewhere to put it.
It probably works out cheaper to get Chris(cask) to do it. Def a lot less hassle!!
Steve
Post #257143 7th Aug 2013 10:59pm
Appleby
Yeah, I reckon my 90 is gonna take 3 bulk packs before it's done. I'm also going to do the whole roof in Dynaliner 1/4" and will probably fill the doors with 1/8" on top of dynamat. I'm also after peoples opinions on dynapad. I'm after a covering for the floor/bulkhead to remove road/engine/exhaust noise and try and keep the heat/cold out (keep the missus happy!).
I've done another car before (landy is alot easier to work on, not many trim panels to remove) and I can vouch for wearing gloves. I didn't notice while I was doing it but I ended up with lots of little slices all over my hands so I was more careful this time!
Post #257146 7th Aug 2013 11:13pm
Cheshire110
How much do you charge Chris? It's a 110 Utility XS.. Cheers, David
Post #257155 7th Aug 2013 11:52pm
SGH
Nice job you are doing on you 110 Thumbs Up I thought of using Dynapad on the floor in my 130 trouble is as it's no a closed cell foam so would soak up any water leaks.
Post #257171 8th Aug 2013 6:54am
Killer90
Site Sponsor
David- varies matey from £900.00 upwards depending on the coverage etc Thumbs Up CSK Automotive
Post #257179 8th Aug 2013 7:31am
Cheshire110
Ok cheers, will start saving up my £s! Looks a dead good job you do! Cheers, David
Post #257183 8th Aug 2013 7:38am
Killer90
Site Sponsor
Cheers Thumbs Up
Your more than welcome to pop down when the next one is in for it and have a try before you buy Rolling with laughter Thumbs Up CSK Automotive
Post #257184 8th Aug 2013 7:41am
