Home > Maintenance & Modifications > Soundproofing a Defender
Page 8 of 9 <123456789>
Cheshire110
Killer90 wrote:
Cheers Thumbs Up
Your more than welcome to pop down when the next one is in for it and have a try before you buy Rolling with laughter Thumbs Up
That's a nice offer, thanks! I'll get in touch next time I'm 'daaan saaaath' Cheers, David
Post #257187 8th Aug 2013 7:53am
Appleby
United Kingdom 2002 Defender 90 Td5 CSW Epsom Green
SGH wrote:
I thought of using Dynapad on the floor in my 130 trouble is as it's no a closed cell foam so would soak up any water leaks.
In that case I will probably give it a miss! Water leaks and landrover and all that!
Post #257200 8th Aug 2013 9:43am
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Where did you buy the 10mm closed cell foam?
Les Brock wrote:
Just lined my roof with 3mm Butyl sound deadening and insulated with this stuff, 10mm closed cell foam is it worth adding another layer ?
Only used about half the roll and I have aanother full roll as well
waiting for alloy tape to seal it all up
Regards
Les
Post #264498 7th Sep 2013 8:38pm
Hazza
United Kingdom 1990 Defender 110 Td5 HT Bronze Green
Les, can I ask where you got the 3mm butyl sound deadening from? Cheers 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #265257 10th Sep 2013 5:20pm
Les Brock
This
2.2mm Butyl with alloy its 3mm
http://www.ebay.co.uk/itm/Alubutyl-2-2mm-2...415d95b3ee
From Germany was here in 5 days cheapest I could find it
Regards
Les
Post #265266 10th Sep 2013 5:36pm
Les Brock
Here ...
http://www.ebay.co.uk/itm/8m-x1m-FOIL-FOAM...3384c8563b
Regards
Les
Post #265270 10th Sep 2013 5:40pm
Hazza
Thanks Les...payday never comes fast enough! 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #265511 11th Sep 2013 8:05am
Windyhill
United Kingdom 2013 Defender 110 Puma 2.2 USW Corris Grey
Hi
Am new to this forum, and this may have been covered. I have just replaced my 2010 90 XS CSW with a 110 Utility XS as owing to my growing family, the 4 seat 90 was no longer practical. LR no longer fit carpets to them, which am sure is a cost cutting measure so the first thing I noticed was how much noisier the 110 was over my 90. I ordered and fitted a noise killer kit this aft, and if I'm being honest haven't noticed a huge amount of difference.
There are a lot of areas which don't have any protection, including most of under the front seats, the rear of the front seat box and areas under the rear seats. Is it worth me getting some dynamat xtreme and some tape to fill in the gaps or are my expectations a bit high? Whilst I'm at it, I was thinking I may as well do the roof and doors which isn't covered with noise killer kit.
The other thought I had would be to rip out the noisekiller kit altogether and start again with the Dynamat?
With regard to carpets, has anyone any experience of the exmoor kits? I see the CSK lads have fitted the LR ones and have yet to price these up but expect them to be a lump.
Post #285191 25th Nov 2013 7:36pm
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
Les Brock wrote:
geobloke wrote:
That is a great job you have done there Les. I doubt a second layer is going to do very much more for you than the first has already. Can you use the extra roll anywhere else in your 90?
Yes still got the sides to do, tub etc but didnt use as much as I thought I would Laughing
Regards
Les
how do find it is it working
Post #285470 26th Nov 2013 7:40pm
mark_d
As some one who has fitted Dynamat Extreme to all but one of my cars over the last 13 years and now having switched to Silent Coat for the 90, I would have no problem recommending Silent Coat as a more cost effective alternative. If there is a difference, it's nominal.
My 90 had the Noise Killer kit fitted when I bought it and I wasn't overly impressed with it, so I added lots of silent coat dampening material and acoustic foam, with good effect.
I haven't completed the sound proofing but having done the rear tub and door, there is a noticeable improvement.
The measured difference isn't really any lower because the engine ad gearbox seem to dominate, but there was a reduction in noise coming from the back and sides.
The soundproofing work I have done so far is detailed in the link in my signature.
EDIT: Maybe better to add direct links
http://defender90xs.blogspot.co.uk/2013/06...age-1.html
http://defender90xs.blogspot.co.uk/2013/06...-door.html
http://defender90xs.blogspot.co.uk/2013/06...r-tub.html http://defender90xs.blogspot.co.uk/
Post #285494 26th Nov 2013 8:34pm
Pickles
mark d..very professional job mate.
Cheers, Pickles.
Post #285512 26th Nov 2013 9:10pm
tolley
where have you found the best price for it?
Post #285514 26th Nov 2013 9:13pm
Windyhill
Cheers Mark d
Had a look at your sound deadening and think my best route is to order some silent coat and apply it to the doors, under the noise killer kit, all the areas not covered by the noise killer kit and possibly the roof. Biggish job on.
Did the carpet fit ok on top of it all?
Thanks again.
Post #285525 26th Nov 2013 9:34pm
mark_d
I got mine off ebay, it comes from Car Audio Direct who charge silly postage to get it across to this part of the UK when bought direct from them but give free postage when bought through the auction site they have to pay fees to Confused http://defender90xs.blogspot.co.uk/
Post #285530 26th Nov 2013 9:40pm
mark_d
Windyhill wrote:
Cheers Mark d
Thanks again.
Hi Windyhill, the carpet went back OK. The Silent Coat didn't make much difference and the Noise Killer was already in when I bought it. I can take some close up photos of particular areas if you want to see finer detail. I think the only real area worth noting was the metal trim at the rear door sitting slightly higher at the front (inside) edge.
I'm hoping to do the roof and sides when the weather warms up but I think the biggest difference will come with the bulkhead and foot wells. http://defender90xs.blogspot.co.uk/
Post #285534 26th Nov 2013 9:46pm
