Home > Maintenance & Modifications > Soundproofing a Defender |
superspoons Member Since: 16 Apr 2012 Location: Herts Posts: 314 |
After doing the floor / arch's of my 110 last weekend.... once it goes down, I can't see you getting it up easily. Not a bad thing of course but just a warning to get it right first time Cheers, Superspoons |
7th May 2013 2:32pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
Gavin- I cut a square sheet and stuck it in place of the LR cheap sound deadening then i just done little bits on the shaped parts of the metal piece mainly to stop vibration You can plonk it on how you liek as it will do the same job just i like to keep it neat CSK Automotive
www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
7th May 2013 4:38pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
Quick Q - how much space is there between the door card and the inner panel. Could you fit acoustic foam in between? BM52
7th May 2013 5:47pm |
Cheers Chris - doors to do after the roof Cheers, Superspoons |
7th May 2013 6:00pm |
Luismi Member Since: 04 Nov 2010 Location: Cotswolds Posts: 178 |
Click image to enlarge Click image to enlarge Click image to enlarge HTH |
7th May 2013 7:43pm |
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 |
Been reading this thread with interest as about to sound proof my td5 double cab. Really it's getting rid if the wet naff carpet with the wright off road kit to smarten it up and improve practicability front and rear so seats etc has to come out.
The sound proofing is a welcome benefit however after reading this wondering if I should dynamat as well if so where and how much. I realise its a where do you stop however interested to see what people think would be reasonable and worth while without spending a fortune (I already have on the matting) |
7th May 2013 8:14pm |
I would say soundproof the front floor and seat box, also the middle row floor and seat box, a bit on the door inners and job done You could always go for Dynadeck instead of carpet as it doesnt absorb water and have a nice grained finish to it CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
7th May 2013 8:18pm |
Pretty much all of it then How much would I need for this? Think it would be dynamat as have already bought the wright off road kit |
7th May 2013 8:50pm |
I would say 1 pack if you measure it out correctly CSK Automotive
7th May 2013 9:07pm |
pesto_trader Member Since: 26 Jun 2013 Location: Oslo Posts: 148 |
Nice job! Im doing my 90 td5 at the moment. I have just removed the panel on the front door on the drivers side. Should i take off the plastic insulation or just cover the door as it is now?
15th Jul 2013 8:00pm |
thank you, strip off the original door shredder and you can replace it with Dynaliner or take it off carefully, dynamat behind and replace CSK Automotive
15th Jul 2013 8:37pm |
Les Brock Member Since: 20 Mar 2012 Location: Stroud, Glos Posts: 152 |
Just lined my roof with 3mm Butyl sound deadening and insulated with this stuff, 10mm closed cell foam is it worth adding another layer ?
Click image to enlarge Click image to enlarge Click image to enlarge Only used about half the roll and I have aanother full roll as well waiting for alloy tape to seal it all up Regards Les Last edited by Les Brock on 5th Aug 2013 8:39am. Edited 1 time in total |
5th Aug 2013 8:30am |
That is a great job you have done there Les. I doubt a second layer is going to do very much more for you than the first has already. Can you use the extra roll anywhere else in your 90?
5th Aug 2013 8:37am |
Yes still got the sides to do, tub etc but didnt use as much as I thought I would Regards Les |
5th Aug 2013 8:41am |
