Home > Maintenance & Modifications > Soundproofing a Defender |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
That looks a very neat job , well done
This was this weeks job at the CSK workshop 13 plate 110 xs in for the full works Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
7th Aug 2013 9:25pm |
Appleby Member Since: 03 Apr 2012 Location: Bristol Posts: 74 |
Cheers , how much Dynamat does it take to do an entire 110 then?
One more question, when you do the roof/doors do you remove the original land rover sound deadening or just go over it? |
7th Aug 2013 9:29pm |
Usually get through 3-4 boxes for a complete job like this, it had dynaliner to footwells and gearbox aswell. When i soundproof the doors i cut a square sheet and tuck it in and go over the lr orignal "thing" they put on. Then heat the dynamat up with a heat gun and work the edges into the orignal lr stuff so theres no gaps CSK Automotive
7th Aug 2013 9:32pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20453 |
Very naughty! Where are those gloves! You'll end up in A&E with severe cuts like that. Never forget protection! No Guts, No Glory. 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
7th Aug 2013 9:35pm |
I just brought a set of Mechanix gloves, that dynamat is lethal and i never learn
p.s this is not sarcasm im telling the truth CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
7th Aug 2013 9:40pm |
Well just be careful the H&S experts will give you a detailed explanations of the severe implications of your actions....
Still they will tell you next every time you go out for a drive you may not come back again. No Guts, No Glory. 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
7th Aug 2013 9:45pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3785 |
CSK..Top job.
Carpet as well.....Who supplied the carpet?....I'd like to see an image of the finished item..cabin, seat boxes, & rear, if possible. Cheers, Pickles. |
7th Aug 2013 9:59pm |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
Hi Appleby, My 110 took 3 Dynamat Extreme Bulk packs with very little wastage and have gone through three rolls of Dynaliner, but will need another two at least with zero wastage. The problem with it is that after you've done the floors, doors, ceiling etc you start trying to find other places to put it If I got another bulk pack I'd find somewhere to put it. It probably works out cheaper to get Chris(cask) to do it. Def a lot less hassle!! Steve |
7th Aug 2013 10:59pm |
Yeah, I reckon my 90 is gonna take 3 bulk packs before it's done. I'm also going to do the whole roof in Dynaliner 1/4" and will probably fill the doors with 1/8" on top of dynamat. I'm also after peoples opinions on dynapad. I'm after a covering for the floor/bulkhead to remove road/engine/exhaust noise and try and keep the heat/cold out (keep the missus happy!).
I've done another car before (landy is alot easier to work on, not many trim panels to remove) and I can vouch for wearing gloves. I didn't notice while I was doing it but I ended up with lots of little slices all over my hands so I was more careful this time! |
7th Aug 2013 11:13pm |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2760 |
How much do you charge Chris? It's a 110 Utility XS.. Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
7th Aug 2013 11:52pm |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 |
Nice job you are doing on you 110 I thought of using Dynapad on the floor in my 130 trouble is as it's no a closed cell foam so would soak up any water leaks. |
8th Aug 2013 6:54am |
David- varies matey from £900.00 upwards depending on the coverage etc CSK Automotive
8th Aug 2013 7:31am |
Ok cheers, will start saving up my £s! Looks a dead good job you do! Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
8th Aug 2013 7:38am |
Your more than welcome to pop down when the next one is in for it and have a try before you buy CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
8th Aug 2013 7:41am |
