Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats
Page 10 of 81 <123 ... 91011 ... 798081>
mk1collector
Thank you Thumbs Up
Post #351258 12th Aug 2014 5:15pm
mk1collector
Well a hectic week but some things turned up today Mr. Green
First off middle row tinted windows. I had to call a favour in from a mate to bond the fixings to the window as they didn't come on the glass Big Cry so they're setting as we speak and I'll build up the doors tomorrow.
Also my almost new genuine seat covers that I won on ebay far too cheap turned up Whistle the fronts are already fitted and the middle row will go in when the windows have been fitted.
Lastly the wind deflectors will get fitted even though one is broken at the end, but that will have to get sorted after my hols Mr. Green
I'll put pics of the built up finished job tomorrow or the day after Thumbs Up
Cheers for looking
Ray
Post #351430 13th Aug 2014 5:23pm
mk1collector
In holiday mode, with middle row windows, wind deflectors and seat covers fitted. Only needs a wash and filling with fuel before we go now. Roof box also fitted for more space Rolling Eyes
Ray
Post #351605 14th Aug 2014 4:33pm
mk1collector
Well we made it there and back without being recovered this time Rolling with laughter although there is definately something wrong Big Cry the vibration is annoying at about 50 to 60 and there's a lack of power so I need to do some checks this week.
I think we brought back more bugs and sand on the defender than there was at the place we stayed Laughing
I gave it a good wash off this morning to get rid of as much salt as I could!
Unfortunately we missed a show while on holiday that could have been interesting
We only saw the poster in the supermarket after the event Neutral
Anyway I'll post about my findings on the running problem and I've got a couple of thing I want to do before winter too.
Ray
Post #353413 24th Aug 2014 4:07pm
mk1collector
I think I've found the lack of power as there was oil at the ecu plug again Rolling Eyes so I'll order a new injector loom when everything opens again after the bank holiday, but the vibration is still there so more to check when the weather is good.
Ray
Post #353460 24th Aug 2014 11:16pm
Tiger
Ray, mine had a vibration between 50-60
Turned out to be the handbrake was just a touch over adjusted, very slight bind revealed itself at those speeds as a noticeable vibration which went away at 70!
When they serviced it did they adjust the handbrake up a turn or two?
Matt
Post #353468 25th Aug 2014 6:19am
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
I put silicone in the top of the plugs when I fitted my harness. It was a britpart one, but has been good for 18 months now. I don't know whether this is a known way to slow down the ingress but it seems to have worked for me. Most silicones are oil resistant I think, but it will say on the tube. 2002 110 td5
Post #353474 25th Aug 2014 7:40am
pob1968
Just a thought on people running into your truck, my mate has a Bonnatti Grey 130 dccpu and it has been ran into in our car park at work three times in two and a half years, all stating they didnt see it!
Maybe its a Bonnatti Grey thing Shocked 110 Hardtop
Post #353476 25th Aug 2014 8:12am
barbel jim
I change the injector harness every 2 years regardless. prevention is better than cause, especially as its only a couple of £. I onle ever use genuine......... trust the blue wrapper Rolling with laughter Rolling with laughter
Post #353478 25th Aug 2014 8:27am
TD5_dan
2001 Defender 110 Td5 CSW Java Black
Ray have you painted or powder coated the aluminium tread on your side steps black if so did you remove it to do it? 2001 TD5 110 County Station Wagon - sold
1970 Series 2A Station Wagon
1970 Series 2A hard top
1960 Series 2
1972 Series 3
Post #353494 25th Aug 2014 9:06am
mk1collector
Matt
I'll try backing the handbrake off a little but they definately didn't adjust it in the service. My vibration calms down a bit above 70 too so I'll try it Thumbs Up
Post #353511 25th Aug 2014 10:38am
mk1collector
I don't suppose you have any pics of where to put the silicon? I replaced the harness last year but it's back already!
Post #353513 25th Aug 2014 10:43am
mk1collector
That's exactly what the young lad said who hit me the first time! Shocked I even had my lights on so you'd think he couldn't miss me!
Post #353514 25th Aug 2014 10:45am
mk1collector
I changed it last year but I've changed the oil 3 times since then for various reasons so with the oil being so new it might be more escapeable Rolling with laughter
Post #353515 25th Aug 2014 10:47am
mk1collector
It's been zinc coated then powder coated. The steps were starting to rust so I took them off ground them back had them sand blasted then zinc coated and powder coated and the chequer was done at the same time. Thumbs Up
Post #353518 25th Aug 2014 10:50am
