Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats
Page 3 of 81 <123 4 ... 798081>
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Where about a in France are you going?
Post #259777 19th Aug 2013 8:42am
mk1collector
Good to hear you had an uneventfull (landy problem wise) trip hopefully ours will be the same Mr. Green we're off to south Brittany on the coast somewhere i can't remember the town name but the misses has it somewhere I hope Rolling with laughter I've still got a couple of bits to do before we go if bits arrive Big Cry
Post #259821 19th Aug 2013 10:47am
Jimb1978
A beautiful area of France. I have just filled up. 23.62 mpg at 70mph.
Some pictures and recommendations of where to stay would always be appreciated. Once I get organised I will do the same.
Have a good un
Jim
Post #259888 19th Aug 2013 2:55pm
mk1collector
I've not checked my mpg lately but since taking the rack off and getting the head done I'm defeinately getting more miles per tank. When I'm back ill post up the findings good or bad from the hols Thumbs Up
Post #259987 19th Aug 2013 11:12pm
mk1collector
Fitted the rear tinted sliding windows from masai.
No fitted pics yet as the last one was fitted a bit late, ill decide which other tinted ones I want after I get back from hols but at least there shouldn't be any rattling on the journey now.
A word of warning on the window fitting though, the windows aren't a direct replacement for original Landrover sliders so a bit of filing is involved. Also don't buy the rivets to hold in the windows from masai as they aren't capped and when informed they didn't know what capped rivets were so I had to send then pictures and a description pointing out that the ones they supply will let water into the vehicle Rolling Eyes still waiting on acknowledgement and a refund.
Post #259990 19th Aug 2013 11:28pm
mk1collector
Well here she is in holiday mode with roof bars and box, I picked up some window vents and a couple of cup holder for the second row seats from Brendan today and as you can see the tinted sliders are in so that's it for before the trip other than treating her too a wash.
Ray
Post #260083 20th Aug 2013 4:08pm
mk1collector
Windscreen surround re-painted and new heated windscreen with new rubber fitted last weekend.
Sorry for the poor pic but it got dark by the time I'd finished Embarassed
Just picked up some parts to make my own side window demisters so I need some dry weather to get drilling and cutting now :mrgreen:
Post #273235 12th Oct 2013 10:03pm
mk1collector
Fitted side window demisters today. Similar idea to the mud ones but only cost £14 and some of my time Mr. Green
The end result!
Let me know what you think Thumbs Up
Ray
Post #273385 13th Oct 2013 4:29pm
kipperthedog
Tidy! £14? Tell more.....
Post #273402 13th Oct 2013 5:31pm
Jimb1978
I second that. Looks great...tell us more
Post #273475 13th Oct 2013 7:51pm
mk1collector
£14 is actually expensive because I had to buy a long length of convoluted tube. if I hadn't decided to do the job Saturday evening when only b&q were still open I probably would have been able to find the tube sold by the metre so I bet the job would have only cost about 7 or 8 quid. You need 2 pipe strengtheners 22mm ones are the best size (the open vent bits) from b&q which are about £3 and about 1 metre of 25mm convoluted tube. Also 2 25mm jubilee clips. First remove the dash top, dash clocks, and upper dash trim. You should be able to see the base of the windscreen vents. Right next to the base of both vents a 22mm hole needs to be drilled into the heater box at the outer side. Measure the amount of tube you need to reach the ends of the dash from the hole in the heater box and cut the convoluted tube. Feed the tube into the heater box about a cm and it will hold itself in place (this is a bit tricky) now rebuild the dash apart from the end plates. Drill a 22mm hole in either end trim of the dash and put one pipe strengthener in each then feed the convoluted tube onto the pipe strengthener and clamp with the jubilee clips (one each side) and screw the end trims back on. Works the same as the mudstuff version will but only costs about £7 or £8 and about 3 hours time. With a saving of £120 I think it's well worth it Thumbs Up
Hope all that made sense Embarassed
Ray
Post #273516 13th Oct 2013 9:36pm
mk1collector
More money spent Big Cry just fitted some conti cross contact tyres and picked up the heated mirror kit from mud
Fitted the pads to some new mirror heads
I'll get new (un-corroded) mirror arms and the heated screen wiring next week and get everything wired up in time for winter. Or be bankrupt and have to sell everything Rolling with laughter
Post #278041 30th Oct 2013 4:24pm
mk1collector
Damn double posting Rolling Eyes
Fitted new steering box arm as the ball joint was screwed too Evil or Very Mad
Post #278042 30th Oct 2013 4:24pm
Byronavitch
England 2011 Defender 90 Puma 2.4 HT Stornoway Grey
mk1collector wrote:
Thank you Thumbs Up
The first thing when I got her back was a full service lube up and general check over at my mates garage and get the petrol and oil leaks started so I could be happy she was in good order. Then a few weeks was spent sorting the broken trim pieces inside and a bit of a clean out then as the wife and kids are a little short in the leg it was time to get some side steps put on. A brown church roof rack soon followed as I needed the carrying ability to do up a couple of houses.
Pic with one of my other toys.
And one in the snow.
This is pretty much how she stayed for a year or two till a young lad in a Toyota aygo decided to drive into me.
Like that picture :thumbsup:
Post #278046 30th Oct 2013 4:57pm
mk1collector
Thumbs Up thank you. I've recently had all the tow bar bits blasted and re-powder coated so I'm starting to get her corrosion free all be it slowly. Side steps next then a few bits of paint to get done come spring time Mr. Green
Post #278057 30th Oct 2013 5:53pm
