![]() | Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats |
Thank you
In holiday mode, with middle row windows, wind deflectors and seat covers fitted. Only needs a wash and filling with fuel before we go now. Roof box also fitted for more space
![]() ![]() Click image to enlarge Ray Last edited by mk1collector on 11th Sep 2017 4:21pm. Edited 1 time in total |
Well we made it there and back without being recovered this time
![]() ![]() I think we brought back more bugs and sand on the defender than there was at the place we stayed ![]() ![]() Click image to enlarge I gave it a good wash off this morning to get rid of as much salt as I could! Unfortunately we missed a show while on holiday that could have been interesting ![]() Click image to enlarge We only saw the poster in the supermarket after the event ![]() Anyway I'll post about my findings on the running problem and I've got a couple of thing I want to do before winter too. Cheers Ray Last edited by mk1collector on 11th Sep 2017 12:09am. Edited 1 time in total |
I think I've found the lack of power as there was oil at the ecu plug again
![]() Ray |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
Ray, mine had a vibration between 50-60
Turned out to be the handbrake was just a touch over adjusted, very slight bind revealed itself at those speeds as a noticeable vibration which went away at 70! When they serviced it did they adjust the handbrake up a turn or two? Matt |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
I put silicone in the top of the plugs when I fitted my harness. It was a britpart one, but has been good for 18 months now. I don't know whether this is a known way to slow down the ingress but it seems to have worked for me. Most silicones are oil resistant I think, but it will say on the tube. 2002 110 td5
pob1968 Member Since: 20 Apr 2014 Location: uk Posts: 239 ![]() |
Just a thought on people running into your truck, my mate has a Bonnatti Grey 130 dccpu and it has been ran into in our car park at work three times in two and a half years, all stating they didnt see it!
Maybe its a Bonnatti Grey thing ![]() |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1432 ![]() ![]() ![]() |
I change the injector harness every 2 years regardless. prevention is better than cause, especially as its only a couple of £. I onle ever use genuine......... trust the blue wrapper
TD5_dan Member Since: 24 Feb 2012 Location: Essex Posts: 449 ![]() ![]() |
Ray have you painted or powder coated the aluminium tread on your side steps black if so did you remove it to do it? 2001 TD5 110 County Station Wagon - sold
1970 Series 2A Station Wagon 1970 Series 2A hard top 1960 Series 2 1972 Series 3 |
I'll try backing the handbrake off a little but they definately didn't adjust it in the service. My vibration calms down a bit above 70 too so I'll try it ![]() |
I don't suppose you have any pics of where to put the silicon? I replaced the harness last year but it's back already! |
That's exactly what the young lad said who hit me the first time! ![]() |
I changed it last year but I've changed the oil 3 times since then for various reasons so with the oil being so new it might be more escapeable ![]() |
It's been zinc coated then powder coated. The steps were starting to rust so I took them off ground them back had them sand blasted then zinc coated and powder coated and the chequer was done at the same time. ![]() |
