Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats
Page 2 of 81 <123 ... 798081>
mk1collector
Haha yeah I'm in netherton now. I wouldn't mind a go at green laning as I've never done it before and have no idea where there are any around here (although I'm sure there are loads) but it would have to be something mild to ease me into it Embarassed
Post #202410 16th Jan 2013 6:46pm
mk1collector
So, the new bumper was bolted on when dry and the wing chequer plate and A bar were powder coated and everything was bolted on apart from the spots as I've taken them apart to fit a new lens and a full clean up. She's booked in next week to have the two head lamp panels and drivers door painted then I can get on with some other bits Whistle
As she stands at the mo.
Ray
Post #204278 22nd Jan 2013 12:32pm
mk1collector
All said and done i did quite well out of the young lad crashing into me as I didn't have to pay for lots of bits I wanted doing anyway Mr. Green
I got two new outer wings
New bumper and end caps
New front door hinges
Wing chequer plate powder coated
A bar powder coated
Headlamp panels and drivers door painted
New spot light lens
Few cans of dinitrol
All I had to do was bolt everything together which I would have done anyway Mr. Green
Post #204282 22nd Jan 2013 12:41pm
mk1collector
As I've got no big jobs planned on the house for a while I've taken the roof rack off and gained an extra 5 to 10 miles per tank (depending on driving) which is good Mr. Green I've also removed the rear window grills and fitted some forward facing rear seats but not Landrover or exmoor ones as I didn't like the belt and mounting setup. So it looks completely standard from the outside now but I've got a bit of tidying up of paint planned and a few add ons over the next few months before the trip to France in August then I can start playing with it a bit after that Thumbs Up
Post #218016 11th Mar 2013 1:05pm
mk1collector
Standard and boring Big Cry
Post #218024 11th Mar 2013 1:36pm
Tubes63
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
I think it looks best like that, myself Thumbs Up Geoff
2007 Defender 90
Post #218050 11th Mar 2013 3:44pm
mk1collector
Thumbs Up it needs some tinted rear windows soon I think
Post #218052 11th Mar 2013 3:48pm
mk1collector
So this was the last pic I got before she disappeared to a local garage for a month with a head gasket leak and a starting/running problem Big Cry she broke down five times on this little trip to get me some new wellies Rolling with laughter and with the kids in the car and the amount of snow we had enough was enough!!! But I've had her back a couple of weeks now and what a difference Mr. Green I put an egr blank on while in the garage and loe low down pull is now lovely.
So this is her now
As you can see the spots are back on, she's had a wash and I've finally figured out the previous owners bodge that was stopping the horn and rear wash working properly.
In the next few weeks I'm going to pick up some goodies from Brendan on here so there should be some more progress soon and I've got a few more plans before the end of the year so keep tuned Thumbs Up
Ray
Post #233378 7th May 2013 10:33am
mk1collector
So, I've been a little busy with my 110. First off all the rear seats and trim came out so I could seal up all the built in gaps and leaking points from lr then came the dynamat
Once the deadening was done a layer of closed cell foam was put over the top and rubber mats were put over the top( including the nakatanenga load mat from Brendan) and all the trim etc was replaced.
The under cubby safe (again from Brendan) and relocated handbrake lever was next.
I ve also started fitting air con but that will be finished after I come back from holiday (hopefully) and last but not least today I've just received the new clutch spring kit from Simon (mps trading) and fitted it this afternoon so the drive to France should be more pleasant. Still to come are some tinted windows that don't rattle and after the holiday a few mods for winter but ill update on those later. Sorry for the million pics Whistle
Ray
Post #249019 4th Jul 2013 1:39pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Thumbs Up you have been busy. DVD player next?! Whistle
It would be rude not to after all that sound proofing.
How do you find the under cubby safe? Is the arm rest now the right height or gone the other way and ended up too high?
Post #249035 4th Jul 2013 2:54pm
hamtheman
Ireland 2004 Defender 90 Td5 SW Java Black
Lovely machine! I was only thinking recently - "Man I could do with moving the Hand Brake!" and now look!! Great! http://mylandy90.blogspot.ie/
Post #249036 4th Jul 2013 2:56pm
mk1collector
Ha ha, DVD player will have to wait until I've done all the roof and upper sides with sound deadening and closed cell but I think one is definitely on the cards. As for the cubby safe, it's made the cubby perfect for resting my arm on but now I'm going to have to buy a new cubby as I'd forgotten how tatty it was and I don't think it's an original lr one anyway as its a bit long Big Cry
Post #249047 4th Jul 2013 4:21pm
mk1collector
Thank you, the handbrake move is pretty easy (it only took me a couple hours) and you can use an RRC handbrake but make sure you have the right one, or a disco 1 lever. There's a thread in the maintenance and mod section with a link to reedx with a good write up of the job. I'd link you too it but I don't know how, sorry Mr. Green
Ray
Post #249050 4th Jul 2013 4:25pm
mk1collector
Well I'm off on my hols soon so figured I'd lose the weight of the tow bar for the trip as it getting blasted and re-powder coated some time after I get back. So today off it came and at the same time I re-bolted the rear step back on securely without the rubbish rivnuts and I also relocated the tow electrics to the hole in the rear cross member. In the past week she's also been in for new swivel housings and bearings, wheel bearings, new front callipers, discs and pads and a full service with diff lock evo 1 oil in the gearbox to make it a bit smoother so hopefully she will be in good health for the drive to France.
Ray
Post #259758 19th Aug 2013 12:38am
Jimb1978
Enjoy your holiday ray. It sounds like the defender is ready for it. I got back yesterday after 2200 miles without any problems. In fact, it was raining on the last day so we cancelled our last overnight stop and came back from Le Mans all in one. Even fully loaded and the rack and roof tent, she still managed 25 to the gallon at 70 mph!
Post #259776 19th Aug 2013 7:39am
