Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats |
Thank you
12th Aug 2014 5:15pm |
In holiday mode, with middle row windows, wind deflectors and seat covers fitted. Only needs a wash and filling with fuel before we go now. Roof box also fitted for more space
Click image to enlarge Ray Last edited by mk1collector on 11th Sep 2017 4:21pm. Edited 1 time in total |
14th Aug 2014 4:33pm |
Well we made it there and back without being recovered this time although there is definately something wrong the vibration is annoying at about 50 to 60 and there's a lack of power so I need to do some checks this week.
I think we brought back more bugs and sand on the defender than there was at the place we stayed Click image to enlarge I gave it a good wash off this morning to get rid of as much salt as I could! Unfortunately we missed a show while on holiday that could have been interesting Click image to enlarge We only saw the poster in the supermarket after the event Anyway I'll post about my findings on the running problem and I've got a couple of thing I want to do before winter too. Cheers Ray Last edited by mk1collector on 11th Sep 2017 12:09am. Edited 1 time in total |
24th Aug 2014 4:07pm |
I think I've found the lack of power as there was oil at the ecu plug again so I'll order a new injector loom when everything opens again after the bank holiday, but the vibration is still there so more to check when the weather is good.
Ray |
24th Aug 2014 11:16pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Ray, mine had a vibration between 50-60
Turned out to be the handbrake was just a touch over adjusted, very slight bind revealed itself at those speeds as a noticeable vibration which went away at 70! When they serviced it did they adjust the handbrake up a turn or two? Matt |
25th Aug 2014 6:19am |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 |
I put silicone in the top of the plugs when I fitted my harness. It was a britpart one, but has been good for 18 months now. I don't know whether this is a known way to slow down the ingress but it seems to have worked for me. Most silicones are oil resistant I think, but it will say on the tube. 2002 110 td5
25th Aug 2014 7:40am |
pob1968 Member Since: 20 Apr 2014 Location: uk Posts: 239 |
Just a thought on people running into your truck, my mate has a Bonnatti Grey 130 dccpu and it has been ran into in our car park at work three times in two and a half years, all stating they didnt see it!
Maybe its a Bonnatti Grey thing 110 Hardtop |
25th Aug 2014 8:12am |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1423 |
I change the injector harness every 2 years regardless. prevention is better than cause, especially as its only a couple of £. I onle ever use genuine......... trust the blue wrapper
25th Aug 2014 8:27am |
TD5_dan Member Since: 24 Feb 2012 Location: Essex Posts: 449 |
Ray have you painted or powder coated the aluminium tread on your side steps black if so did you remove it to do it? 2001 TD5 110 County Station Wagon - sold
1970 Series 2A Station Wagon 1970 Series 2A hard top 1960 Series 2 1972 Series 3 |
25th Aug 2014 9:06am |
I'll try backing the handbrake off a little but they definately didn't adjust it in the service. My vibration calms down a bit above 70 too so I'll try it |
25th Aug 2014 10:38am |
I don't suppose you have any pics of where to put the silicon? I replaced the harness last year but it's back already! |
25th Aug 2014 10:43am |
That's exactly what the young lad said who hit me the first time! I even had my lights on so you'd think he couldn't miss me! |
25th Aug 2014 10:45am |
I changed it last year but I've changed the oil 3 times since then for various reasons so with the oil being so new it might be more escapeable |
25th Aug 2014 10:47am |
It's been zinc coated then powder coated. The steps were starting to rust so I took them off ground them back had them sand blasted then zinc coated and powder coated and the chequer was done at the same time. |
25th Aug 2014 10:50am |
