Home > Puma (Tdci) > The First Headlight Question ever asked on this forum
Page 2 of 2 <12
paullo
Canada
If you can run xenons without consequence; I'd have the Crystal / Quad-Optics as some have suggested as well as proper ballasted xenons. They throw a ton more light than halogen bulbs, last 2-3x longer and are 5x cheaper then LED's. I've seen a setup exactly the same as I've mentioned and it puts the factory lights to shame.
Post #113714 9th Jan 2012 11:13am
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
diesel_jim wrote:
On my old 90 I used to have an ARB headlight loom (although they're dead easy to make)
in short, it's 3 relays (one for both headlights dipped bean and the other two for each headlight on main beam)
There was a socket that the headlight plug plugged into, which triggered the relays (dipped/main), and the whole loom took its own power feed directly from the battery.
So when you flicked the headlight dip/main switch on the steering column, the relays engaged, and they controlled the headlights. even with standard bulbs it made them "whiter" instead of the yellowy dull that they are.
Funnily enough the headlight (off/side/main) switch melted on my 110 last week. I've knocked up a quick relay loom so that the main switch just operates the relay which in turn powers the headlights, but the dip/main bean still goes through the poxy column switch... I'll get around to making a full loom sometime.
As luck would have it, I had an old Td5 bulkhead loom so I chopped off the healdight switch plug, along with the old plug from my melted switch, and made the relay loom literally plug & play (apart from a separate earth for the relays)
should save on melted switches in future!
Hi blackwolf,
How is your fender lately??
just to check that all puma defender are fitted with headlight relays now? - they are the r123 and r126 on the wiring diagram????
http://www.legionlandrover.com/manuales/el...%20tdi.pdf
Thanks
Martin
Post #300769 21st Jan 2014 1:29am
Martin, those relays are not the switch activated ones that people are talking about adding in this or the other two threads you've commented on. Also, the manual you've linked to is for a 300tdi, not a Puma. Darren
Post #300776 21st Jan 2014 6:21am
tuesdayfox
Hi Darren,
Thanks!
then linked diagram is not correct.
so the headlight relay in current defenders are dim/dip relay, not the on/off relay that we need?
M
Post #300780 21st Jan 2014 6:54am
The relay fitted as standard in the headlight circuit of Defenders is activated by the ignition feed and energises the main headlamp on/off switch. Its purpose is to turn off the headlights if you stop the engine.
The main headlight on/off switch and the dip/main beam switch both carry full headlight current, hence the failures, hence the many threads on the subject.
Post #300796 21st Jan 2014 8:48am
jimbob7
Is this the modified headlamp loom people are talking about?
https://shop.landreiziger.nl/modificatie/m...elaar.html Pov.spec,ftw. 2006, 110,TD5.
Post #300843 21st Jan 2014 12:46pm
VeeTee
Netherlands
Yes, it is. Plug & play solution. Thumbs Up Cheers, Vincent
MySite
Post #300847 21st Jan 2014 1:15pm
Page 2 of 2 <12
