Home > Puma (Tdci) > The First Headlight Question ever asked on this forum
carib110
2009 Defender 110 Puma 2.4 CSW Zermatt Silver
Is it possible to increase the wattage of the H4 headlight bulbs from 55/60 to 95/100 (Xenon) without doing any damage? Just a simple swap.
Post #112536 5th Jan 2012 5:52pm
AFAIK the switch will get warm and possibly melt.
also, 90/100s are illegal for road use.
there are some excellent 55/60s on the market from Halfords (£10) thru to PIAA(£60)
HTH
Post #112545 5th Jan 2012 6:11pm
carib110
Thanks, that is what I needed to know.
It is still legal here to drink rum out of the bottle while you are driving, so I doubt they will worry about strong headlights.
Post #112549 5th Jan 2012 6:17pm
Jammer600
United Kingdom 2007 Defender 90 Puma 2.4 HT Tonga Green
Your stalk/switch will definitely burn out!! 90 Puma HT
Post #112566 5th Jan 2012 6:43pm
Dave-H
Along with the bulb connectors ............ Whistle Guns and Landrovers .... anything else is irrelevant.
Post #112576 5th Jan 2012 6:55pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Simple enough to pop a relay and beefed up wiring in the circuit to stop things getting warm! ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #112757 5th Jan 2012 11:49pm
On my old 90 I used to have an ARB headlight loom (although they're dead easy to make)
in short, it's 3 relays (one for both headlights dipped bean and the other two for each headlight on main beam)
There was a socket that the headlight plug plugged into, which triggered the relays (dipped/main), and the whole loom took its own power feed directly from the battery.
So when you flicked the headlight dip/main switch on the steering column, the relays engaged, and they controlled the headlights. even with standard bulbs it made them "whiter" instead of the yellowy dull that they are.
Funnily enough the headlight (off/side/main) switch melted on my 110 last week. I've knocked up a quick relay loom so that the main switch just operates the relay which in turn powers the headlights, but the dip/main bean still goes through the poxy column switch... I'll get around to making a full loom sometime.
As luck would have it, I had an old Td5 bulkhead loom so I chopped off the healdight switch plug, along with the old plug from my melted switch, and made the relay loom literally plug & play (apart from a separate earth for the relays)
should save on melted switches in future!
Post #112772 6th Jan 2012 7:54am
It baffles me why LR still run the full headlight current through the light switch and dip switch on the4 Defender, especially as there is a (fairly pointless) relay already in the circuit. I doubt that there is any other vehicle manufactured in the world that does this!
Modifying the wiring to include relays for the headlight current is an extremely sensible idea.
It also amazes me that the dip switch is such a piece of crud; every time I use it feels as though it is about to break (and two already have). The arrangement on my Disco2, which is 5 years older than my Defender, is superior in every respect.
Maybe this is why we love our Defenders so much.
Post #112841 6th Jan 2012 10:47am
Grockle
..and the headlights will explode injuring all the people waiting at the crossing Shocked Wink 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #112848 6th Jan 2012 11:11am
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Hi Carib110!
I lived, worked and played in Santo Domingo (lived in Arroyo Hondo, worked in Ensanche Naco, played on the Malecon, Villa Duarte etc.) until 2001, weren’t too many Land Rovers about then.
I added to them by selling and leaving behind my 3.5 litre V8 110 station wagon with twin fuel tanks, winch and bull bar, expedition roof rack etc. Probably still in use and, as you say, anything goes…
Must return soon for another fix of Brugal and Seben-Up, the Jet-Set, Jaragua, D’Noche, Boca Chica hotties, cabañas…
Peter
Post #112907 6th Jan 2012 1:49pm
scotty38
England 2012 Defender 110 Puma 2.2 USW Aintree Green
Then why would you care if your lights were even on Laughing
Post #112920 6th Jan 2012 3:42pm
carib110
Birdy wrote:
Hi Carib110!
Peter
Hi Peter,
Boca Chica hotties? Cabañas? Why what DO you mean?
Actually, I live on the North coast away from all that madness but only minutes away from the Brugal rum factory. I only visit Santo Domingo to visit the Land Rover dealership for my regular maintenance.
It's tough living here but someone has to do it.
Alex
Post #112960 6th Jan 2012 6:10pm
carib110
So I can see if any more parts have fallen off Shocked
Post #112963 6th Jan 2012 6:14pm
AndrewS
Re: The First Headlight Question ever asked on this forum
Well I know a bloke that has done this with 2 130's and not had any issues, the vehicles are used 24/7 so the lights are used on a regular basis. 130's have feeling's as well you know Smile
Post #113012 6th Jan 2012 7:52pm
60North110
2007 Defender 110 Puma 2.4 CSW Java Black
My dipped headlights were always bad, so based on recommendations from this forum I have experimented with various combinations.
A noted improvement came in fitting the Wipac Crystal (SVX) headlamps, and I ran some H4 95/100 headlight bulbs for 3 months but was disappointed with the results. (Blue tinted glass ones)
After reading about the Osram Nightbreaker 55/60's I thought I would give them a try
Thumbs Up BRILLIANT - finally the dipped beam is what I expected it to be Thumbs Up
Get yourself some WIPAC Crystals and OSRAM NIGHTBREAKERS, you wont be disappointed.
Post #113650 8th Jan 2012 10:13pm
