Home > Puma (Tdci) > The First Headlight Question ever asked on this forum |
tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129 |
Hi blackwolf, How is your fender lately?? just to check that all puma defender are fitted with headlight relays now? - they are the r123 and r126 on the wiring diagram???? http://www.legionlandrover.com/manuales/el...%20tdi.pdf Thanks Martin |
21st Jan 2014 1:29am |
Martin, those relays are not the switch activated ones that people are talking about adding in this or the other two threads you've commented on. Also, the manual you've linked to is for a 300tdi, not a Puma. Darren
21st Jan 2014 6:21am |
Hi Darren,
Thanks! then linked diagram is not correct. so the headlight relay in current defenders are dim/dip relay, not the on/off relay that we need? M |
21st Jan 2014 6:54am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17540 |
The relay fitted as standard in the headlight circuit of Defenders is activated by the ignition feed and energises the main headlamp on/off switch. Its purpose is to turn off the headlights if you stop the engine.
The main headlight on/off switch and the dip/main beam switch both carry full headlight current, hence the failures, hence the many threads on the subject. |
21st Jan 2014 8:48am |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Is this the modified headlamp loom people are talking about?
https://shop.landreiziger.nl/modificatie/m...elaar.html Pov.spec,ftw. 2006, 110,TD5. |
21st Jan 2014 12:46pm |
Yes, it is. Plug & play solution. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
21st Jan 2014 1:15pm |
