Home > Maintenance & Modifications > A day in the life of Miffy the 110...
Page 41 of 60 <123 ... 404142 ... 585960>
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
Quick question - what is the part number of the Duo Lights?
I've had a look on their site and there's quite a list of them.
Post #999637 11th Jul 2023 2:23pm
geobloke
Any of the 70mm delights will work, I have the Duolight DL27. For reference they do come with a full wiring loom, brackets and plastic ring finishers.
https://www.performancealloys.com/einparts...-universal
Well that is irritating they are now on offer 20% off... Rolling Eyes
Post #999639 11th Jul 2023 2:30pm
geobloke
Love a bit of evening painting...
Wiper blades all nice and black again, not a faded patch dull grey Rolling Eyes
With a new set of blades and that is another job ticked off the list Thumbs Up
Post #999689 11th Jul 2023 8:41pm
geobloke
Leaking Allisport intercooler
Hmmm. I am not sure what to do about this... Allisport say it is nothing to be concerned about, but...
​It doesn't look like a split weld, but weeping from the channel to end tank union. It has been like this for quite some time by the looks of things. Hmmmm...
Clean and JB Weld might be the way forward.
Post #999736 12th Jul 2023 7:50am
Surely with heat expansion and contraction and under pressure from the turbo eventually it's going to get worse?
I'm sure they weren't designed to be leaking Laughing
Post #999738 12th Jul 2023 8:02am
geobloke
Well yes, they are definitely not meant to leak Rolling with laughter
I have popped the image on to a rad/intercooler repair company to see what they say. I wonder how much pressure drop is happening? can't be much, surely... Rolling Eyes
Post #999741 12th Jul 2023 8:10am
geobloke
Well Balls...!
Just popped out to let the dogs smell the bushes and took the wipers with me...
Balls... That wasn't meant to happen, thing is made of cheese... Balls...
Small consolation, the other two look good though.
Post #999769 12th Jul 2023 10:34am
geobloke
Cable tie bases - DAZ110
Ah ha... DAZ110 you absolute star Thumbs Up Thumbs Up
These arrived in the post and they are precisely what I need to fix the cabling behind the bumper in place
Thank you very much Thumbs Up
Post #999873 13th Jul 2023 8:26am
DAZ110
Thumbs Up
Post #999903 13th Jul 2023 12:41pm
excossack
How are the bases held in place? Glue/screws/magic? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #999907 13th Jul 2023 12:46pm
geobloke
MANN HUMMEL Provent 200 Oil Catch Can
Given the oily mess I found coming out of the intercooler it led me to have a poke around. There shouldn't be hardly any oil making its way into the intercooler from the cam cover vent as I had an oil catch can installed inline. Weird eh?
Now the catch can I have fitted is a Provent copy and I have had cause to wonder in the past whether it is working efficiently enough as very little oil was being separated out. The solution at the time was to wrap the metal mesh filter in some cotton cloth. This worked well and the drain tube provided about 100ml of oil over the year. The most concerning issue with the cheap Provent I have always had is the flimsy plastic of the inlet and outlet ports that deformed with very little pressure and over time have become square under the jubilee clips. This has allowed oily mist to vent to atmosphere. Yuk...
So, given the above and the intercooler I found a real Provent 200 and it arrived first thing this morning.
What a difference in quality of product. Chalk and Cheese difference. I advise anyone thinking of fitting a catch can to buy original, not the cheap Chinese knock offs.
Some observations:
    The lid of the P200 is such a positive fit and locks in place whereas the P200c (Chinese) is a loose fit.
    The vent spring in the P200 is much stronger.
    The P200 outlet vent is much softer, more pliant and the cap positively clips in place.
    The P200 filter is a multi-layer textile rather than SS mesh.
    The P200 outlet ports are made of a thick strong plastic that does not deform.
    The mounting brackets are almost identical.
The new Provent 200 fitted into Miffy in the original position
Lets see what the difference is Thumbs Up
Post #999908 13th Jul 2023 12:54pm
geobloke
Hopes and dreams John. Hopes and dreams Whistle
I have some M4 Black cap head bolts that fit perfectly into the centre of the base. A small hole in the bumper and bob's your uncle. Not sure if I am going to thread the bumper or go with a nut.
Post #999909 13th Jul 2023 12:55pm
excossack
Cheers. Hopes and dreams works for me! Smile 1999 Defender TD5 110
Regards
John M0VAZ
Post #999912 13th Jul 2023 1:10pm
geobloke
TD5 black bulkhead connector - BMW AMP - Main Harness
Hi folks. Need some knowledge.
I have to get a pin out of this black bulkhead connector. It is one of the main harness connectors.
It is a BMW AMP connector with weird locking slides inside the connector. How do I remove one of the pins???
I have a vague thought I might need a pin extractor for this one, but that is a complete guess Rolling with laughter
Post #999957 13th Jul 2023 5:40pm
geobloke
A few little jobs after dinner this evening. The brakes have been bled, front diff filled with oil, TRE's and pro-shafts greased.
Small simple stuff, but all essential Thumbs Up
Post #999981 13th Jul 2023 7:29pm
