![]() | Home > Maintenance & Modifications > A day in the life of Miffy the 110... |
AH ha.... Success... Have to love LR Direct, replacement wiper blade came this afternoon, plus other bits...
New wiper arm on and SS flanged bolts with anti seize of course... ![]() Click image to enlarge I forgot to mention yesterday that when I came to bleed the brakes I noticed this weird growth in the DOT 4 remaining in the reservoir. Never seen that before. It got syphoned off before refilling. But weird. Thought DOT 4 was pretty much poison to everything... ![]() Click image to enlarge ![]() Click image to enlarge |
It is not the first time that I have heard about Allisport intercoolers splitting along the welds or leaking. I think I will have a go at plugging the weak. What is the worst that can happen ![]() It is a funny thing but "balls" features fairly regularly in my Land Rover vocabulary ![]() |
Oooo an early morning S&A delivery
![]() This is EP 80/90 for the rear diff that is going to be removed for refurb in the next few weeks. The diff has done around 250k miles and it would be a good time to check it out. ![]() Click image to enlarge |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10940 ![]() ![]() |
Just be careful when plugging the hole/holes as the pressure will cause another hole in time, that's what my intercooler did
![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Well you're full of optimism Clayton
I came across this photo of my old (1992) Defender 90, called Eva, sat outside my old house this morning, she was a splendid vehicle. We did some amazing trips together. Goodness she could haul ass, such a strong engine the 200tdi.
![]() That will be the best bet to observe the " weep " ![]() I just find it great finding old pics that you forget you had, all the memories come flooding back, O happy days ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Many thanks to htb2 for the slam panel support struts
Observe the weep or observe and weep ![]() ![]() You are not wrong about old photos... Or old videos... https://youtu.be/X9vSyR7l8oA This is that red 90 having a great time setting out trials at what was then the Anglesey Offroad centre. Hell of a time ![]() |
Well, this morning I had a visitor
![]() John very kindly offloaded one of his large vices with me which is going to come in handy when I fit the ATB to the rear diff and a host of other jobs that require more than two hands to do. What we also did was check his 110s front half shaft end play as he is experiencing some clicking from the front at full lock and although it is probably the CV getting tired I offered to check the end play whilst he was here. For context his 110 has covered nearly 250k miles and they are likely to be the original half shafts and CVs. Pretty incredible really. I am thrilled as I got to use my new DTI and I am happy to say it works ![]() The results are as follows; OS = 0.07mm NS = 0.59mm The results: the OS end play is 0.01mm too tight and the NS is a minimum of 0.41mm too loose ![]() ![]() The end play should be between 0.08 and 0.18mm to allow lubrication of the brass bushing on the stub axle and the external edge of the CV joint. Too little play and the parts will not be lubricated adequately and if there is too much play the CV can impact on the brass bushing and the internal axle oil seal will migrate over the half shaft possibly wearing the seal quicker. So, the moral of the story is get out there and check your CV end play. They do change over time and it is a very very simple DIY job to do if you have a DTI. I suppose you could do it with feeler gauges as well mind. ![]() Click image to enlarge ![]() Click image to enlarge |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5922 ![]() ![]() ![]() |
Good to meet you today as well Guy and Miffy the 110. The ham session up the hill went well thanks.
Glad the vice is of use to you, I didnt need 4 vices hanging around the shed. Thanks for checking the end float, time to look at options etc. cheers PS Amber lights fixed, turns out the earth pin on the multi plug had moved! No idea why as the connector has been fine for that last 3 years or so! 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Four vices... I would have thought one vice was enough for the average man to be honest... In my case its a nice peaty whisky
![]() Glad you got the lights sorted out. If I had to guess I would say the pin wasn't located quite far enough into the multi-way connector and vibrated loose. Just about to order some soft vice jaws ![]() Tomorrow I am going to check Miffy's end play... Whatch this space as she is also approaching 250k miles on her original front axle... Just not the diff, number 3 diff ![]() |
Mmm single malt
![]() Regards John M0VAZ Econet Station 48 no clock |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2131 ![]() ![]() ![]() |
Always nice to see multiple Landrovers playing happily together in this natural environment. Likewise, always nice to read about their owners playing nice together too - great to be able to help each other ![]() ![]() ![]() |
