![]() | Home > Maintenance & Modifications > A day in the life of Miffy the 110... |
Well since you seem to be an expert in these screws and really not that far away...
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5922 ![]() ![]() ![]() |
Good luck over the weekend. More motorsport for me. 1999 Defender TD5 110
That sounds like fun, although you are missing the opportunity of an excellent bison burger
Hope so as well. Bison burger mmmmmmmmmmm 1999 Defender TD5 110
Well not had much dry weather to do anything this weekend... but I did get a couple of things done.
The first is the front brake stone guards are now attached with a proper 15mm long bolt and the guards are nicely pressed against the YRM SS brackets and away from the brake disc. ![]() Click image to enlarge ![]() Click image to enlarge The second little job was the fitting of the new dual DRL and Fog lights in the bumper. I have been waiting to fit these for months, but needed a thicker 90mm gasket behind the bumper to get the right clamping force to hold the light in position. There are 70mm Vinstar Duolights from EinParts in Germany, or at least that is where I got them from. I have not wired them up yet, but I am very much looking forward to having both DRLs and fog lamps on the front of Miffy. Should look a bit different to the usual Defender DRLs... ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2145 ![]() ![]() ![]() |
All looks tickety boo π
Bison burger AND YRM in one update - all too much for me! Keep up the great work πππ |
Well that was a nice surprise before sitting down to work... Roll on the rear diff upgrade...
![]() ![]() Click image to enlarge |
Honestly, a bison burger is something special. ![]() |
Good grief... Must resist.... must resist.... Miffy really doesn't need to be a 6x6...
![]() https://www.ebay.co.uk/itm/175637205166?va...o8QAvD_BwE |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10940 ![]() ![]() |
Nice jobs being done there on Miffy
![]() I will have to put that on my to do list " try a Bison burger " ![]() You could do a mod to the third axle and make it a " lift axle " when not in use ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 867 ![]() ![]() ![]() |
A little late to this, sorry! Great to meet you too! I am now seriously considering a TD5 with a GTB550 turbo..... 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
Great to meet you to Shroppy
![]() ![]() ![]() So I see, looks like you have a good option in that 2004 TD5, it will be a 15P and around 100k miles is almost broken in ![]() |
Well, a little job over lunch... This morning the wiper removal tool arrived and long story short. Brilliant tool to have in your garage. Right tool for the job.
This began with noticing that the rubber dust covers on the wiper spindles were only being held together by faith, hopes and dreams. ![]() Click image to enlarge So I sourced a replacement set from Emberton Imperial might have been via their eBay site. ![]() Click image to enlarge Anyway, I couldn't get the wiper arms off and I know that trying to lever them off will only cause damage to paint, or glass or components. If you are planning to remove your wiper arms then this tool is what you need. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge A quick clean, application of red rubber grease and the cap slides on. Lovely positive fitment around the spindle shaft and over the locking ridge at the bottom of the spindle. βThe tool and dust covers also work on the rear door wiper as well ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Those securing nuts definitely need changing though and the wiper arms are getting a fresh coat of paint as well. |
