Home > Modifications & Maintenance (L663) > Mirror Clearsight retrofit |
Clark4x4 Member Since: 19 Jun 2023 Location: Madrid Posts: 33 |
Hi Marco,
really interested in your experience with this retrofit, I starting to follow some part on ebay... In fact... do you have a picture of connector in the mirror? I know that in antenna is a green Fakra but not sure in mirror side... Cheers Oscar |
23rd Jun 2023 7:43am |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 163 |
hi oscars,
I'll give you what I found, it looks like a normal black coaxial fakra connector, I ordered the cable repair kit from LR, of which there is no photo, when it arrives I will publish the images of what arrives. Cheers Marco Click image to enlarge |
23rd Jun 2023 12:43pm |
today the main spare parts arrived, mirror and antenna, I await the repair wiring from LR.
on the photo you can clearly see the two video signal connectors, it is a harness that carries both the video signal and power supply (poc), therefore no power supply to the antenna. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
28th Jun 2023 2:37pm |
Hi everyone,
retrofit successful! i ordered a genuine land rover repair cable, LR164584, then i ordered a blue universal connector adapter fakra coaxial cable. the land rover cable has a green connector, which connects to the antenna, and a purple connector, this is an interconnection, to this purple I connected the universal extension which then connects to the black connector on the mirror. Total I spent 50 euros of wiring. installation procedure, I have published all the photos, phase 1, disassembly of the rear view mirror, disassembly of the roof lights console, disassembly of the rear side roof light. phase 2, I passed the coaxial cable from the mirror opening to the lights console compartment, (this is a bit difficult), then from the lights console compartment, to the rear side light, and from this to the rear part under the antenna, (the latter very easy parts). I referred to a video by Simon PFUK, whom I thank. step 3, I disassembled the two antenna bolts, disconnected connectors, installed new antenna and connected new cable to green connector. finally after closing everything, I did the coding thanks to the Gap Tool, MultiCAN-711 Interior Mirror Variant IRVM changed to SVRM. Only this programming, and voilà the game is done, I would say extremely simple. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
1st Jul 2023 2:58pm |
&feature=share[/url]
1st Jul 2023 3:02pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1415 |
Great job Marco It's a modification that I would love to do. Am I right that you managed to pick the parts up second hand? Also the repair lead that you got, when you fed it through the roof, do you have the panoramic roof or just the plain one? Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
1st Jul 2023 6:00pm |
hi Jan, Thanks 👍, I found the used spare parts, I got a great deal, the wiring was new and relatively cheap, I easily passed the wiring without a sunroof, but as you can see from the photograph, in any case there are lateral spaces easy to walk.
it is a job that is completed in two hours Cheers Marco |
1st Jul 2023 6:18pm |
Thanks for that Marco, I'm off to search for some second hand parts on Ebay Cheers Ian
1st Jul 2023 6:27pm |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 422 |
Nice job Marco, well done ! No Mud flaps for my 90.!
----------------------------------------- P300 S MY21 on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
1st Jul 2023 8:26pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3674 |
Kudos! Top Job Marco.
2nd Jul 2023 6:40am |
Thanks for sharing Marco, Great gob!!
I’m collecting parts,( antenna and wire, need to find mirror) and I’ll replícate this retrofit, so your input is very much appreciated Cheers Oscar |
2nd Jul 2023 8:58am |
M7even Member Since: 14 Sep 2020 Location: Dubai Posts: 23 |
Awesome retrofit!
Would be interesting to do it, but does it by any chance void the warranty ? 2014 Defender LXV 2023 Defender 90 HSE |
9th Jul 2023 7:36pm |
GrouseK9 Member Since: 09 Aug 2021 Location: Austin, Tx Posts: 16 |
Fantastic job and wonderful post!! I'm ordering parts this week. One Q: I have a sun roof, did the cable come with plenty of slack? Wondering how much of a pain it will be to route it if it is tight and short. Thanks and well done.
24th Jul 2023 4:34pm |
thanks for the approval,
don't worry, it's easy to pass the wiring from the console (glasses holder) to the antenna. follow the video I posted by the kind Simon of PF. They have a car with a sunroof. It is more difficult to pass the cable in 20 cm, from the console to the mirror support.... Cheers Marco |
24th Jul 2023 4:47pm |
