![]() | Home > Modifications & Maintenance (L663) > Mirror Clearsight retrofit |
Clark4x4 Member Since: 19 Jun 2023 Location: Madrid Posts: 38 ![]() ![]() |
Hi Marco,
really interested in your experience with this retrofit, I starting to follow some part on ebay... In fact... do you have a picture of connector in the mirror? I know that in antenna is a green Fakra but not sure in mirror side... Cheers Oscar |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 174 ![]() ![]() |
hi oscars,
I'll give you what I found, it looks like a normal black coaxial fakra connector, I ordered the cable repair kit from LR, of which there is no photo, when it arrives I will publish the images of what arrives. Cheers Marco ![]() Click image to enlarge |
today the main spare parts arrived, mirror and antenna, I await the repair wiring from LR.
on the photo you can clearly see the two video signal connectors, it is a harness that carries both the video signal and power supply (poc), therefore no power supply to the antenna. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Hi everyone,
retrofit successful! i ordered a genuine land rover repair cable, LR164584, then i ordered a blue universal connector adapter fakra coaxial cable. the land rover cable has a green connector, which connects to the antenna, and a purple connector, this is an interconnection, to this purple I connected the universal extension which then connects to the black connector on the mirror. Total I spent 50 euros of wiring. installation procedure, I have published all the photos, phase 1, disassembly of the rear view mirror, disassembly of the roof lights console, disassembly of the rear side roof light. phase 2, I passed the coaxial cable from the mirror opening to the lights console compartment, (this is a bit difficult), then from the lights console compartment, to the rear side light, and from this to the rear part under the antenna, (the latter very easy parts). I referred to a video by Simon PFUK, whom I thank. step 3, I disassembled the two antenna bolts, disconnected connectors, installed new antenna and connected new cable to green connector. finally after closing everything, I did the coding thanks to the Gap Tool, MultiCAN-711 Interior Mirror Variant IRVM changed to SVRM. Only this programming, and voilà the game is done, I would say extremely simple. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
&feature=share[/url]
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1440 ![]() ![]() ![]() |
Great job Marco
![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
hi Jan, Thanks 👍, I found the used spare parts, I got a great deal, the wiring was new and relatively cheap, I easily passed the wiring without a sunroof, but as you can see from the photograph, in any case there are lateral spaces easy to walk.
it is a job that is completed in two hours Cheers Marco |
Thanks for that Marco, I'm off to search for some second hand parts on Ebay
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 442 ![]() ![]() |
Nice job Marco, well done ! No Mud flaps for my 90.!
----------------------------------------- P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3706 ![]() ![]() ![]() |
Kudos! Top Job Marco.
Thanks for sharing Marco, Great gob!!
![]() I’m collecting parts,( antenna and wire, need to find mirror) and I’ll replícate this retrofit, so your input is very much appreciated ![]() Cheers Oscar |
M7even Member Since: 14 Sep 2020 Location: Dubai Posts: 23 ![]() ![]() ![]() |
Awesome retrofit!
Would be interesting to do it, but does it by any chance void the warranty ? 2014 Defender LXV 2023 Defender 90 HSE |
GrouseK9 Member Since: 09 Aug 2021 Location: Austin, Tx Posts: 16 ![]() ![]() ![]() |
Fantastic job and wonderful post!! I'm ordering parts this week. One Q: I have a sun roof, did the cable come with plenty of slack? Wondering how much of a pain it will be to route it if it is tight and short. Thanks and well done.
thanks for the approval,
![]() ![]() don't worry, it's easy to pass the wiring from the console (glasses holder) to the antenna. follow the video I posted by the kind Simon of PF. They have a car with a sunroof. It is more difficult to pass the cable in 20 cm, from the console to the mirror support.... Cheers Marco |
