![]() | Home > Modifications & Maintenance (L663) > Mirror Clearsight retrofit |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1440 ![]() ![]() ![]() |
I'm in the process of collecting the parts together also for my retrofit and I have the sunroof so whoever gets them first can comment on how easy it was to get it past the sunroof
![]() ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Clark4x4 Member Since: 19 Jun 2023 Location: Madrid Posts: 38 ![]() ![]() |
Important!!! if you have Secure Tracker, don't forget to put Service Mode in InControl app... or you will receive and alarm... Your car has been stoled!!!! after disconnect antenna...
And you need to call and say that was you, no problem in your car... ![]() |
Well I've just fitted mine and it's working perfectly, I actually went down the opposite side to Clark4x4. I managed to get my wire down to the 2nd row interior light without any problems, I have the panoramic roof, getting the wire from there to the front was difficult as I couldn't get my hand in the console gap so I had to enlist the help of a family member with small hands
![]() I used the Land Rover repair cable LR164584 and the 3M extension cable from Jason at In Car Connections --> Cable as per Marco's instructions Thanks to Marco for doing it and sharing his methods and also thanks to clark4x4 for the tip about the service mode in the app ![]() Click image to enlarge ![]() Click image to enlarge Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
I have a 110 with the panoramic roof and the 3m Extension Cable combined with the repair cable LR164584 is more than enough, I actually coiled up the excess and wrapped it in foam to wedge it back into the roofspace. ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
MONGO_SGT_11BC2 Member Since: 31 May 2023 Location: West Cost Posts: 16 ![]() ![]() |
Bravo Marco! Thanks for showing us the way!
Japseroony Member Since: 02 Jan 2008 Location: North East England Posts: 841 ![]() ![]() ![]() |
Hi Ian, so any idea on the total cost of the install please? Gas, Grass Or Ass - Nobody Rides For Free "UNDERSTEER" ----is when you hit the fence with the front of the car. "OVERSTEER" ------is when you hit the fence with the rear of the car. "HORSEPOWER" ----is how fast you hit the fence. "TORQUE" -----------is how far you take the fence with you. |
G4R1 Member Since: 17 Aug 2020 Location: Barnet/Limassol Posts: 131 ![]() ![]() |
This is perfect!
Well done guys, great job! Would you mind sharing where did you manage to get the mirror from? Perhaps you have the parts number? 3.0L MHVE D200 S Pangea Green+Black Pack Adv. + Off-Road and Family Packs |
These are the part numbers for the parts for my car, which is a MY2022 D200 SE without garage opener buttons
Mirror LR140339 £897.76 Fin Camera LR140530 £223.16 Camera Cover LR117853 £117.38 Cable LR164584 £30.25 Which gives a total of £1268.56 You will also need a Fakra cable from Ebay https://www.ebay.co.uk/itm/325234838660 Which is about £10 If you keep an eye on Ebay the parts do seem to pop up quite regularly, the camera can be had for about £200-250, it is the same one as fitted to the Defender, Evoque, Disco Sport. Just make sure that the connectors are the same as the ones on Marco's photo earlier in the thread, also most of them on Ebay are the camera and cover together. As for the mirror it would seem that the one fitted to the Defender only fits the Defender and again can be found for about £200-250 on Ebay. You will need the Land Rover repair cable and depending on whether you have a 110 or 90 you will need the Fakra cable from Ebay, if you have a 90 a shorter cable will do. Although I have a 110 and the cable listed above was more than long enough There was a camera on Ebay with a scratched topside, I discounted this one because of the damage but Powerful UK now do a repair cover which would hide the scratches. https://www.powerfuluk.com/clearsight-roof...-l663.html Also most of the breakers on Ebay will accept offers so definitely try a cheeky offer before buying:thumbsup: Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Just remembered one other thing, the mirror/screen will need a ccf edit to get it working
That perfect!
Thank you very much for detailed explanation and the tips! I’ll keep an eye on eBay particularly for the mirror. 3.0L MHVE D200 S Pangea Green+Black Pack Adv. + Off-Road and Family Packs |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 255 ![]() ![]() |
Do the clearsight mirrors from a 2020 discovery sport dynamic hse fit?
The part number for the Defender also fits the Evoque & Disco Sport, but I would just make sure that the connectors are the same as the photos Marco posted on page one
I have a discovery sport 2020 with the clearsight mirror that I am about to sell as I have my defender and wondered if I could remove the mirror and shark fin antenna and fit them to my defender.
My 2020 disco sport clearsight mirror appears to have a different fitting. Not the round twisting one on my defender mirror. Presumable this type of fitting isn’t compatible is it? Does anyone know?
I could see the back of the mirrors posted on here ![]() ![]() |
