Home > Modifications & Maintenance (L663) > Mirror Clearsight retrofit
Page 1 of 6 123456>
mmbanf
Italy
Hi everyone,
I decided to do this retrofit, I was lucky and bought used spare parts, new ones would have cost a lot of money, about 1000 euros for the mirror (SMRV smart view rear mirror), 300 euros for the antenna, 150 euros for the antenna cover.
the power harness to the mirror should be identical, no modifications, we just need to add a video coaxial cable, from the green antenna connector, to the mirror (black connector).
I ordered a camera cable repair kit, which from the diagram looks like the correct one, let's see what I get.......
I will run the coaxial cable with a guide from the back to the front, under the roof.
once this is done, only the antenna assembly and coding remain.
when I have the spare parts at home, more photos for the procedure, I'll keep you updated.
Post #996948 20th Jun 2023 2:27pm
Clark4x4
Spain
Hi Marco,
really interested in your experience with this retrofit, I starting to follow some part on ebay...
In fact... do you have a picture of connector in the mirror? I know that in antenna is a green Fakra but not sure in mirror side...
Oscar
Post #997213 23rd Jun 2023 7:43am
mmbanf
Italy
hi oscars,
I'll give you what I found, it looks like a normal black coaxial fakra connector, I ordered the cable repair kit from LR, of which there is no photo, when it arrives I will publish the images of what arrives.
Marco
Post #997247 23rd Jun 2023 12:43pm
mmbanf
Italy
today the main spare parts arrived, mirror and antenna, I await the repair wiring from LR.
on the photo you can clearly see the two video signal connectors, it is a harness that carries both the video signal and power supply (poc), therefore no power supply to the antenna.
Post #997878 28th Jun 2023 2:37pm
mmbanf
Italy
Hi everyone,
retrofit successful!
i ordered a genuine land rover repair cable, LR164584, then i ordered a blue universal connector adapter fakra coaxial cable.
the land rover cable has a green connector, which connects to the antenna, and a purple connector, this is an interconnection, to this purple I connected the universal extension which then connects to the black connector on the mirror.
Total I spent 50 euros of wiring.
installation procedure, I have published all the photos, phase 1, disassembly of the rear view mirror, disassembly of the roof lights console, disassembly of the rear side roof light.
phase 2, I passed the coaxial cable from the mirror opening to the lights console compartment, (this is a bit difficult), then from the lights console compartment, to the rear side light, and from this to the rear part under the antenna, (the latter very easy parts).
I referred to a video by Simon PFUK, whom I thank.
step 3, I disassembled the two antenna bolts, disconnected connectors, installed new antenna and connected new cable to green connector.
finally after closing everything, I did the coding thanks to the Gap Tool,
MultiCAN-711 Interior Mirror Variant
IRVM
changed to SVRM.
Only this programming, and voilà the game is done, I would say extremely simple.
Post #998185 1st Jul 2023 2:58pm
mmbanf
Italy
&feature=share[/url]
Post #998186 1st Jul 2023 3:02pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Great job Marco Bow down It's a modification that I would love to do. Am I right that you managed to pick the parts up second hand? Also the repair lead that you got, when you fed it through the roof, do you have the panoramic roof or just the plain one? Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #998205 1st Jul 2023 6:00pm
mmbanf
Italy
hi Jan, Thanks 👍, I found the used spare parts, I got a great deal, the wiring was new and relatively cheap, I easily passed the wiring without a sunroof, but as you can see from the photograph, in any case there are lateral spaces easy to walk.
it is a job that is completed in two hours
Marco
Post #998209 1st Jul 2023 6:18pm
Hairy Dan
Thanks for that Marco, I'm off to search for some second hand parts on Ebay Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #998210 1st Jul 2023 6:27pm
Defendit..
Netherlands
Nice job Marco, well done ! No Mud flaps for my 90.!
P300 S MY21 on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #998218 1st Jul 2023 8:26pm
Co1
Kudos! Top Job Marco.
Post #998234 2nd Jul 2023 6:40am
Clark4x4
Spain
Thanks for sharing Marco, Great gob!! Bow down
I’m collecting parts,( antenna and wire, need to find mirror) and I’ll replícate this retrofit, so your input is very much appreciated Thumbs Up
Oscar
Post #998242 2nd Jul 2023 8:58am
M7even
United Arab Emirates 2014 Defender 90 Puma 2.2 LXV Hard Top Santorini Black
Awesome retrofit!
Would be interesting to do it, but does it by any chance void the warranty ? 2014 Defender LXV
2023 Defender 90 HSE
Post #999370 9th Jul 2023 7:36pm
GrouseK9
United States 2016 Defender 110 BMW M52 2.8i Petrol CSW Auto Indus Silver
Fantastic job and wonderful post!! I'm ordering parts this week. One Q: I have a sun roof, did the cable come with plenty of slack? Wondering how much of a pain it will be to route it if it is tight and short. Thanks and well done.
Post #1001575 24th Jul 2023 4:34pm
mmbanf
Italy
thanks for the approval, Thumbs Up Thumbs Up
don't worry, it's easy to pass the wiring from the console (glasses holder) to the antenna.
follow the video I posted by the kind Simon of PF.
They have a car with a sunroof.
It is more difficult to pass the cable in 20 cm, from the console to the mirror support....
Marco
Post #1001577 24th Jul 2023 4:47pm
Page 1 of 6 123456>
