Home > Maintenance & Modifications > A day in the life of Miffy the 110... |
Ok I have decided not to fit the bull bar. I love the look but it is really too close to the AC grill. So, back to plan A I think.
If I do not need this bull bar it will be up for grabs if anyone is interested. It is perfectly straight and there is plenty of life left in it after a lick of paint. It would look great rubbed down and given a coat of Raptor. PM me if interested. |
23rd Jun 2023 9:51am |
Thanks Clayton. It is good to spend time on her. She has done a lot and gone a long way so it is about time she had some more significant effort spent on her. |
25th Jun 2023 10:45am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10728 |
Keeper. Clayton. |
26th Jun 2023 8:45pm |
Just a small vehicle related update. Managed to pick up a second hand tow ball mounted bike rack the other week. It is well used but has many many years worth of use left in it.
It needed a good rub down, rust converted, dash of paint (Raptor 1K) and some tube end caps. It now looks like it will last another decade or so It will be used on both the Defender and the Freelander 2. Click image to enlarge Click image to enlarge Click image to enlarge Love a good deal |
30th Jun 2023 3:36pm |
Good find and a great job with the paint work as usual 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
3rd Jul 2023 9:19pm |
Yes I was chuffed with the find, had no idea that bike racks were so expensive Anyway, it performed flawlessly with the E-bike on it.
3rd Jul 2023 9:58pm |
That's always the way when your looking for something, the price has rocketed glad it's all ok for the e bike 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
4th Jul 2023 4:31pm |
A nice dry evening this evening, so a chance to pop out and prep a few parts on the old girl for repair and painting.
The first thing to do is remove the broken anti vibration mounts I fitted to the RAI a few years ago now. At some point in a car park someone hung off the RAI and both mounts broke. So I sourced some beefier versions of the mounts. Re-positioned the bracket to where it needs to be and dismantled the RAI and intake manifold. Click image to enlarge Click image to enlarge Click image to enlarge A bit of wire brushing and keying later and the parts are almost prepped for paint, including the wing tops and RAI itself. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge The good news is that with a little creative grinding I have managed to save the important part of the a-frame mounting bracket. Bit of rust converter and paint and these will do for another few years until I can get my hands on a welder. Hopefully tomorrow will be dry and warm enough for paint |
4th Jul 2023 8:21pm |
This evening the wind died down enough that I could finish off the painting I started yesterday. The first bits are the RAI bracket, air intake manifold and a-frame lower brackets.
Click image to enlarge These have all been stripped, degreased, rust converted and coated with Raptor 1k rattle can spray. The internal surface of the intake manifold was surprisingly rusty considering I coated it before fitting, weird, but it should survive longer this time around. I also suspect I have saved just enough of the a-frame brackets that it won't fall off Next on the list are the wing tops, RAI top and RAI body itself. I realised this is the third time I have stripped and painted the wing tops in their life, had so much use out of these over the years. The RAI top is just because the plastic was sun faded so a quick spray to keep it pretty. I know vanity, my name is Geo... Click image to enlarge Click image to enlarge Click image to enlarge Finally the RAI body was in great shape, the plastic coating was a little sun faded (this is a PandP cages RAI) after five years or so, maybe longer. The only rust was on the mounting brackets where the coating had chipped off, so a bit more rust converter and a coat of Raptor 2k rattle can to match the bumper. It is a little less glossy than the plastic coating which suits me. Click image to enlarge Not bad, just fingers crossed it doesn't rain in the next hour or so... Also, I do love a comical spray mounting system Use what you have at hand and where would we be without pallet wrap Click image to enlarge Click image to enlarge |
5th Jul 2023 8:25pm |
Not the usual Blue Box part...
Click image to enlarge Great to meet @Shroppy this evening and thanks again for meeting me part of the way Also... TD5 TD5 TD5 you know it makes sense.... |
5th Jul 2023 8:42pm |
Just preparing to replace the second row crossmember and I know there are going to be some stubborn floor screws hiding away in that footwell
So in the post today came these bad boys... These are hex head No.14 3/4" screws. No more crappy Phillips cross heads Click image to enlarge And whilst I am in here, newly painted chequer wing top protectors. They look much smarter... Click image to enlarge Click image to enlarge and RAI too... Click image to enlarge |
6th Jul 2023 2:31pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5842 |
I ended up drilling out most of the floor screws when I did the mid xmember. 1999 Defender TD5 110
6th Jul 2023 2:37pm |
I fully expect John that I will be doing the same thing... Plus removing the internal roll hoop which should be... fun
6th Jul 2023 2:40pm |
One or two behaved but most of the 20+ year old screws simple said no.
Good luck. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
6th Jul 2023 2:42pm |
