Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 33 of 104 <123 ... 323334 ... 102103104>
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
MultiCAN754 AutoTRProgMode 0x02 change to Fitted
Gets me the auto button on the pivi screen but also the emergency brake fault Big Cry
There is also another setting for Auto which is
EUCD129 TERRAIN RESPONSE FITMENT 0x13
Change to Auto Terrain Response Dynamic & Configurable Dynamic Mode
but that doesn't make any difference to the brake error or give you the button so may not be connected Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #994439 29th May 2023 9:38pm
marcd3301
I'm really pleased to see the terrific progress made since uploading newer CCF. Now if only I could make such good use to enable ACC and Ambient Lighting! On a better note, I had great fun with my ATPC this long (UK) holiday weekend. Cheers Marc
20MY Defender 110 D240 First Edition, Gondwana Stone (enhanced with as much black as possible). Devon 4x4 winch mount, Bravo Snorkel fitted.
24MY Defender 110 D300 XS, Santorini Black.
Post #994474 30th May 2023 10:51am
OVRLANDR
United States
ATPC is the bomb!
I’ll look at my CCF’s this afternoon as I have TR2.
Post #994493 30th May 2023 12:38pm
Hairy Dan
Hairy Dan wrote:
I don't think any of the Defenders have park assist so I would be surprised if it can be enabled. The CCF file covers many cars in the range so not everything that is listed in there applies to the Defender, I'm not saying it can't be done but I haven't seen anybody that has tried. Confused
I made this reply a couple of weeks ago but I've just been watching one of Hunters Prestige videos and they mention activating the park assist feature to get the Defender to auto park so it does look like it is possible Confused
Link to part in video it is discussed
https://youtu.be/EaXLvPIbhQ4 Cheers Ian
Kielder 4x4 Safari
Post #994567 30th May 2023 10:27pm
OVRLANDR
United States
Ian,
I have the same thing as you for MultiCAN 736, 754, and 755.
For the EUCD-129, I have With Auto Terrain Response
I have the TR2 factory fitted.
Post #994570 30th May 2023 11:46pm
Hairy Dan
Thumbs Up I'll give that a try Cheers Ian
Kielder 4x4 Safari
Post #994636 31st May 2023 2:22pm
Allegedly
United States
I have a 2022 NAS with Premium LED headlights, a GAP tool on the way and a really strong desire to upgrade to Matrix LED. I can get the parts.
Has anyone had success doing this mod with a GAP tool? Simon at PowerfulUK did his but I think he used Pathfinder.
Post #995051 4th Jun 2023 3:28pm
walfy
Just thinking aloud here. I can see the benefit of this tool, adding to the functionality of the vehicle.
But has anyone managed to enable the rear door windows to open and close? I know you need a loom to get the doors connected electrically to the rest of the vehicle but unsure if the GAP tool can activte the windoes? 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #995125 5th Jun 2023 11:16am
EataPeach4923
Anyone had luck with ACC and Dynamic Mode w/ red gauges? I have a 2020 P400 SE and am trying to get these working.
Post #995446 7th Jun 2023 2:03pm
muppetry
United States
I haven't seen any reports of ACC being successfully activated with this tool yet. The website says they are still working on it.
Dynamic mode works fine, but only a few reports of red gauges showing up.
Post #995528 8th Jun 2023 3:43am
Paladino
What is the best place to buy the tool in UK/Germany? Thanks
Post #995532 8th Jun 2023 5:49am
emariu
Romania
Is there an updated list with all the modifications that are functioning and all the settings needed to be changed in order to obtain them?
I had just received my GAP IID Tool and I need some help with CCF coding
Thank you in advance
Post #996004 12th Jun 2023 2:31pm
OVRLANDR
United States
If you read back through the discussions you will find that Ian (Hairy Dan) has them posted in one of his discussions.
Post #996008 12th Jun 2023 3:05pm
Japseroony
England 2016 Defender 110 Puma 2.2 XS CSW Montalcino Red
Try Bell Auto Services in or just outside York - BAS here https://bellautoservices.co.uk/
Thumbs Up Gas, Grass Or Ass - Nobody Rides For Free
"UNDERSTEER" ----is when you hit the fence with the front of the car.
"OVERSTEER" ------is when you hit the fence with the rear of the car.
"HORSEPOWER" ----is how fast you hit the fence.
"TORQUE" -----------is how far you take the fence with you.
Post #996009 12th Jun 2023 3:08pm
marcd3301
marcd3301 wrote:
Here's a tricky one which I seek the knowledge of the forum on. I've activated (or at least believe I have) ambient lighting:
EUCD-240 Ambient Lighting
Tri colour fitted, auto button enabled (and tried all other options)
and installed the passenger side, driver side, and centre (floor) console LEDs. I now have the function via Pivi, but still the LEDs refuse to illuminate. I've checked fuses (FL1 + FL3), but no joy. Has anybody else tried and been successful? I'm not sure if this is a CCF issue or connectivity, but I don't want to start chasing wires if somebody else is able to help.
A follow up on the quest for ambient lighting. I can confirm that the CCF:
is the correct setting, but this will not automatically enable you to retrofit the lighting across the dashboard or in the central console. These require connection of harness to the BCM, which Land Rover conveniently left unterminated.
However....
if you retrofit the following:
(less 13776D)after changing the CCF, you will at least have ambient lighting in your door bins and around the handle area of you doors. Instructions for door panel removal can be found from Powerful UK:  Cheers Marc
Post #996250 14th Jun 2023 2:14pm
