Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1396 |
MultiCAN754 AutoTRProgMode 0x02 change to Fitted
Gets me the auto button on the pivi screen but also the emergency brake fault There is also another setting for Auto which is EUCD129 TERRAIN RESPONSE FITMENT 0x13 Change to Auto Terrain Response Dynamic & Configurable Dynamic Mode but that doesn't make any difference to the brake error or give you the button so may not be connected Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
29th May 2023 10:38pm |
OVRLANDR Member Since: 16 May 2022 Location: New York Posts: 42 |
ATPC is the bomb!
I’ll look at my CCF’s this afternoon as I have TR2. |
30th May 2023 1:38pm |
I made this reply a couple of weeks ago but I've just been watching one of Hunters Prestige videos and they mention activating the park assist feature to get the Defender to auto park so it does look like it is possible Link to part in video it is discussed https://youtu.be/EaXLvPIbhQ4 Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
30th May 2023 11:27pm |
Ian, I have the same thing as you for MultiCAN 736, 754, and 755. For the EUCD-129, I have With Auto Terrain Response I have the TR2 factory fitted. |
31st May 2023 12:46am |
I'll give that a try Cheers Ian
31st May 2023 3:22pm |
Allegedly Member Since: 21 Oct 2021 Location: FL Posts: 11 |
I have a 2022 NAS with Premium LED headlights, a GAP tool on the way and a really strong desire to upgrade to Matrix LED. I can get the parts.
Has anyone had success doing this mod with a GAP tool? Simon at PowerfulUK did his but I think he used Pathfinder. |
4th Jun 2023 4:28pm |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2650 |
Just thinking aloud here. I can see the benefit of this tool, adding to the functionality of the vehicle.
But has anyone managed to enable the rear door windows to open and close? I know you need a loom to get the doors connected electrically to the rest of the vehicle but unsure if the GAP tool can activte the windoes? 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
5th Jun 2023 12:16pm |
EataPeach4923 Member Since: 07 Jun 2023 Location: USA Posts: 17 |
Anyone had luck with ACC and Dynamic Mode w/ red gauges? I have a 2020 P400 SE and am trying to get these working.
7th Jun 2023 3:03pm |
muppetry Member Since: 31 May 2023 Location: NM Posts: 2 |
I haven't seen any reports of ACC being successfully activated with this tool yet. The website says they are still working on it. Dynamic mode works fine, but only a few reports of red gauges showing up. |
8th Jun 2023 4:43am |
Paladino Member Since: 07 Dec 2022 Location: Serbia Posts: 30 |
What is the best place to buy the tool in UK/Germany? Thanks
8th Jun 2023 6:49am |
emariu Member Since: 12 Jun 2023 Location: Calarasi Posts: 10 |
Is there an updated list with all the modifications that are functioning and all the settings needed to be changed in order to obtain them?
I had just received my GAP IID Tool and I need some help with CCF coding Thank you in advance |
12th Jun 2023 3:31pm |
If you read back through the discussions you will find that Ian (Hairy Dan) has them posted in one of his discussions.
12th Jun 2023 4:05pm |
Japseroony Member Since: 02 Jan 2008 Location: North East England Posts: 792 |
Try Bell Auto Services in or just outside York - BAS here https://bellautoservices.co.uk/ Gas, Grass Or Ass - Nobody Rides For Free "UNDERSTEER" ----is when you hit the fence with the front of the car. "OVERSTEER" ------is when you hit the fence with the rear of the car. "HORSEPOWER" ----is how fast you hit the fence. "TORQUE" -----------is how far you take the fence with you. |
12th Jun 2023 4:08pm |
marcd3301 Member Since: 11 May 2023 Location: Telford Posts: 22 |
A follow up on the quest for ambient lighting. I can confirm that the CCF: EUCD-240 Ambient Lighting Tri colour fitted, auto button enabled is the correct setting, but this will not automatically enable you to retrofit the lighting across the dashboard or in the central console. These require connection of harness to the BCM, which Land Rover conveniently left unterminated. However.... if you retrofit the following: Click image to enlarge (less 13776D)after changing the CCF, you will at least have ambient lighting in your door bins and around the handle area of you doors. Instructions for door panel removal can be found from Powerful UK: Cheers Marc -------------------- 20MY Defender 110 D240 First Edition, Gondwana Stone (enhanced with as much black as possible). Devon 4x4 winch mount, Bravo Snorkel fitted. 24MY Defender 110 D300 XS, Santorini Black. |
14th Jun 2023 3:14pm |
