![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
graemesmith1960 Member Since: 03 Sep 2021 Location: West of Scotland Posts: 79 ![]() ![]() |
Also available direct from GAP Diagnostics (the people who make them) sent from Canada (beware the customs duty). Just click on Sponsers at the top right of the page and you will get an advert. There are also quite a few dealers in the UK but I'm not sure if Forum rules allow me to mention them but I'll give you the one who is associated with GAP and that is Bell Auto Services.
IID Tools have been around for more than just a few years and for the post 2017 cars you need version III. Not sure when this came out but mine was too old and I needed a new one. Because of that I'd be reluctant to buy one off eBay just in case. Also they are locked to an individual VIN although you can pay to have it transferred but a second hand one may have been blacklisted so you really don't want to go there. Just my opinion of course. Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey |
That was my plan. Unfortunately the ECU dump from the tool confirmed I had a locked down KVM. You can’t program a new KVM from this tool as you won’t have any keys already coded. You need Pathfinder to do it from scratch. Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey
Deus98 Member Since: 25 Feb 2023 Location: City Hall Posts: 8 ![]() ![]() |
Thanks Dan for clarifying your settings. Mine is the P400 MHEV. Now this get interesting with the clockspring. I don't seem to find this as a stand alone part, instead it seem to come as whole column on Scuderiaparts website. I did find it on a Chinese site as part of the 007 steering wheel kit. Tried asking but seller will not sell me just the clockspring. Gonna dig deeper for its part number. 2020 MY, 110, P400 SE |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1426 ![]() ![]() ![]() |
Hi, yes it would appear that every other model of Land Rover/Range Rover has a separate clock spring but the Defender appears to be only available complete with the two stalks which seems a bit mad to me
![]() ![]() https://huntersprestige.com/products/heate...eq=uniform Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
I spoke to a Chinese remote programmer who will be helping me find out the part number. The photo he shared does seem to be able to buy in part, Indo suspect it may not be genuine JLR then. Once I have it done and coded, I shall share the coding parameters needed to make it work.
![]() Click image to enlarge 2020 MY, 110, P400 SE |
StromC Member Since: 30 Jan 2023 Location: Rockville Posts: 13 ![]() ![]() |
Yes. I purchased the correct activity key and was able to activate using the GAP tool. The key is that the vehicle must be in service mode when you activate. |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 246 ![]() ![]() |
Did you already have two keys supplied with your vehicle and also activate the activity key?
Most UK spec Defenders will have a locked KVM. The PowerfulUK 90 didn't and they were able to add an activity key. Mine is locked down unfortunately. If you do an ECU dump from the IID tool it will list the KVM near the end. Mine reports as 'Locked for Life'. GAP have confirmed that I cannot add an activity key without a new KVM. Unfortunately to use the IID tool to program keys you need to have at least one key programed into the KVM. A new one will not have this and Pathfinder is the only way to program a new KVM. It seems I am stuck with getting a dealer to provide and fit all the required bits and pieces. I know there Websites advertising L663 Activations which include Activity Key but they are all at least a 1000 mile round trip away so unless anyone knows of a place in Central Scotland providing this service it's going to be an expensive Activity Key! Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey
I am in the US. I had two delivered standard keys. The GAP tool simply added the activity key as a third key.
Nashvegas Member Since: 25 Dec 2021 Location: Portland, Oregon Posts: 40 ![]() ![]() |
Saw today that my iPhone updated to a new IIDTool app (I'm the beta program), version 4.1.4 Build 122.
Any exciting new features or functions ? |
OVRLANDR Member Since: 16 May 2022 Location: New York Posts: 42 ![]() ![]() |
I was trying to fiddle around some more with the ACC settings today. Since this last update to the IID Tool, I no longer have “MultiCAN-712 ACC Lead Car Distance Display” and “MultiCan-809 ACC Stop Gap Setting”. Have they disappeared from anyone else?
I am up to date and I still have it
MultiCAN-712 ACC Lead Car Dist Disp set to Not fitted I also still have MultiCAN-809 ACC Stop Gap Setting set to Fitted I also have factory fitted ACC ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Great, hopefully you get it sorted and please do share the parameters ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
You didn’t happen to save an ECU Info List before you added the key? The entry I’m interested in is about 6th from the end: RFA-REMOTE FUNCTION ACTUATOR. My KVM State reported as ‘Locked Forever’ which GAP said that was it and I couldn’t add an activity key even though I only have 2 keys programmed. Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey |
