Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 28 of 110 <123 ... 272829 ... 108109110>
OVRLANDR
United States
I do not have MC-712 or MC-809.
This is what I have Sad
Post #988584 11th Apr 2023 12:04pm
forzahog
United States 2016 Defender 110 Other Works V8 Auto Fuji White
Let the guys at GAP know they're not showing up and they can add them. I think they add some of those on a case by case basis. With it being in beta and all. 20MY Defender 110 Fuji White
Post #988603 11th Apr 2023 3:54pm
forzahog
Ugh, double post somehow. Whistle 20MY Defender 110 Fuji White
Post #988604 11th Apr 2023 3:54pm
OVRLANDR
United States
Yes, I did send them off an email.
Post #988619 11th Apr 2023 5:23pm
OVRLANDR
United States
Ok, I reloaded the device firmware through tool updater and then to my iPad. Everything is there now and I’m back at it with the ACC.
Ian, you stated that you have factory fitted ACC…I’m wondering what you have for
MultiCAN-756 ABS Partc
Not Supported
Not Participating in Mode Management
Error
Post #988635 11th Apr 2023 7:14pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Glad you got it sorted Thumbs Up This is how mine is set
Participating in Mode Management Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #988640 11th Apr 2023 7:21pm
OVRLANDR
United States
Thank you Ian! Bow down
And thank you for looking that up for me. I’m trying to figure where the ABS fault is coming from when I make changes to MultiCAN 580, 712, and 809. I have LKA from the factory and notice that when I make changes to those three MC files, the LKA goes inactive. LKA has to be part of the equation.
Post #988644 11th Apr 2023 7:35pm
Hairy Dan
These are the settings I have for those
MultiCAN-580 PTCruiseFitment
ACC with Queue Assist fitted
MultiCAN-712 ACC Stop Gap Select
Not supported
MultiCAN-809 ACC Stop Gap Setting
Fitted Cheers Ian
Kielder 4x4 Safari
Post #988649 11th Apr 2023 7:53pm
lightning
Can someone tell me, is it possible to disable the auto folding mirrors and make them manual.
So they only open/close when you press the buttons near the electric window switches? The reason is, when we are towing the caravan and have the extension mirrors fitted, if you lock the vehicle the mirrors fold and the extension mirror clamps hit the door.
Post #988668 11th Apr 2023 8:47pm
forzahog
It's probably some combination of these two. I haven't changed them to see what they do yet.
MultiCAN-688 MirrorPositionFeature
Estimated Folded/Unfolded
MultiCAN-703 Exterior Mirror Auto Unfold
Automatic External Mirrors Unfold Enabled 20MY Defender 110 Fuji White
Post #988674 11th Apr 2023 9:02pm
mmbanf
Italy
Abs error last update
good morning everyone, with the latest update this visible error appeared with the gap tool, no symptoms or warning light on the car.
the only changes I made are those reported on the forum ( dynamic mode, wifi, 007, drl) .
I think the problem originates from the dynamic mode configuration maybe not complete or incorrect, has anyone seen this error?
Post #989139 16th Apr 2023 3:48pm
forzahog
I had that for a long time and just ignored it, but then I stumbled upon a pathfinder thread where they mentioned that you can get that with a ccf mismatch for the vehicle. It apparently doesn't have to have anything to do with ABS. I did a restore to my original ccf and then made my updates and it went away. 20MY Defender 110 Fuji White
Post #989179 16th Apr 2023 11:08pm
mmbanf
Italy
thank you very much for the reply,
at this point I ignore it, since it has no defects.
Marco
Post #989440 19th Apr 2023 7:36am
lightning
So it looks like time to buy this unit, as it's working for the things l want to do such as the stop/start memory
l looked on the GAP Diagnostic website and it still says Defender L663 "coming soon"
Also there's a couple of options, one at £500 the other at £2,000
Hopefully the £500 one will be all l need.
And it mentions "subscription" at a further £500 per year. Obviously this is really designed for repair garages and dealers.
As a private buyer, buying a unit to work on their own vehicle only, would l still need to pay the £500 subscription to get the unit to work?
Post #990339 25th Apr 2023 9:15pm
Hairy Dan
As I said last time you asked, the best place to buy it is from one of GAP's distributors, Duckworths at Market Rasen are one and also a forum sponsor, if you ring and ask for Sophie you will get the best price. The one that you want is the IIDTool BT G3 which should cost below the £500 you mentioned from Duckworths, the more expensive one is the pro version which isn't tied to just one VIN and that has the subscription, the IIDTool BT G3 is buy it once and use it with one VIN (although you can purchase extra VIN's if you have more than one LR) there is no yearly subscription to pay. If you do decide to purchase it via the GAP website remember that it is based in Canada and there may be extra tax to pay on the unit when it arrives in this country. The GAP website mentions it's 'coming soon' for the L663 as it is still in Beta test, the final release hasn't been released yet Confused Laughing If you buy one before the final release you will have to ask Pat to add you to the Beta test in order to use the tool on the L663. To do this you will have to install a programme called Test Flight on your mobile device and install the firmware to the tool via a desktop computer or Mac. Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #990366 26th Apr 2023 12:19am
