![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
forzahog Member Since: 03 Nov 2022 Location: Fayetteville Posts: 66 ![]() ![]() ![]() |
Did you have this activated via the IID tool? On mine (2020 P300) it's a drastic change from comfort.
- Dynamic Mode EUCD-245 Dynamic-I Standard: Dynamic-i Not Fitted Changed to: Dynamic-i Content with Configurable Dynamic Mode Screen MultiCAN-562 DynamicProgMode Standard: Not available for selection Changed to: Available for selection without timeout Other possible value: Available for selection with timeout MultiCAN-605 ConfigDynamicMode Standard: Not Fitted Changed to: Fitted 20MY Defender 110 Fuji White |
MattF Member Since: 28 Oct 2022 Location: Norwalk CT Posts: 32 ![]() ![]() |
Thank you -
The only difference I see is mine is set to the other possible value (Available for selection with timeout). I wonder if that could be it or there is some other configuration overriding these. I believe the guy turned on all the V8 configs.... MultiCAN-562 DynamicProgMode Standard: Not available for selection Changed to: Available for selection without timeout Other possible value: Available for selection with timeout |
GAT Member Since: 19 Apr 2013 Location: Kent Posts: 113 ![]() ![]() |
Definitely stiffer ride and to me it picked up much better and didn’t seem to have the hesitation. I put it to Dynamic most times. First Edition 90 in Pangea Green. (Gone)
P400 110 in Tasman Blue. |
Would you have an export of your ccf by any chance? 20MY Defender 110 Fuji White |
I just received a cvs file of it. What is the best way to share it?
Thanks much! |
I put it out on one of the share sites (onedrive, dropbox, google drive, etc) and then share the link via pm. 20MY Defender 110 Fuji White
Done - PM sent
Thank you |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1426 ![]() ![]() ![]() |
I would say with mine it seems to stiffen the suspension and adds weight to the steering it also seems to pull better from take off. The only thing with mine is that my dials don't turn red.
![]() ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Ian
PM sent - Thank you! |
I take it who ever did you activations used a ccf editor and the Land Rover Pathfinder System as I noticed that some of the wording etc was different to the IID Tool and there were some extra options on your printout
Dynamic Mode EUCD-245 Dynamic-I Standard: Dynamic-i Not Fitted Changed to: Dynamic-i Content with Configurable Dynamic Mode Screen This is the only change I can see from yours to mine, mine is set to Available for selection without timeout and yours is set to Available for selection with timeout MultiCAN-562 DynamicProgMode Standard: Not available for selection Changed to: Available for selection without timeout Other possible value: Available for selection with timeout MultiCAN-605 ConfigDynamicMode Standard: Not Fitted Changed to: Fitted I can't see that difference making Dynamic mode not work as I have experimented with timeout and without timeout and it didn't seem to make a difference on my car ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
You are correct the Pathfinder tool was used. It's really quite the puzzle. Maybe time to just trying to reload the ccf file again....
Thank you for taking the time to review this. I'm grateful Matt |
Has anybody ran a fault check since the app was updated the other night? For some reason my quits early when asking it to check faults
Lockley Member Since: 15 Feb 2023 Location: Herefordshire Posts: 16 ![]() ![]() |
Yes, I did have this problem. I reported it to Pat who sent me a new build which seems to have resolved the issue. I’m now on build 119.
L663 D300 MY22 |
Great thanks, I have reported it also
