![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1443 ![]() ![]() ![]() |
I'll see if I can get a photo tomorrow
THe only setting I can see in my ccf related to cooled seats is as follows EUCD-054 Heated Front Seats Heated And Cooled Front Seats, Volvo, 3 Mode Zoning EUCD-055 Front Seat Ventilation Not supported MultiCAN-671 SlcClimateSeats Available to the driver only and the setting for the climate rear seats (which I don't have) MultiCAN-835 Rr Climate Seats SZM No Heated or Climate Seats ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
This is the view from the front of the driver's seat
![]() Click image to enlarge and this is from the rear of the driver's seat ![]() Click image to enlarge The large circular fan at the rear is what switches on when cooled seats are switched on ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
OVRLANDR Member Since: 16 May 2022 Location: New York Posts: 45 ![]() ![]() |
![]() Click image to enlarge There’s an electrical unit in front of that fan called a peltier. This unit produces heat or cooling according to the electrical current direction. So you would need two of these for each seat as one is used for the seat bottom and one for the back of the seat. |
GAT Member Since: 20 Apr 2013 Location: Kent Posts: 120 ![]() ![]() |
Thanks for the replies.
I haven’t got that under either seat which is no real surprise. So I wonder if being the parts needed it could be retrofitted. And what the cost of the parts might be. First Edition 90 in Pangea Green. (Gone) P400 110 in Tasman Blue. |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3070 ![]() ![]() |
Wow that's a bit of an advancement from the seats in my old 110
forzahog Member Since: 03 Nov 2022 Location: Fayetteville Posts: 67 ![]() ![]() ![]() |
I have been looking to do this as well. I found some on ebay. I've been waiting to research and see if you have to take the seat cushion off.
https://www.ebay.com/itm/234790589958?mkci...media=COPY 20MY Defender 110 Fuji White |
I have replaced the left seat back heater/ac in my 2018 Range Rover. That involved taking the panel on the back of the seat off, not the actual seat cover. I believe it took me approximately three hours and was not that bad of a job as I was just exchanging parts. I am not familiar with the Defenders set-up but imagine it would be pretty much similar however, you might have to build/install the complete system.
Bob Heijnen Member Since: 29 Nov 2022 Location: Noordwijk Posts: 17 ![]() ![]() |
1. wifi hotspot. Free data for life!
2. Last user mode disables stop start on p300 defenders permanetly on or off with the simple touch of a button even after ignition cycles. 3. Adaptive cruise control with que assist including full stop and go. 4. Adaptive speed limiter. 5. Adaptive high beams with configurable settings. 6. Advanced off road package. 7. All terrain prgress control & configurable terrain response! 7A. Terrain Response 2! 8. On demand center locking differential with the touch of a button. 9. Global window close from your key fob. 10. Global window open from your key fob. 11. Sunroof open from your key fob. 12. Sunroof close from your key fob. 13. Tailgate pop open from your key fob. 14. Bright Lights/High beams on with your fog lights on. (Not allowed in North America buyt we do it) 15A. Configurable dynamic mode (Even the V8 and/or 007 Defenders dont have this!) 15B. Proximity locking & unlocking works on some model years. 16. Dynamic mode- controls throttle, suspension, steering, braking settings. 17. Timers and G force meters on the navigation system. 18. DAB radio and XM radio activation. (Needs a subscription eventually.) 19. Engine noise cancellation. 20 Engine sounds through the speakers disabled. 21. Cell Phone signal boosting. 22. Advanced Tow assist. 23. Activity Key as long as you have the correct MHZ frequency key. 24. Needs hardware! Adding center console fridge freezer. 25. Needs professional installation and wiring then we can activate the rear differential as an oem add on after the fact. Yes fully OEM with the advanced off road pack after you buy the oem parts and have them professionally installed we can activate the differential to be fully oem integrated. 26. Trunk pop key fob 27 disable some seat belt chiming. 28. Add additional color blending to your inter cabin lights if you already have them. 29. Disable interior lights turning on when tailgate is open great for security at night and camping. This a list that can be activated in LA. Lots of interesting options. We still have a lot to figure out .... ![]() |
Are you offering these options or is it what you’ve found to be possible?
If so then please share how. Thanks First Edition 90 in Pangea Green. (Gone) P400 110 in Tasman Blue. |
This is what I found to be possible.
As soon as I figured out how I will post it surely. Hope other will do the same. Greetings |
MattF Member Since: 28 Oct 2022 Location: Norwalk CT Posts: 32 ![]() ![]() |
![]() Click image to enlarge Question: Has anyone through any means gotten Dynamic Mode activated and confirmed it changes the driving dynamics (engine, steering, gears, suspension). I had this activated earlier this week and all the functions are present in the Pivi but there is no change in the actual driving dynamics between Comfort and Dynamic. ![]() Click image to enlarge ![]() Click image to enlarge |
![]() Click image to enlarge Question: Has anyone through any means gotten Dynamic Mode activated and confirmed it changes the driving dynamics (engine, steering, gears, suspension). I had this activated earlier this week and all the functions are present in the Pivi but there is no change in the actual driving dynamics between Comfort and Dynamic. Mine is a MY23 P300 ![]() Click image to enlarge ![]() Click image to enlarge |
sorry for the double post
In my case it does, shifting at higher refs, suspension stiffer and better cornering. I actually prefer it to comfort mode.
