Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 23 of 104 <123 ... 222324 ... 102103104>
MattF
United States
Can you share more specifics?
What CCF settings, Model Year, etc.?
It seems like i'm missing some important setting
Thank you
Post #983462 23rd Feb 2023 7:22pm
forzahog
United States 2016 Defender 110 Other Works V8 Auto Fuji White
Did you have this activated via the IID tool? On mine (2020 P300) it's a drastic change from comfort.
- Dynamic Mode
EUCD-245 Dynamic-I
Standard: Dynamic-i Not Fitted
Changed to: Dynamic-i Content with Configurable Dynamic Mode Screen
MultiCAN-562 DynamicProgMode
Standard: Not available for selection
Changed to: Available for selection without timeout
Other possible value: Available for selection with timeout
MultiCAN-605 ConfigDynamicMode
Standard: Not Fitted
Changed to: Fitted 20MY Defender 110 Fuji White
Post #983464 23rd Feb 2023 7:28pm
MattF
United States
Thank you -
The only difference I see is mine is set to the other possible value (Available for selection with timeout). I wonder if that could be it or there is some other configuration overriding these.
I believe the guy turned on all the V8 configs....
Post #983478 23rd Feb 2023 8:27pm
GAT
Definitely stiffer ride and to me it picked up much better and didn’t seem to have the hesitation. I put it to Dynamic most times. First Edition 90 in Pangea Green. (Gone)
P400 110 in Tasman Blue.
Post #983479 23rd Feb 2023 8:30pm
forzahog
MattF wrote:
Thank you -
Would you have an export of your ccf by any chance? 20MY Defender 110 Fuji White
Post #983480 23rd Feb 2023 8:44pm
MattF
United States
I just received a cvs file of it. What is the best way to share it?
Thanks much!
Post #983481 23rd Feb 2023 8:45pm
forzahog
I put it out on one of the share sites (onedrive, dropbox, google drive, etc) and then share the link via pm. 20MY Defender 110 Fuji White
Post #983492 23rd Feb 2023 10:20pm
MattF
United States
Done - PM sent
Thank you
Post #983493 23rd Feb 2023 10:25pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
I would say with mine it seems to stiffen the suspension and adds weight to the steering it also seems to pull better from take off. The only thing with mine is that my dials don't turn red. Sad If you pm me also with your ccf file I'll have a look at it compared to mine Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #983497 23rd Feb 2023 11:34pm
MattF
United States
Ian
PM sent -
Thank you!
Post #983500 23rd Feb 2023 11:52pm
Hairy Dan
I take it who ever did you activations used a ccf editor and the Land Rover Pathfinder System as I noticed that some of the wording etc was different to the IID Tool and there were some extra options on your printout
Dynamic Mode
EUCD-245 Dynamic-I
This is the only change I can see from yours to mine, mine is set to Available for selection without timeout and yours is set to Available for selection with timeout
Changed to: Fitted
I can't see that difference making Dynamic mode not work as I have experimented with timeout and without timeout and it didn't seem to make a difference on my car Confused Cheers Ian
Kielder 4x4 Safari
Post #983596 24th Feb 2023 11:31pm
MattF
United States
You are correct the Pathfinder tool was used. It's really quite the puzzle. Maybe time to just trying to reload the ccf file again....
Thank you for taking the time to review this. I'm grateful
Matt
Post #983599 24th Feb 2023 11:34pm
Hairy Dan
Has anybody ran a fault check since the app was updated the other night? For some reason my quits early when asking it to check faults Confused Cheers Ian
Kielder 4x4 Safari
Post #983673 25th Feb 2023 7:21pm
Lockley
Yes, I did have this problem. I reported it to Pat who sent me a new build which seems to have resolved the issue. I’m now on build 119.
L663 D300 MY22
Post #983701 25th Feb 2023 10:15pm
Hairy Dan
Great thanks, I have reported it also Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #983702 25th Feb 2023 10:20pm
