Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
graemesmith1960 Member Since: 03 Sep 2021 Location: West of Scotland Posts: 64 |
I've got Walk Away Locking working on my MY22 UK Spec HSE.
Not quite as simple as that statement implies though. First I enabled the WiFi Hotspot, left the cat for 30 minutes and nothing - it did not appear as an option. An hour later I tried enabling Walk Away Locking - left it switched off for 30 minutes afterwards - nothing. After driving it on a short journey and leaving it for a couple of hours both options were there in Pivi when I started up again and both work. Now for TR2! Defender D300 HSE 110 MY22 Pangea Green |
14th Jan 2023 5:54pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1413 |
If you change a setting and it doesn't appear after you have left the car to go to sleep, try rebooting the Pivi-Pro system and it will usually appear when it restarts Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
14th Jan 2023 5:57pm |
tooth_dr Member Since: 26 May 2021 Location: Northern Ireland Posts: 236 |
Where are you guys buying the scanner?
14th Jan 2023 7:36pm |
Yes, I was aware of that. Unfortunately I use a lot of rural destinations in the SatNav that require a Lat and Long input due to JLR's total inability to get a working system for Web Based favorites (like the previous incarnation of InControl had). The added benefit of WiFi Hotspot and Walk Away Locking pale into insignificance when a Pivi Pro reset wipes everything out! Done it once, don't want to do it again...... Defender D300 HSE 110 MY22 Pangea Green
14th Jan 2023 7:37pm |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 162 |
Hello,
this coding of the front lights is set by default on all versions, even those with basic LED lights. * EUCD-014 Headlights, Type Matrix LED AFS123/IHB, the main coding of the front lights is this: * MultiCAN-679 HeadlightsVariant Headlamp_Variant_Low_A where low : basic led lights; medium: premium led lights; hight: led matrix headlights Marco |
15th Jan 2023 12:44pm |
I got mine from forum sponsor Duckworth's Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
15th Jan 2023 3:10pm |
A Pivi-pro reboot shouldn't delete any data at least I'm pretty sure it hasn't on mine and I've rebooted it quite a few times, heck it even keeps me logged in after the reboot Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
15th Jan 2023 3:12pm |
After you have enabled walk away locking have you turned it on in the settings on Pivi Pro? I get the setting to appear but it doesn't work but I also have the locking fuel door Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
15th Jan 2023 3:15pm |
cfitzge Member Since: 11 Jan 2023 Location: North Carolina Posts: 8 |
Well that’s super disappointing that they all say Matrix! I was giving Sanctuary2325 (my cars previous owner) too much credit! 😆 When I look at “MultiCAN-679 HeadlightsVariant” I see Headlamp_Variant_Mid_C, so I’m guessing that’s premium LED? Weird that I see a grid of stacked LEDs when I look in the lens though? Maybe that’s normal high/low beam? |
15th Jan 2023 4:05pm |
I did turn it on in settings, but nothing seemed to happen when I tested it. Granted I’m not 100% sure how to test it besides locking the doors, walking away, then walking up to the car and waiting for it to unlock… |
15th Jan 2023 4:07pm |
Cheers Dan. Have one on order and signed up with Pat. |
15th Jan 2023 5:27pm |
It only locks the car, it doesn't unlock it. When it is enabled walk away from the car. When it senses the key is about 10 feet or more away it should lock if it works. Defender D300 HSE 110 MY22 Pangea Green |
15th Jan 2023 8:05pm |
carsly Member Since: 09 Jan 2023 Location: Central New Jersey Posts: 11 |
Here is what my cluster looks like And my settings (only changed the starred ones) Click image to enlarge Click image to enlarge I seem to have lost my backup camera and surround view cams so if anyone has tips on those I’d appreciated it. Have tried a dozen odd permutations on the front and side camera setting with no luck. Click image to enlarge |
16th Jan 2023 8:55pm |
I can't quite see on your dials but this is the red accent that we are talking about
Click image to enlarge Whereas mine stays like this when Dynamic mode is engaged Click image to enlarge With your cameras have you tried reading the fault codes for the car and have you rebooted the Pivi screen? Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
16th Jan 2023 11:18pm |
