Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 15 of 109 <123 ... 141516 ... 107108109>
graemesmith1960
I've got Walk Away Locking working on my MY22 UK Spec HSE.
Not quite as simple as that statement implies though. First I enabled the WiFi Hotspot, left the cat for 30 minutes and nothing - it did not appear as an option. An hour later I tried enabling Walk Away Locking - left it switched off for 30 minutes afterwards - nothing.
After driving it on a short journey and leaving it for a couple of hours both options were there in Pivi when I started up again and both work.
Now for TR2! Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey
Post #978042 14th Jan 2023 5:54pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
If you change a setting and it doesn't appear after you have left the car to go to sleep, try rebooting the Pivi-Pro system and it will usually appear when it restarts Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #978044 14th Jan 2023 5:57pm
tooth_dr
Northern Ireland
Where are you guys buying the scanner?
Post #978072 14th Jan 2023 7:36pm
graemesmith1960
Yes, I was aware of that. Unfortunately I use a lot of rural destinations in the SatNav that require a Lat and Long input due to JLR's total inability to get a working system for Web Based favorites (like the previous incarnation of InControl had). The added benefit of WiFi Hotspot and Walk Away Locking pale into insignificance when a Pivi Pro reset wipes everything out! Done it once, don't want to do it again...... Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey
Post #978073 14th Jan 2023 7:37pm
cfitzge
United States
So I just got my tool up and running, managed to make the well-documented changes from the thread successfully.
Found a couple weird things in my 2022 P400 Xdynamic HSE:
    - I don’t have a locking gas cap, but seems like walk away locking does not work (unfortunately).
    - I see in my config that I have matrix lights and I’m in the US… also looking through my headlights I see a grid of LEDs?
So does anyone know how to turn on the adaptive headlights, since I think the previous owner may have upgraded them for me?
Post #978113 14th Jan 2023 11:30pm
mmbanf
Italy
Hello,
this coding of the front lights is set by default on all versions, even those with basic LED lights.
* EUCD-014 Headlights, Type
Matrix LED AFS123/IHB,
the main coding of the front lights is this: * MultiCAN-679 HeadlightsVariant
Headlamp_Variant_Low_A
where low : basic led lights; medium: premium led lights; hight: led matrix headlights
Thumbs Up Thumbs Up Thumbs Up
Marco
Post #978175 15th Jan 2023 12:44pm
Hairy Dan
I got mine from forum sponsor Duckworth's Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #978188 15th Jan 2023 3:10pm
Hairy Dan
A Pivi-pro reboot shouldn't delete any data at least I'm pretty sure it hasn't on mine and I've rebooted it quite a few times, heck it even keeps me logged in after the reboot Confused Cheers Ian
Kielder 4x4 Safari
Post #978190 15th Jan 2023 3:12pm
Hairy Dan
After you have enabled walk away locking have you turned it on in the settings on Pivi Pro?
I get the setting to appear but it doesn't work but I also have the locking fuel door Confused Cheers Ian
Kielder 4x4 Safari
Post #978191 15th Jan 2023 3:15pm
cfitzge
United States
mmbanf wrote:
Hello,
Marco
Well that’s super disappointing that they all say Matrix! I was giving Sanctuary2325 (my cars previous owner) too much credit! 😆
When I look at “MultiCAN-679 HeadlightsVariant” I see Headlamp_Variant_Mid_C, so I’m guessing that’s premium LED? Weird that I see a grid of stacked LEDs when I look in the lens though? Maybe that’s normal high/low beam?
Post #978199 15th Jan 2023 4:05pm
cfitzge
United States
I did turn it on in settings, but nothing seemed to happen when I tested it. Granted I’m not 100% sure how to test it besides locking the doors, walking away, then walking up to the car and waiting for it to unlock…
Post #978202 15th Jan 2023 4:07pm
tooth_dr
Northern Ireland
Cheers Dan. Have one on order and signed up with Pat.
Post #978222 15th Jan 2023 5:27pm
graemesmith1960
It only locks the car, it doesn't unlock it. When it is enabled walk away from the car. When it senses the key is about 10 feet or more away it should lock if it works. Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey
Post #978252 15th Jan 2023 8:05pm
carsly
United States 2016 Defender 130 Other SW Auto Bali Blue
Hairy Dan wrote:
Ajay(UK) wrote:
carsly wrote:
So far I've enabled, and tested, the wireless hotspot and enabled dynamic mode, complete with the red gauges.
The holy grail of “Red Gauges” Laughing
Please share the ccf options you changed to get the dials to go red in dynamic mode? Most of us can only get the ambient light to change to red Rolling Eyes
Cheers,
Andy.
Yes please share your settings, I've got dynamic mode and my ambient lighting goes red but the dials don't Confused
Here is what my cluster looks like
And my settings (only changed the starred ones)
I seem to have lost my backup camera and surround view cams so if anyone has tips on those I’d appreciated it. Have tried a dozen odd permutations on the front and side camera setting with no luck.
Post #978421 16th Jan 2023 8:55pm
Hairy Dan
I can't quite see on your dials but this is the red accent that we are talking about
Whereas mine stays like this when Dynamic mode is engaged
With your cameras have you tried reading the fault codes for the car and have you rebooted the Pivi screen? Cheers Ian
Kielder 4x4 Safari
Post #978436 16th Jan 2023 11:18pm
