Home > Puma (Tdci) > no heat from heater |
bcarlin Member Since: 24 Sep 2011 Location: lanarkshire Posts: 290 |
Thanks
I hope this is the problem as I don’t know what else it can be |
6th Dec 2022 8:03pm |
Start with eliminating the obvious, adjust the cables if necessary and go from there
6th Dec 2022 8:04pm |
6th Dec 2022 9:04pm |
Checked the temps
Expansion tank is running about 60c and the pipes at the heater are about 50c |
7th Dec 2022 4:27pm |
ob1conobe Member Since: 10 Jan 2014 Location: Gloucestershire Posts: 52 |
This thread may help:
https://www.defender2.net/forum/topic71379.html |
17th Dec 2022 1:14pm |
thanks but i dont think they got to the bottom of the issue
17th Dec 2022 4:22pm |
Replaced the thermostat It’s made no difference.
21st Dec 2022 2:44pm |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 502 |
I remember a recall on this issue dealing with the tubes.
Only driver's seat concerned (for RHD vehicles) |
23rd Dec 2022 7:29pm |
Iktank Member Since: 08 Nov 2014 Location: Porthcawl Posts: 237 |
I think it will be this as stated in earlier post
"there is a cable that goes to the heater control valve (plastic on bulkhead) and at least 1 if not two that go to the heater box itself. It might be that one or more of these are not fully opening or closing what they are meant to. This is a common thing on earlier Defenders, every now and again you have to re-adjust the wire within the lever fixing on the heater box to make sure the flap inside is actually closing properly" They only last few years before they fail - mine gave in after 6 years my mates the same, same part as used on a fiat and a few others e.g Cabin heater control valve (Fiat Part 77363342) I paid £23.50 for mine when I bought it Easy to change just be careful of the little metal cable retaining clip, LR part comes with it other makes dont and the little clip was a pain to find on line if you break the original: - JYC500070 - heater control cable clip located at heater valve and air con unit |
24th Dec 2022 7:49am |
24th Dec 2022 7:50am |
dupicate - cant delete
duplicate 2 also cant delete
24th Dec 2022 7:51am |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2052 |
You having a “Groundhog Day” Iktank
24th Dec 2022 1:42pm |
Mmmmmmm it appears so, internet froze and I clicked on post few time - and posted it three times !!!Can I delete any of them - nope
24th Dec 2022 2:24pm |
