Home > Puma (Tdci) > no heat from heater
Page 2 of 3 <123>
bcarlin
Thanks
I hope this is the problem as I don’t know what else it can be Big Cry
Post #973690 6th Dec 2022 9:03pm
geobloke
Start with eliminating the obvious, adjust the cables if necessary and go from there Thumbs Up
Post #973691 6th Dec 2022 9:04pm
bcarlin
Bow down
Post #973716 6th Dec 2022 10:04pm
bcarlin
Checked the temps
Expansion tank is running about 60c and the pipes at the heater are about 50c
Post #973817 7th Dec 2022 5:27pm
ob1conobe
United Kingdom 2014 Defender 90 Puma 2.2 HT Alpine White
Post #974973 17th Dec 2022 2:14pm
bcarlin
thanks but i dont think they got to the bottom of the issue
Post #974987 17th Dec 2022 5:22pm
bcarlin
Replaced the thermostat It’s made no difference.
Post #975366 21st Dec 2022 3:44pm
ob1conobe
This reflects the experienced expressed in the thread I gave you above.
So frustratingly no further forwards ...
Post #975368 21st Dec 2022 4:05pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
I remember a recall on this issue dealing with the tubes.
Only driver's seat concerned (for RHD vehicles)
Post #975619 23rd Dec 2022 8:29pm
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
I think it will be this as stated in earlier post
"there is a cable that goes to the heater control valve (plastic on bulkhead) and at least 1 if not two that go to the heater box itself. It might be that one or more of these are not fully opening or closing what they are meant to. This is a common thing on earlier Defenders, every now and again you have to re-adjust the wire within the lever fixing on the heater box to make sure the flap inside is actually closing properly"
They only last few years before they fail - mine gave in after 6 years my mates the same, same part as used on a fiat and a few others e.g
Cabin heater control valve (Fiat Part 77363342) I paid £23.50 for mine when I bought it
Easy to change just be careful of the little metal cable retaining clip, LR part comes with it other makes dont and the little clip was a pain to find on line if you break the original:
- JYC500070 - heater control cable clip located at heater valve and air con unit
Post #975635 24th Dec 2022 8:49am
Iktank
Post #975636 24th Dec 2022 8:50am
Iktank
dupicate - cant delete
Post #975637 24th Dec 2022 8:50am
Iktank
duplicate 2 also cant delete Very Happy
Post #975638 24th Dec 2022 8:51am
Ianh
You having a “Groundhog Day” Iktank Rolling with laughter
Post #975651 24th Dec 2022 2:42pm
Iktank
Mmmmmmm it appears so, internet froze and I clicked on post few time - and posted it three times !!!Can I delete any of them - nope Rolling Eyes
Post #975653 24th Dec 2022 3:24pm
Page 2 of 3 <123>
